Pagina 6 di 50 primaprima ... 4567816 ... ultimoultimo
Visualizzazione dei risultati da 51 a 60 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #51
    Nov 2015
    Thanks for your info.
    My largest Windows based HR application so far takes me around 45 mins to compile.
    Nov 2015
    Alpha4 okay? We all look forward to it.
  4. #53
    Nov 2015
    Compile carbon12.1 Do you need to modify the GitHub file you provide?
  5. #54
    Quote Originariamente inviato da awssong Visualizza il messaggio
    no, with the latest sourcecode commit there is some problem to be fixed
    in my github the device tree is compatible only with CM
    for carbon or other rom you have to make some changes
    Nubia Z7MAX
  6. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (15-11-15),megthebest (15-11-15)
  7. #55
    Nov 2015
    I compiled a success this time, but China Mobile has no signal, I'm in the baseband version where the "unknown", which should change the place? Please PAOLO teach me, thank you very much!
  8. #56
    Nov 2015
    In the Z7MAX forum also has a friend encountered such a problem, did not find a solution, hoping to give support to PAOLO! Thank you
  9. #57
    the CM13 sources currently are messed up due to some patches included tonight
    now I'm uploading the alpha 4 that I have compiled yesterday
    Nubia Z7MAX
  10. #58
    link and changelog alpha4 in first page
    with this version I have added the compatibility with opengapps
    my advice is to switch to opengapps (no more problem with contact sync or any other gapps permission), unfortunately to do that you have to do a full wipe (with format system)
    Nubia Z7MAX
  11. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    jadar (16-11-15),LiveMoto (16-11-15),mai62 (15-11-15)
  12. #59
    Nov 2015
    Did you upload your new code? I see or alpha3? Compiled after the phenomenon of SIM card is still there. Could you please upload it? I see you update the firmware of the Nexus5, and you need to add the corresponding synchronization code in local_manifests? Code is what?
  13. #60
    Nov 2015
    Did you upload the source to the GITHUB? Waiting for you to upload! Thank you very much!
