Pagina 4 di 50 primaprima ... 2345614 ... ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #31
    Nov 2015
    Good to know, thanks.
    BTW, someone in China has already modified you early alpha ROM ……
    Nov 2015
    boardconfig.mk
    TARGET_KERNEL_SOURCE := kernel/nubia/nx505j_mm
    TARGET_KERNEL_ARCH := arm
    TARGET_KERNEL_CONFIG := cm-nx505j_defconfig
    Kernel/nubia/nx505j_mm
    Boardconfig.mk
    This directory in this folder is not found in the file you provide.
  4. #33
    Nov 2015
    Are you uploaded to the cm13.0's GITHUB's adapter file complete?
  5. #34
    Quote Originariamente inviato da awssong Visualizza il messaggio
    boardconfig.mk
    Boardconfig.mk
    just change:
    codice:
    to
    codice:
    yes are complete
    Ultima modifica di PaoloW8; 15-11-15 alle 09:05
    Nubia Z7MAX
  6. #35
    Nov 2015
    local_manifests Directory content:
    <?xml version="1.0" encoding="UTF-8"?>
    <manifest>
    <project name="CyanogenMod/android_device_qcom_common" path="device/qcom/common" remote="github" revision="cm-13.0" />
    <project name="CyanogenMod/android_hardware_qcom_fm" path="hardware/qcom/fm" remote="github" revision="cm-13.0" />
    <project name="Christopher83/arm-cortex_a15-linux-gnueabihf-linaro_4.9" path="prebuilts/gcc/linux-x86/arm/arm-cortex_a15-linux-gnueabihf-linaro_4.9" remote="github" revision="master" />
    <project name="PaoloW8/android_device_nubia_nx505j" path="device/nubia/nx505j" remote="github" revision="cm13.0" />
    <project name="PaoloW8/android_vendor_nubia_nx505j" path="vendor/nubia/nx505j" remote="github" revision="cm13.0" />
    <project name="PaoloW8/android_kernel_nubia_nx505j" path="kernel/nubia/nx505j_mm" remote="github" revision="cm13.0" />
    </manifest>
    Right? Trouble you help me see, I sync source code, compiled in the first screen. Can not enter the system, thank you!
  7. #36
    Nov 2015
    Alpha4 for a long time?
    Do you have a compilation of tutorials? If finished, what documents need finished? In which directory?
  8. #37
    in local_manifest add:
    codice:
      <project name="CyanogenMod/android_external_stlport" path="external/stlport" remote="github" revision="cm-13.0" />
      <project name="CyanogenMod/android_external_sony_boringssl-compat" path="external/sony/boringssl-compat" remote="github" revision="cm-13.0" />
    resync and compile
    Nubia Z7MAX
  9. #38
    Nov 2015
    Is this part also need?
  10. #39
    sorry but I don't have any tutorial...only several years of experience
    when it ends the zip is in out/target/product/nx505j/cm13.0-xxxxxxxxxxx.zip
    Nubia Z7MAX
  11. #40
    yes, just add at your local_manifest the 2 line I wrote
    Nubia Z7MAX
