Pagina 14 di 50 primaprima ... 4121314151624 ... ultimoultimo
Visualizzazione dei risultati da 131 a 140 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #131
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    delete this line from your local_manifest
    Thanks!paolo
    Jun 2015
    Hello Paolo, thanks for work. Please tell me what means full wipe? Advanche wipe, check dalvik cache, system, data and cache? Or more. I have System issue behind flashing the open gapps. System.prozess has end. What is my issue?
  4. #133
    Quote Originariamente inviato da flasher Visualizza il messaggio
    yes, advanced wipe and select dalvik cache, system, data and cache.
    strange error, you have flashed the correct gapps ? (arm, 6.0)
    Nubia Z7MAX
  5. Il seguente Utente ha ringraziato PaoloW8 per il post:
    flasher (24-11-15)
  6. #134
    Jun 2015
    Paolo, first i have installed first CM 13 than reboot and behind the CM Wizard reboot to TWRP and than i flashed the (right) Gapps (from your Download).
    Now first i flashed the CM 13 new and the gapps without reboot between flash. Now is that right.
  7. #135
    Nov 2015
    I have same problem with Gapps installation on alpha6 that I have never encounterred from all ROMs that I had been flashed for the last few years.
  8. #136
    Jun 2015
    I don`t find the setting`s for the vibration. Where i find them?
  9. #137
    Jun 2015
    For the people they need Adway Blocker. Look in playstore at busybox from meefik. Install them and reboot. Then work Adway. Thanks at johnny8910 from XDA.
  10. Il seguente Utente ha ringraziato flasher per il post:
    inigoml (25-11-15)
  11. #138
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Yeah! It works!
    I've tested with another Busybox but no luck.
    Thank you, mate!
  12. #139
    May 2015
    Madrid, Spain
    Nubia z7 max
    Hi everybody.
    With Alpha6 I have experienced some issues. What about your experience?
    - Some random reboots (It appears that only related with GUI because it only takes some seconds to be operative again).
    - LTE for my primary line sometimes takes a lot of time to get signal or at least icon shows no signal.
    Thank you!
  13. #140
    Jun 2015
    Thanks go to johnny8910 from XDA.
