Pagina 15 di 50 primaprima ... 5131415161725 ... ultimoultimo
Visualizzazione dei risultati da 141 a 150 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #141
    today I added the initial support to the smart cover
    for now turn on / off the display when you open / close the cover (better than nothing )
    I also added the FM radio app
    Nubia Z7MAX
  2. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (27-11-15),tigreos (26-11-15)
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    DPI set up the menu source code.
  5. #143
    Nov 2015
    When is your Alpha 7 released?
  6. #144
    some screenshot for the cover app
    https://www.androidiani.com/forum/mo...ml#post7229067
    It is strange because it is made for the HTC dotcover (search on google images if you do not know what is) so thanks to the author... but it works
    Quote Originariamente inviato da flasher Visualizza il messaggio
    For the people they need Adway Blocker. Look in playstore at busybox from meefik. Install them and reboot. Then work Adway. Thanks at johnny8910 from XDA.
    in the next release it is no longer needed, there is a fix for remount system in read/write
    Quote Originariamente inviato da awssong Visualizza il messaggio
    this afternoon
    Nubia Z7MAX
  7. Il seguente Utente ha ringraziato PaoloW8 per il post:
  8. #145
    Sep 2015
    this afternoon
    Why all those alphas? When will you call a version a beta version?
  9. #146
    Quote Originariamente inviato da jadar Visualizza il messaggio
    alpha, beta etc are just a word
    btw today I will release not the alpha7 but beta1
    Nubia Z7MAX
  10. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (27-11-15),flasher (27-11-15),jadar (27-11-15)
  11. #147
    Nov 2015
    Thanks!Paolo
  12. Il seguente Utente ha ringraziato awssong per il post:
    jadar (27-11-15)
  13. #148
    Sep 2015
    I suggest to call it c1, it will automatically become better
    Seriously now, keep the good work and name it as you're pleased
    Thank you
  14. Il seguente Utente ha ringraziato Pstelios per il post:
    jadar (27-11-15)
  15. #149
    Jun 2015
    Despite alpha: it is a great Rom. Thanks Paolo for your work.
  16. #150
    link and changelog beta1 in first page
    Nubia Z7MAX
  17. I seguenti 4 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (27-11-15),flasher (27-11-15),jadar (27-11-15),migel121 (27-11-15)
