Pagina 21 di 50 primaprima ... 11192021222331 ... ultimoultimo
Visualizzazione dei risultati da 201 a 210 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #201
    Oct 2015
    Ha, I almost forgot. From Beta1 beginning, insert the SD card name garbled, but will display SD card brand before Beta1.
    Beta2 fast pull switch failure. Even close down the shortcut, from the right side of the pull or open the shortcut. It's very annoying...
    Ultima modifica di narutonote; 09-12-15 alle 12:42
    Oct 2013
    Quote Originariamente inviato da LiveMoto Visualizza il messaggio
    After formatting the SD-card in Android 6.0 and return it to a state of "portable" it ceased to be read in TWRP. If you select SD-card recovery TWRP freezes.
    TWRP sees space on the sd-card, but when choosing a card in the section Restore permanently hangs. Mount does not work from a recovery.
    I tried to format the card to FAT32 and extFAT on the PC. Did not help.
    SD-Card is readable on a computer and in the CM12, but TWRP freezes and I can not make a backup or recover from it.
    Another SD card works in TWRP without problems. Her I have not formatted in Android 6.0. So the problem is in the SD-card.
    I have the same problem....How to read the memory card (SDCard) on CM13 without make format??
  4. #203
    Oct 2015
    Good morning, Paolo. I found ways to modify front-facing camera photo resolution size can be normal use front camera. But this is take temporary solution not effect a permanent cure method.
  5. #204
    Quote Originariamente inviato da narutonote Visualizza il messaggio
    I have already fixed this bug
    the only problem is that I have to upload the whole rom and not only a little fix
    ...so today (or tomorrow at the latest) I will upload the beta3
    Nubia Z7MAX
  6. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    flasher (10-12-15),narutonote (10-12-15)
  7. #205
    Oct 2015
    Thank you, Paolo. Thanks to you, we can experience the great CM13. Looking forward to your Beta3.
  8. #206
    Sep 2015
    Hello Paolo,
    I have installed beta2. Since then (because I travel much) I have lost my Wi-Fi connection and the phone is unable to scan Wi-Fi networks and connect to them
    Thanks for great job (and help to come &#128513
    Regards
  9. #207
    link beta3 and changelog in first page
    Nubia Z7MAX
  10. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    jadar (12-12-15),migel121 (11-12-15),narutonote (11-12-15)
  11. #208
    Sep 2015
    I can't find it, it stops to beta2
  12. I seguenti 2 Utenti hanno ringraziato Pstelios per il post:
    migel121 (11-12-15),PaoloW8 (11-12-15)
  13. #209
    Quote Originariamente inviato da Pstelios Visualizza il messaggio
    lol right....
    try now
    Nubia Z7MAX
  14. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    mai62 (11-12-15),migel121 (11-12-15)
  15. #210
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    Your private library has not been updated for a long time? When to upload? Thank you for your excellent ROM
