Pagina 46 di 50 primaprima ... 364445464748 ... ultimoultimo
Visualizzazione dei risultati da 451 a 460 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #451
    Nov 2016
    Thank you Paolo for your great work! Have you noticed V15 does not work with Xposed? I saw someone reporting the same issue on another forum: boot animation stuck forever after any Xposed module is installed.
    Quote Originariamente inviato da expzte Visualizza il messaggio
    I stopped using Xposed long time ago
    on xda I saw the same issue reported on nexus 6 and xiaomi mi5 so maybe the current Xposed version is not full compatible with the android 6.0.1 November patch....just wait a new version
    Nubia Z7MAX
  4. #453
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Quote Originariamente inviato da PaoloW8 Visualizza il messaggio
    you use my cm12.1 or compiled by you/other ?
    I have ported the new apk and I tried with my cm12.1 and the front camera works
    The same problem - after switch to fron camera FC.
    I use my build, compiled on your config files, without any changes.
  5. #454
    Quote Originariamente inviato da brooklyn2006 Visualizza il messaggio
    I'm using the new 3.89 blobs and works
    right now I have updated my github so try to sync and recompile
    Nubia Z7MAX
  6. Il seguente Utente ha ringraziato PaoloW8 per il post:
    brooklyn2006 (11-11-16)
  7. #455
    Nov 2016
    on I saw the same issue reported on nexus 6 and xiaomi mi5 so maybe the current Xposed version is not full compatible with the android 6.0.1 November patch....just wait a new version
    Interesting I'm not an expert but I thought experts like Xposed. Would you like to share how you control app permission and wakeups between apps? I use Xprivacy and PreventRunning. Xprivacy is much better than the stock permission control. E.g. a fake location is provided to the app if you don't allow the app to access your location. And PreventRunning seems much easier and more effective than Greenify. Thanks.
  8. #456
    Jul 2016
  9. Il seguente Utente ha ringraziato pchatzop per il post:
    PaoloW8 (12-11-16)
  10. #457
    Quote Originariamente inviato da pchatzop Visualizza il messaggio
    done and it seems to works
    just download the little zip fix that I made and flash it without any wipe
    CM13.0_relV15_xposedfix.zip
    Nubia Z7MAX
  11. #458
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    With 3.89 blobs new camera work fine on CM12.1
  12. Il seguente Utente ha ringraziato brooklyn2006 per il post:
    PaoloW8 (13-11-16)
  13. #459
    ehehe nice
    Nubia Z7MAX
  14. #460
    Jul 2016
    Everything working much better in your new sources, thank you. After 3 months(since i used the OPO kernel sources for bluetooth) i got stuttering on bt playback again. It was an isolated incident and everything worked fine after a reboot, for more than 2 hours of playback(if i had to count, it happened once in a total of 30 hours of music playback). A took a look at the logcat while playing, and got an error about qcmediaplayer(music played fine, it just presented the error while changing tracks), and i remember that you commented it out in your rel v14 sources. Could it have some relevance to the issue?
