Pagina 45 di 50 primaprima ... 354344454647 ... ultimoultimo
Visualizzazione dei risultati da 441 a 450 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #441
    Jul 2016
    Unfortunately, i cannot get it to work. I had already copied all those files, even updated the vendor makefile to include them(some new files like libFNVfbEngineHAL.so) and recompiled the rom, no dice. Still not able to connect to camera. Logcat says something about unable to get camera vendor metadata. Baseband and other blobs work fine. Thanks for helping, I'll just have to wait for your release i guess. How is the camera quality with the new blobs?
    Quote Originariamente inviato da pchatzop Visualizza il messaggio
    strange, in cm13 I only done this
    I also have ported the new nubia camera app (NubiaCamera_6.0_V6.0.0.85.2)
    for the quality I really don't know (maybe yes, a little improvement)....I never use the camera lol
    Nubia Z7MAX
  4. #443
    Jul 2016
    Maybe its a mistake somewhere in my part, and im kinda busy now to try and find it . I will use your fixed sources once you get it in github.
    I was mostly trying to get a unified kernel source for z7 mini and max, think i got it going,just need my friend with the mini to test it on. Will get it up soon, feel free to use whatever part you like since i manually updated it to 3.4.113(pretty boring task!).
  5. #444
    I have updated my github (cm13.0 branch) with the new 3.89 camera blobs, I also updated the adreno and drm blobs with the bacon version and the kernel with few security patch
    now I'm waiting for the november security patch before release the V15 rom zip.
    Nubia Z7MAX
  6. #445
    Jul 2016
    Thank you very much paolo, this worked perfectly. Merged all the changes successfully and camera works like a charm. Hope to see the new ported nubia camera apk soon! Just a little observation, i found that antutu performance is a little bit lower(about 56-57000) with the new changes, when it was about 59-60000 before. Could it be because of the OPO graphics blobs? it could also be the memory fixes in the linux kernel, because i think i got a lower RAM score than before(7700 when i got about 9500 before).
  7. #446
    release V15 in first page
    in the changelog there also is the link for the new nubia camera app
    Nubia Z7MAX
  8. Il seguente Utente ha ringraziato PaoloW8 per il post:
    brooklyn2006 (10-11-16)
  9. #447
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Quote Originariamente inviato da PaoloW8 Visualizza il messaggio
    Can you adopt new camera for CM12?
  10. #448
    Quote Originariamente inviato da brooklyn2006 Visualizza il messaggio
    you talk about the apk ?
    maybe yes but I don't know if works with the old camera blobs
    I'm thinking to release a new version of the cm12.1 with the new blobs and the source codes updated but I need some time to patch the kernel with the all security patch released in the last few months.
    tomorrow I will start to work on it
    Nubia Z7MAX
  11. Il seguente Utente ha ringraziato PaoloW8 per il post:
  12. #449
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    yes, I talk about apk.
    I tried to do the adaptation himself, but the front camera does not work. Back camera work fine.
  13. #450
    you use my cm12.1 or compiled by you/other ?
    I have ported the new apk and I tried with my cm12.1 and the front camera works
    you can find the apk for the cm12.1 here in the cm12.1 folder
    Nubia Z7MAX
