Pagina 38 di 50 primaprima ... 28363738394048 ... ultimoultimo
Visualizzazione dei risultati da 371 a 380 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #371
    Quote Originariamente inviato da LiveMoto Visualizza il messaggio
    Simple 3.5mm headphones (mini jack).
    you have tried with a different headphones ?
    Nubia Z7MAX
  2. Il seguente Utente ha ringraziato PaoloW8 per il post:
    LiveMoto (09-06-16)
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    No, but I'll try.
    4PDA community from Russia
  5. #373
    release V10 in first page
    Nubia Z7MAX
  6. I seguenti 4 Utenti hanno ringraziato PaoloW8 per il post:
    flasher (01-07-16),mai62 (01-07-16),pchatzop (04-07-16),stomiobeach (01-07-16)
  7. #374
    Feb 2016
    Nubia z7 max
    Thumbs up
    Thanks for your work
  8. #375
    Jul 2016
    Thank you very much for your awesome work, your roms are the reason I got this device in the first place(and I also got 2 more for my friends since I saw how smooth my phone was running with your cm13). Bluetooth music bug is finally fully fixed in release v10, tested it today. Hope you can compile more roms, like resurrection remix, or AOSPA. Also, one little question, is the phone capable of qualcomm fast charge? Could it be included with a kernel patch? Regards, and keep up the good work.
  9. #376
    Oct 2015
    Thank you very much for your hard work and dedication paolo, the only reason I haven't bought a new phone are these awesome updates.
  10. #377
    Jul 2016
    Hello again, i tried to build resurrection remix with your device tree, after a lot of tinkering everything was successful, rom built fine, but flashing the build just makes the phone stuck at the nubia logo. Is there something specific i should do to make it bootable? The compiled kernel (from your tree) works fine with your cm13 rel 10. Hope you can help! I am willing to bring some more flavors of android on this lovely phone, based on your awesome sources and hopefully learning and fixing some issues on my own.
    Ultima modifica di pchatzop; 22-07-16 alle 01:42
  11. #378
    Jul 2016
    I got it working. Resurrection remix for the z7 max BASED ON PAOLOW8'S SOURCES. I will test the rom first tilli deem it stable enough for release. I also have an idea for solving the bluetooth stuttering, i will try it and post the solution for paolo too. I just came up with a minor annoyance. Your latest ported nubiacamera app crashes when i switch to the front camera. That happened in other roms too, as well as on every marshmallow for the z7 mini(my friend owns the mini, i will build for him too). That app works well only on cm12.1 roms and your cm13, not my my newly build resurrection remix. Do you have any idea on how to fix it?
  12. #379
    rel v11 in first page
    Nubia Z7MAX
  13. Il seguente Utente ha ringraziato PaoloW8 per il post:
    mai62 (24-07-16)
  14. #380
    Quote Originariamente inviato da pchatzop Visualizza il messaggio
    for the front camera fix copy this file inside the directory frameworks/base/core/java/org/codeaurora/camera/ and recompile
    QCFace.java
    Nubia Z7MAX
  15. Il seguente Utente ha ringraziato PaoloW8 per il post:
    pchatzop (25-07-16)
