Pagina 14 di 19 primaprima ... 41213141516 ... ultimoultimo
Visualizzazione dei risultati da 131 a 140 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #131
    Quote Originariamente inviato da brooklyn2006 Visualizza il messaggio
    Paolo, did you fix call disconnection?
    you have tried with different baseband ?
    I never had a disconnection in more than 2 months of use
    Nubia Z7MAX
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Quote Originariamente inviato da PaoloW8 Visualizza il messaggio
    yes of course.
    CM12.1 - work fine with any baseband
    CM13, CM14.1 - disconnected with any baseband.
    Some people on 4pda.ru wrote, that they helped switch off double tap display to turn on screen. For my did not help.
  4. #133
    yes of course.
    it's really strange, no one in the italian discussion reported this issue (in both cm13 and cm14 thread)
    so I ask...there are other people who have this problem ? write it here
    Nubia Z7MAX
  5. #134
    Aug 2015
    hi paolo
    when i use beta 4
    my hotspot open error
    display mode is not stable whatever i chose Automatic , off , day or night
    maybe i flash beat4 from beat 3 ,need wipe system and data part?
  6. #135
    Quote Originariamente inviato da zrnokia5230 Visualizza il messaggio
    hi paolo
    when i use beta 4
    no, you don't need full wipe
    btw, thanks for the report
    this morning I have fixed the hotspot issue, now I check the livedisplay
    in one or two days I will release the beta5
    edit:
    fixed the livedisplay issue
    Ultima modifica di PaoloW8; 14-12-16 alle 23:52
    Nubia Z7MAX
  7. Il seguente Utente ha ringraziato PaoloW8 per il post:
    mai62 (15-12-16)
  8. #136
    Aug 2015
    thanks.
    Will you add the status bar speed function and
    control super # icon in status bar shown or not
    in later versions?
  9. #137
    Jan 2015
    I have a problem with my z7 max.
    I lose the audio of the external hp.
    I must restart soft for the audio become.
    Have you a solution ?
    Thks
  10. #138
    beta5 link and changelog in first page
    Nubia Z7MAX
  11. #139
    Oct 2016
    Hi, Paolo, after updating to beta5, the compilation was failed. Do you know what's going wrong?
    build/kati/command.cc:182: error: undefined reference to 'Symbol::SetGlobalVar(Var*, bool) const'
    build/kati/command.cc:183: error: undefined reference to 'Symbol::SetGlobalVar(Var*, bool) const'
    clang++: error: linker command failed with exit code 1 (use -v to see invocation)
    make: *** [/home/seth/android/cm-14.1/out/host/linux-x86/bin/ckati] Error 1
  12. #140
    Quote Originariamente inviato da seth09 Visualizza il messaggio
    I don't know
    you have added this line in your local_manifest ? (if you didn't, add and resync)
    codice:
    <project name="CyanogenMod/android_packages_resources_devicesettings" path="packages/resources/devicesettings" remote="github" revision="cm-14.1" />
    you are doing a incremental compile ? delete everything inside the directory "out" and try again
    Ultima modifica di PaoloW8; 18-12-16 alle 09:25
    Nubia Z7MAX
