Pagina 7 di 50 primaprima ... 5678917 ... ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #61
    Nov 2015
    How about your code, I want to try it too. Any link to your works?
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    I did not find the possibility to change the DPI interface system.
    4PDA community from Russia
  4. #63
    Nov 2015
    I am running alpha 4 now, Facebook and a bank apps that was not working in alpha3 are working now, thanks.
    I just find out that I cannot save (write/modify) my external SD card, any suggestion?
  5. #64
    Quote Originariamente inviato da LiveMoto Visualizza il messaggio
    no, some features are not yet implemented
    Nubia Z7MAX
  6. #65
    Quote Originariamente inviato da owhk Visualizza il messaggio
    ehehe lol, this new system of managing the storage devices driving me crazy
    have you tried format the sd ?
    Nubia Z7MAX
  7. #66
    Nov 2015
    Yes I did format my 64GB SD card in alpha2, I also checked the platform.XML file for the external SD/media access right, it looks okay.
  8. #67
    I mean if you've tried to format with alpha4
    Nubia Z7MAX
  9. #68
    Nov 2015
    I have something like 60GB of data need to backup and restore if I have to reformat the SD card!
  10. #69
    Nov 2015
    I re sync the code you provide alpha 4, China Telecom, China Mobile is still no signal? How do you integrate the official baseband into the system? Can you tell me how to do it? Thank you
  11. #70
    Nov 2015
    I tried, or not, I do not know what caused the. Hope to get your help. My local_manifests content is: please give me directions. Thank you!
    <?xml version="1.0" encoding="UTF-8"?>
    <manifest>
    <project name="CyanogenMod/android_external_stlport" path="external/stlport" remote="github" revision="cm-13.0" />
    <project name="CyanogenMod/android_external_sony_boringssl-compat" path="external/sony/boringssl-compat" remote="github" revision="cm-13.0" />
    <project name="CyanogenMod/android_device_qcom_common" path="device/qcom/common" remote="github" revision="cm-13.0" />
    <project name="CyanogenMod/android_hardware_qcom_fm" path="hardware/qcom/fm" remote="github" revision="cm-13.0" />
    <project name="Christopher83/arm-cortex_a15-linux-gnueabihf-linaro_4.9" path="prebuilts/gcc/linux-x86/arm/arm-cortex_a15-linux-gnueabihf-linaro_4.9" remote="github" revision="master" />
    <project name="PaoloW8/android_device_nubia_nx505j" path="device/nubia/nx505j" remote="github" revision="cm13.0" />
    <project name="PaoloW8/android_vendor_nubia_nx505j" path="vendor/nubia/nx505j" remote="github" revision="cm13.0" />
    <project name="PaoloW8/android_kernel_nubia_nx505j" path="kernel/nubia/nx505j" remote="github" revision="cm13.0" />
    </manifest>
