Pagina 5 di 50 primaprima ... 3456715 ... ultimoultimo
Visualizzazione dei risultati da 41 a 50 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #41
    Nov 2015
    Thank you very much!
    Nov 2015
    repo init -u git://github.com/CyanogenMod/android.git -b cm-13.0
    Do I have this sync command right?
  4. #43
    Quote Originariamente inviato da awssong Visualizza il messaggio
    this command is for initialize the repo, it is to be done only once
    for sync the source:
    repo sync
    Nubia Z7MAX
  5. #44
    Nov 2015
    thanks!CarbonROM What is its GitHub address? Is the time to initialize the warehouse.
    repo init -u "address" -b.....
  6. #45
    https://github.com/CarbonROM/android
    Nubia Z7MAX
  7. #46
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    Alpha4 what time is it?
  8. #47
    I'm compiling right now
    if all goes well this afternoon / evening
    Nubia Z7MAX
  9. Il seguente Utente ha ringraziato PaoloW8 per il post:
    migel121 (15-11-15)
  10. #48
    Nov 2015
    Thanks!paolo
  11. #49
    Nov 2015
    I am just curious, in average, how long you need to compile a CM ROM?
  12. #50
    Quote Originariamente inviato da owhk Visualizza il messaggio
    cm12.1 2 hours and 40 minutes
    cm13.0 1 hour and 50 minutes
    Ultima modifica di PaoloW8; 15-11-15 alle 11:32
    Nubia Z7MAX
