Pagina 1645 di 1789 primaprima ... 645114515451595163516431644164516461647165516951745 ... ultimoultimo
Visualizzazione dei risultati da 16,441 a 16,450 su 17884
Jiayu S3 - Modding
  1. #16441
    Androidiano VIP L'avatar di Bertus
    Trieste
    Poco F2 pro 6GB / 128GB
    Ringraziato 1,045 volte in 638 Posts
    Aggiornamento ROM 7.1.2 Stable 13 Unofficial LineageOS 14.1 by Sandstrangers
    Changelog
    Removed all optimization flags;
    Dexpreopt is back again;
    Removed some stuff from libart.so which caused apps fc;
    Kernel built with gcc 4.9.4 instead of 7.1;
    HW audiocodecs included.
    Download link: https://forum.xda-developers.com/dev...t/dl/?id=26501
    Download link TWRP: https://forum.xda-developers.com/dev...t/dl/?id=25278
    Poco F2 pro (Global) 6GB / 128GB ROM Stock MIUI 13.0.8.0 e Android 12 - Schede SIM WindTre (Dati) e Tiscali
    ....... se non si può "smanettare" non è bello ... se è tutto pronto non mi piace !
    Quote Originariamente inviato da giopoli Visualizza il messaggio
    Jiayu S3 (mt6752) - madOS v1.2 - Android 7.1.2 - 2017-08-19
    M.A.D·Sabato 19 agosto 2017
    Changelog:
    Patch Level: August 2017
    Kernel version 3.10.107
    Wifi improvements
    Fixed substratum issues
    New feature for showing charging current & voltage on lockscreen
    Added F2FS support
    Reworked MTK RIL implementation
    Some more improvements
    FAQ: https://forum.xda-developers.com/sho...26&postcount=2
    Download:
    ROM: https://www.androidfilehost.com/?fid=961840155545589805
    TWRP: https://www.androidfilehost.com/?fid=889764386195902349
    Google Apps: Please choose: arm64, Android 7.1, pico or nano version. Other packages are said to be causing issues!
    The Open GApps Project
    Install Instructions/Support/Information:
    https://forum.xda-developers.com/jia...yu-s3-t3451923
    parli di questo ?
    @Bertus
    Questa ROM M.A.D OS 1.2 e la ROM M.A.D. Build 13 postata nei primi post sono la stessa ROM?
  4. #16443
    Senior Droid L'avatar di michiamanoLULUaccent
    Nov 2013
    Ringraziato 85 volte in 69 Posts
    Dalla Stable 11 alla Stable 13 LineageOS, quali wipe per non dover reinstallare tutto? Cache Partition e Dalvik Cache?
    Ho anche rotato il mio nuovo gioiellino e sto facendo un po' di confusione tra l'uno e l'altro
    Ultima modifica di michiamanoLULUaccent; 03-09-17 alle 00:13
    Oneplus 5 e 7T soddisfatta
  5. #16444
    Trieste
    @Bertus
    E' la stessa ROM
    Quote Originariamente inviato da michiamanoLULUaccent
    Nella versione 12 sono state fatte delle modifiche profonde... conviene fare tutti i Wipe e Format Data SD interna
    Ultima modifica di Bertus; 03-09-17 alle 08:01
  6. #16445
    Jun 2016
    Trieste
    S3 ADV e PRO
    Non riesco a ripristinare i dati e le app da Titanium. Non mi riconosce i backup. Dove trovo le indicazioni su come fare? Grazie
    Inviato dal mio JY-S3 usando Androidiani App
  7. #16446
    Feb 2015
    Molti , non li ricordo più...
    Quote Originariamente inviato da di10pn Visualizza il messaggio
    Prova a dare un'occhiata a questo thread :
    https://www.androidiani.com/forum/mo...per-tutti.html
    regolamento del forum
    Beno Fignon
    Goya
    George Santayana
  8. Il seguente Utente ha ringraziato Stahl per il post:
    di10pn (03-09-17)
  9. #16447
    Nov 2013
    Il gruppo M.A.D ha pubblicato questa nota :
    Buon giorno,
    dopo aver aggiornato a questa versione con i soli wipe data, dalvik e cahe la rom quando la riaccendo non trova le sim.
    A volte devo staccare la batteria e funziona dopo riavvio oppure devo fare un wipe di dalvik e cache.
    Ora sono tornato alla precedente.
    A voi è capitato?
  10. #16448
    Trieste
    Quote Originariamente inviato da codicem Visualizza il messaggio
    Buon giorno,
    A voi è capitato?
    In questo caso ti consiglio un bel Flashtool della LL, in modo da pulire tutto e rifare le partizioni, e reinstallare la ROM con la TWRP consigliata da MadOS
  11. #16449
    Androidiano VIP L'avatar di metrino
    Jiayu S3A (JY-S3S)
    Ringraziato 1,301 volte in 792 Posts
    A volte capita che ci metta un po', almeno nel mio caso. La precedente release faceva partire il riconoscimento del modulo SIM dopo diversi secondi, l'ultima versione invece quasi subito nel 90% dei casi.
    Ho cmq la sensazione che chi abbia fatto casino in passato (me compreso) con la NVRAM abbia poi perso qualcosa che non è stato più possibile ripristinare.
    Passare dalla LL 5.1 da risultati parziali, nel senso che funziona quasi sempre ma non sembra più come prima.
    Xiaomi Mi 9 SE 128GB (ROM 10.2.5 global EEA)
  12. #16450
    Androidiano L'avatar di sweetmanit
    Ringraziato 38 volte in 32 Posts
    buonasera monto la rom Jiayu S3 (mt6752) - madOS v1.2 - Android 7.1.2 - 2017-08-19 installato xposed ma non riesco ad installare GravityBox_Nougat_7.0.0-alpha-01.apk. quando avvio l'installazione il tasto in basso a dx "installa" non risponde mentre l'altro "annulla" si. Qualcuno saprebbe dire il perchè? Grazie
