Pagina 33 di 50 primaprima ... 23313233343543 ... ultimoultimo
Visualizzazione dei risultati da 321 a 330 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #321
    Feb 2016
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    Look at BB72 ROM nubia Z7 thread. I remember there was a revert procedure for downgrade. But you can also install a clean official Lollipop build and nobody could tell you anything.
    Can someone please redirect me to the right page? I've been reading but google translate isn't helping.
    paolothlw8 I can just flash with nubia tools over cm 13 and I will have stock rom and recovery without conseq
    Sep 2015
    Hi Paolo,
    My phone frequently reboots just after having selected a sim to make a call using french provider's network.
    Lately, I have reinstalled your last ROM (v2) after a full (system, cache, dalvik cache) wipe but this didn't help. Can you or anyone give me some advice to make my phone work normally?
    Thanks in advance.
    Cheers
  4. #323
    link release V3 in first page
    Nubia Z7MAX
  5. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    BaSch83 (27-02-16),flasher (27-02-16),LiveMoto (27-02-16)
  6. #324
    Jun 2015
    Hello paolothlw8, please tell me how can i change the TWRP 2.8.6.0 to TWRP 3.0.0.0? With Rashr- Flashtool? And Thanks for Your Work.
    Ultima modifica di flasher; 27-02-16 alle 20:45
  7. #325
    Quote Originariamente inviato da flasher Visualizza il messaggio
    just flash the zip that I have prepared
    recovery_twrp_3.0.0.0_exfat.zip
    Nubia Z7MAX
  8. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    BaSch83 (28-02-16),flasher (27-02-16)
  9. #326
    Jun 2015
    Hello paolo, just flash in twrp 2.8.6.0?
  10. #327
    Sep 2015
    Hello paolothlw8, I still have issues with the use of the SIM cards. Just after having selected a card, the phone reboots but the phone still makes the call. This happens a couple of time in a day. Can you help? Thanks. Regards.
  11. #328
    Sep 2015
    That's how it worked for me
  12. Il seguente Utente ha ringraziato jadar per il post:
    flasher (02-03-16)
  13. #329
    Jun 2015
    Hello, i have extrem battery drain. Any idea why? The Phone needs in 4 hours 80% Battery.
  14. #330
    link release V4 in first page
    Nubia Z7MAX
  15. I seguenti 4 Utenti hanno ringraziato PaoloW8 per il post:
    BaSch83 (08-03-16),flasher (08-03-16),jadar (19-03-16),migel121 (08-03-16)
