Pagina 7 di 19 primaprima ... 5678917 ... ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #61
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    not yet, the sources are still incomplete
    1、out/target/product/nx505j/gen/SHARED_LIBRARIES/librilutils_intermediates/proto/hardware/ril-caf/librilutils/proto/sap-api.pb.h copyto
    hardware/ril/librilutils/proto 目录下
    然后修改hardware/ril-caf/libril/RilSapSocket.h里面的
    #include <hardware/ril/librilutils/proto/sap-api.pb.h>为
    #include </home/syai2012/rom/aicp7/hardware/ril/librilutils/proto/sap-api.pb.h>
    修改hardware/ril-caf/libril/rilSocketQueue.h里面的
    2、更改kernel/nubia/nx505j/arch/arm/boot/dts 为dtbs
    3、修改:nx505j.mk
    PRODUCT_PACKAGES += \
    FM2 \
    libqcomfm_jni \
    #qcom.fmradio
    4、修改packages/apps/Settings/src/com/android/settings/DeviceInfoSettings.java
    增加
    private static final String KEY_SYSTEM_UPDATE_SETTINGS = "system_update_settings";
    private static final String KEY_UPDATE_SETTING = "additional_system_update_settings";
    Ultima modifica di awssong; 28-10-16 alle 17:22
    Nov 2015
    ERROR: /home/syai2012/rom/aicp7/packages/apps/Settings/src/com/android/settings/DeviceInfoSettings.java:198: KEY_SYSTEM_UPDATE_SETTINGS cannot be resolved to a variable
    ERROR: /home/syai2012/rom/aicp7/packages/apps/Settings/src/com/android/settings/DeviceInfoSettings.java:202: KEY_SYSTEM_UPDATE_SETTINGS cannot be resolved to a variable
    ERROR: /home/syai2012/rom/aicp7/packages/apps/Settings/src/com/android/settings/DeviceInfoSettings.java:206: KEY_UPDATE_SETTING cannot be resolved to a variable
    ERROR: /home/syai2012/rom/aicp7/packages/apps/Settings/src/com/android/settings/DeviceInfoSettings.java:366: KEY_SYSTEM_UPDATE_SETTINGS cannot be resolved to a variable
    ERROR: /home/syai2012/rom/aicp7/packages/apps/Settings/src/com/android/settings/DeviceInfoSettings.java:371: The method ciActionOnSysUpdate(PersistableBundle) is undefined for the type DeviceInfoSettings
    [ 3% 161/4518] ----- Making recovery ramdisk ------
    Copying baseline ramdisk...
    Modifying ramdisk contents...
    ----- Making uncompressed recovery ramdisk ------
    [ 3% 161/4518] target SharedLib: libq...ls_intermediates/LINKED/libqdutils.so)
    ninja: build stopped: subcommand failed.
    build/core/ninja.mk:151: recipe for target 'ninja_wrapper' failed
  4. #63
    Nov 2015
    this morning I saw that they started working on CM14.1 (android 7.1)
    I'm downloading the source codes
    AICP7.1 Successfully compiled.
    链接:http://pan.baidu.com/s/1cklcey 密码:ifgn
  5. #64
    Jul 2015
    In different applications on CM14 I was faced with such a situation as on the picture. I clicked on the photo icon and is strange window appears. Then I can't do anything. I can only kill the app. Maybe someone knows what it is? Thank you.
    Jul 2015
    Quote Originariamente inviato da awssong Visualizza il messaggio
    Thank you for your work. But I can't download the files from pan.baidu.com
  7. #66
    Nov 2015
    Quote Originariamente inviato da mai62 Visualizza il messaggio
    I have uploaded OK, you can download the
  8. #67
    Nov 2015
    Which version are you? Where to download?
  9. #68
    Jul 2015
    I try download aicp_nx505j_n-12.1-UNOFFICIAL-20161028.zip.
    BaiduNetdisk requires registration with a Chinese phone number.
  10. #69
    Nov 2015
    https://mega.nz/#F!Qt8UgbbJ!7TKiwdSuMfMjCmHVWrA7mw
  11. #70
    Jul 2015
    Thank you. I downloaded your file successfully. Tomorrow I'll try to flash. Now we have 4:00 night.
