Pagina 6 di 19 primaprima ... 4567816 ... ultimoultimo
Visualizzazione dei risultati da 51 a 60 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #51
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    Now I using Ubuntu 16.10 but I also have used Ubuntu 16.04 and manjaro without any problem
    I just installed this package:
    codice:
    sudo apt-get install git ccache automake lzop bison gperf build-essential zip curl zlib1g-dev zlib1g-dev:i386 g++-multilib python-networkx libxml2-utils bzip2 libbz2-dev libbz2-1.0 libghc-bzlib-dev squashfs-tools pngcrush schedtool dpkg-dev liblz4-tool make optipng maven openjdk-8-jdk
    from this guide: [GUIDE] How to Setup Ubuntu 16.04 LTS Xenial Xerus for Compiling Android ROMs
    Thanks!paolo
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    I still have no problem with proximity sensor...
    anyone have this problem with the sensor ?
    in camera I also have no problem to switch from video/photo mode
    you have already tried to reflash the rom with a full wipe ?
    After full wipe video recording work fine!
  4. #53
    link alpha4 in first page
    Nubia Z7MAX
  5. Il seguente Utente ha ringraziato PaoloW8 per il post:
    mai62 (25-10-16)
  6. #54
    this morning I saw that they started working on CM14.1 (android 7.1)
    I'm downloading the source codes
    Nubia Z7MAX
  7. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (26-10-16),mai62 (26-10-16)
  8. #55
    Aug 2015
    excellent job !
  9. #56
    Nov 2015
    I am compiling AICP7.1, I do not know will not be reported, SUDAROM on the wrong.
    Checking build tools versions...
    build/core/binary.mk:1230: external/deqp/Android.mk: libdeqp: Unused source files: \
    build/core/binary.mk:1230: external/pdfium/third_party/pdfiumbigint.mk: libpdfiumbigint: Unused source files: bigint/BigInteger.cc bigint/BigIntegerUtils.cc bigint/BigUnsigned.cc bigint/BigUnsignedInABase.cc
    external/skia/dm/Android.mk:653: frameworks/base/libs/hwui/hwui_static_deps.mk: No such file or directory
    build/core/ninja.mk:166: recipe for target '/home/syai2012/rom/suda3/out/build-sm_nx505j.ninja' failed
    make: *** [/home/syai2012/rom/suda3/out/build-sm_nx505j.ninja] Error 1
    #### make failed to build some targets (01:50 (mm:ss)) ####
    WHY?
  10. #57
    I don't know
    I never tried this rom
    I think the error is here
    codice:
    maybe some source codes are missing
    Nubia Z7MAX
  11. #58
    Nov 2015
    Have you compiled the 7.1?
  12. #59
    Quote Originariamente inviato da awssong Visualizza il messaggio
    not yet, the sources are still incomplete
    Nubia Z7MAX
  13. Il seguente Utente ha ringraziato PaoloW8 per il post:
    brooklyn2006 (28-10-16)
  14. #60
    Nov 2015
    Yes, AICP and SUDA compiled into the back also reported the wrong.
    make: Leaving directory '/home/syai2012/rom/suda3/kernel/nubia/nx505j'
    Building DTBs
    make: Entering directory '/home/syai2012/rom/suda3/kernel/nubia/nx505j'
    /home/syai2012/rom/suda3/kernel/nubia/nx505j/arch/arm/boot/Makefile:31: mhx
    make[2]: Nothing to be done for 'arch/arm/boot/dtbs'.
    Kernel Modules not enabled
    ninja: build stopped: subcommand failed.
    build/core/ninja.mk:151: recipe for target 'ninja_wrapper' failed
    make: *** [ninja_wrapper] Error 1
