Pagina 30 di 50 primaprima ... 20282930313240 ... ultimoultimo
Visualizzazione dei risultati da 291 a 300 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #291
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    umh maybe is a problem of the cm13
    there are other phones that have the same bug (so is not only baseband or phone related)
    https://www.reddit.com/r/cyanogenmod...th_on_gti9300/
    Interesting. The same problem with two different devices...
    My vote for a CM13 bug.
    link beta8 in first page
    Nubia Z7MAX
  4. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    flasher (22-01-16),jadar (21-01-16),migel121 (21-01-16)
  5. #293
    Feb 2014
    Grazie Paolo, now the Bluetooth connection whit Miband work's.
  6. Il seguente Utente ha ringraziato migel121 per il post:
    PaoloW8 (21-01-16)
  7. #294
    May 2015
    Madrid, Spain
    Nubia z7 max
    Just working. I see that Spanish translation is almost complete! CM13 GA is almost there! ;-)
  8. Il seguente Utente ha ringraziato inigoml per il post:
    PaoloW8 (21-01-16)
  9. #295
    Nov 2015
    Recently because of busy work, long time no see, I see you upload the code or beta5, for a long time to upload your latest beta8 code? We do not use other purposes, just learn it, thank you very much for your hard work. On behalf of the majority of my friends thank you!
  10. #296
    Nov 2015
    Run root explorerthe error?
  11. #297
    May 2015
    Madrid, Spain
    Nubia z7 max
    After two days I think it's time to move away from beta... Smooth, stable, battery friendly...
    An amazing job, Paolo, as usual.
  12. Il seguente Utente ha ringraziato inigoml per il post:
    PaoloW8 (23-01-16)
  13. #298
    Quote Originariamente inviato da awssong Visualizza il messaggio
    updated
    yes, root explorer no longer works on CM13, the app needs to be updated
    Nubia Z7MAX
  14. #299
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    thanks
    maybe I'll call the next release Rel1
    Nubia Z7MAX
  15. Il seguente Utente ha ringraziato PaoloW8 per il post:
    flasher (23-01-16)
  16. #300
    Jan 2015
    Nubia Z7 Max
    The beta 8 build is excellent. There's no wi-fi or bluetooth bugs, the SIM connection mode chooser works, all display options like double-tap to wake and so on work, and the ROM is smooth and appears to be stable. Only thing, I couldn't get LTE to work, but it might have to do with my network, since LTE is not exactly very stable around here.
    All in all, I'll likely move to this build in the very near future when I find some time to move all my apps
    Thanks for the great work Paolo! I don't know what kind of magic you use for this but it's obviously working
