Pagina 15 di 19 primaprima ... 51314151617 ... ultimoultimo
Visualizzazione dei risultati da 141 a 150 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #141
    Oct 2016
    Quote Originariamente inviato da PaoloW8 Visualizza il messaggio
    I don't know
    you have added this line in your local_manifest ? (if you didn't, add and resync)
    codice:
    <project name="CyanogenMod/android_packages_resources_devicesettings" path="packages/resources/devicesettings" remote="github" revision="cm-14.1" />
    you are doing a incremental compile ? delete everything inside the directory "out" and try again
    I had to delete entire out/ to get the compiling to work. Thanks.
    Nov 2016
    LG G5 h850, Zte NubiaZ7 nx505j
    I got something weird after wiped internal storage and sd card I can't write files or create directory or delete things via mtp!
  4. #143
    Jan 2015
    Hi I found out where the problem comes from with the rear speaker but not finding any solutions.
    Make it during a phone call and alert only by itself and then the rear speaker no longer works.
    For this to happen you have to make a call in handsfree mode to reactivate the speaker and hang up.
    I tried everything to modify in the parameters but it is and always in alarm only of a call.
    Too bizarre
  5. #144
    Quote Originariamente inviato da Kokireg Visualizza il messaggio
    Too bizarre
    I did a fix yesterday, it seems to work
    try to flash this zip without any wipe
    CM14_acdbdata_mod_v2.zip
    Nubia Z7MAX
  6. #145
    Oct 2016
    yes, same problem on nx505j with CM14.0 and CM14.1
    I solved this issue some time ago by doing a little patch to the SensorManager
    apply this patch in frameworks/base: sensors.diff and recompile, after this the sensor should work
    Hi Paolo,
    Is it possible to fix this problem without patching cm14.1 code?
  7. #146
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Hi, Paolo!
    Do you plan make HTC dotcase support for CM14.1?
  8. #147
    Quote Originariamente inviato da seth09 Visualizza il messaggio
    Hi Paolo,
    probably yes but need some research/work to understand how to fix.
    Quote Originariamente inviato da brooklyn2006 Visualizza il messaggio
    Hi, Paolo!
    yes, next week I will do some test
    Nubia Z7MAX
  9. #148
    I can't edit the first message....again -.-
    cm14.1 beta6
    changelog:
    24/12/2016 beta6 (MD5: 706eda360572ef24db7f5b9d1384b725)
    • kernel: few fix
    • fix audio random muted
    • added network speed indicator on statusbar
    • sync cyanogen source code (24/12/2016)
    Merry Christmas to all
    Nubia Z7MAX
  10. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    mai62 (25-12-16),migel121 (26-12-16)
  11. #149
    Nubia Z7MAX
  12. #150
    Aug 2015
    Merry Christmas
