Utente del mese: megthebest con ben 44 Thanks ricevuti nell'ultimo mese
Pagina 35 di 50 primaprima ... 25333435363745 ... ultimoultimo
Visualizzazione dei risultati da 341 a 350 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #341
    Jul 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    maybe yes, I have not tried
    The first time I installed V5 after V4. Then I did a full wipe. On the Russian forum 4pda there are still people who complain about this problem.
    Jul 2015
    After I flash v4, do I still need to flash GApps, BaseBand, CM_Enable/Disable Cover, NubiaCamera etc.?
    Which of them have been included inside v4??
  4. #343
    Quote Originariamente inviato da patwwh Visualizza il messaggio
    none is included
    the baseband you need to flash only once (is independent of the used rom)
    you need to flash the cover zip (if you want to enable it) every time you upgrade the rom and gapps and nubiacamera only the first time
    Nubia Z7MAX
  5. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    LiveMoto (26-03-16),patwwh (28-03-16)
  6. #344
    Jul 2015
    Thanks for your confirmation.
    I found that your rom doesn't support Android's official function of encrypting device.
    I have done a little research, and guess this is a problem of CM13, and not exist in CM12 before, when used with TWRP 3.0.
    Could you help fix this problem or suggest a solution??
    Ultima modifica di patwwh; 26-03-16 alle 15:16
  7. #345
    Jul 2015
    I have made a research on above problem. We can solve partial problem by running below commands in TWRP, and then turn off all WiFi, Data, Kill Background Apps.
    The Encryption can then be started, .... but not really run.
    cat proc/partitions (to get data device. For Z7Max, it is /dev/block/mmcblk0p23)
    umount /data
    umount /sdcard
    tune2fs -l /dev/block/mmcblk0p23 (to get Block Count. For Z7Max, it is 6896635)
    e2fsck -f -p /dev/block/mmcblk0p23 (otherwise next Command would not work)
    resize2fs -f /dev/block/mmcblk0p23 6896595 (New Block Count = Old Block Count - 8, i.e.6896635-8-32, since my Z7Max has 32GB internal storage)
    e2fsck -f -p /dev/block/mmcblk0p23 (found a minor Error in filesystem which was corrected by this command)
  8. #346
    Jul 2015
    I have fully tested v4. Only find 2 majors bugs. One is reported above.
    Another is the wrong System Default of Language: English (Australia), due to hard coded.
    Although user can sometimes work around this problem, by manually selecting another language.
    However, some other hard-coded apps will read and use this Default setting, and give no choice for custom setting.
    Two hard-coded programs together cause a problem.
  9. #347
    if someone wants to try the V6 I put here the link
    You should no longer have the reboot in incoming calls
    I made several patches to the kernel and I also had to fix the FM radio because in these days in CM13 they replaced the app with the qualcomm version
    let me know if some problem (to me at the moment is working well), better if you make a backup first so you can go back without trouble
    cm-13.0-20160330-UNOFFICIAL-nx505j_relV6_test.zip
    md5: 8e0f0f75980ec56ed3aeb8423d044800
    Ultima modifica di PaoloW8; 30-03-16 alle 20:22
    Nubia Z7MAX
  10. Il seguente Utente ha ringraziato PaoloW8 per il post:
    jadar (01-04-16)
  11. #348
    Jul 2015
    I installed cm-13.0-20160330-UNOFFICIAL-nx505j_relV6_test.zip. I did wipe cache only. When receiving a call, everything is working fine. Thank you.
  12. Il seguente Utente ha ringraziato mai62 per il post:
    PaoloW8 (30-03-16)
  13. #349
    Quote Originariamente inviato da mai62 Visualizza il messaggio
    thanks
    also check if FM radio works
    Nubia Z7MAX
  14. #350
    Jul 2015
    thanks
    Yes. FM radio works.
  15. Il seguente Utente ha ringraziato mai62 per il post:
    PaoloW8 (30-03-16)
