Pagina 36 di 50 primaprima ... 26343536373846 ... ultimoultimo
Visualizzazione dei risultati da 351 a 360 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #351
    link and changelog release V7 in first page
    Nubia Z7MAX
  2. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    flasher (10-04-16),inigoml (07-04-16),mai62 (06-04-16)
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Everything running without problems.
    Reboot when receiving a call has been fixed.
    Thank you, Paolo!
  5. #353
    Oct 2015
    when I make a call it disconnects after around 10 seconds and sometimes it disconnects after 30 seconds. I'm using V7 any idea what might cause this?
  6. #354
    Sep 2015
    The same issues happen on my phone. It frequently reboots as I try to make a call on both SIMS
    Envoyé de mon NX505J en utilisant Tapatalk
  7. #355
    Sep 2015
    Is it possible to downgrade the NX505J from Android 6.0 to Android 5.1?
    Thanks anyone for help
  8. #356
    Quote Originariamente inviato da jadar Visualizza il messaggio
    full wipe and flash what you want (cm12.1, stock or other)
    Nubia Z7MAX
  9. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    inigoml (11-05-16),jadar (25-04-16)
  10. #357
    Oct 2013
    Hi Paolo i wonder if you can port new stock Android 6.0 rom from nubia Z9 Max to nubia Z7 Max???
    Here is nubia Z9 Max Rom
    https://translate.googleusercontent....qr7BWDpsVw82mA
    If you want i can download the rom and upload to mega for you.
  11. #358
    Quote Originariamente inviato da tigreos Visualizza il messaggio
    no
    nubia Z9 use a 64 bit soc (qualcomm 810) so is impossible to port the firmware
    Nubia Z7MAX
  12. #359
    Oct 2013
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    no
    ...Anyway thank you again....
  13. #360
    Rel V8 in first page
    Nubia Z7MAX
  14. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    inigoml (11-05-16),mai62 (09-05-16)
