Utente del giorno: reking71 con ben 2 Thanks ricevuti nelle ultime 24 ore
Pagina 29 di 50 primaprima ... 19272829303139 ... ultimoultimo
Visualizzazione dei risultati da 281 a 290 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #281
    Oct 2015
    Me too
    Oct 2013
    I dont have 4G or 3G,try both sim but not have data connection.
  4. #283
    Oct 2015
    Quote Originariamente inviato da tigreos Visualizza il messaggio
    About dual card 4G switch: card 1 data switch to the card 2 data, the first card 1 to only GSM, and then switch card 2 data, select the preferred network type.
  5. #284
    lol...to me works like before
    I have no problem with data connection on sim1
    Nubia Z7MAX
  6. #285
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    Bluetooth behaviour now is the same with 3.70 that with 3.67. It works well but after some time problem arises again. I've been playing music for almost two hours without issus but after stopping playing and resuming some minutes later problem with choppy playback started again.
    strange, I listened some albums in streaming with the pc (about 2 hours of music) and did not give me problems
    tomorrow I do other tests
    Nubia Z7MAX
  7. #286
    Oct 2013
    Quote Originariamente inviato da narutonote Visualizza il messaggio
    Yes now work,only sim 2 have data if switch to 1 not have data.
  8. #287
    Oct 2015
    You only need to replace the card 2 data type GSM, and then switch the card 1 data. Data exchange is slow, please be patient. Of course, the premise is that you do not use the telecommunications card.
  9. #288
    Aug 2015
    bluetooth problem remains....
  10. #289
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    Yes. I was also listening for two hours without problem. Stopped and resumed minutes later and the problem started again. It's quite strange. Perhaps some problem with buffer not flushed or so...
  11. #290
    umh maybe is a problem of the cm13
    there are other phones that have the same bug (so is not only baseband or phone related)
    https://www.reddit.com/r/cyanogenmod...th_on_gti9300/
    Ultima modifica di PaoloW8; 11-01-16 alle 18:25
    Nubia Z7MAX
