Pagina 35 di 99 primaprima ... 2533343536374585 ... ultimoultimo
Visualizzazione dei risultati da 341 a 350 su 982
[UFFICIALE] Viber | Info, Dubbi e Domande
  1. #341
    Quote Originariamente inviato da Viber Visualizza il messaggio
    Ciao,
    Si tratta di un rappresentante ufficiale di Viber - mi scusi, io scrivere in inglese:
    Can you please explain the problems in more details so we can try and offer a solution?
    Thanks
    sorry
    my friend said to me that she shares her position on map updated every moment in chat box...i cannot to do this thing...why?
    then
    whwn i use wifi i don't receive messages...only with 3g connection...why?
    Androidiano L'avatar di Viber
    Ringraziato 28 volte in 28 Posts
    About the map question - I am still not sure I fully understand the problem. Viber can send location inside Viber messages. But this location is not an "online location", it is only the location that was relevant to the moment when the message was sent. If you friend sees her position on the map constantly changing, then this has nothing to do with Viber really It's probably an external app, or the regular Google services...
    About the problem on WiFi - the WiFi network you are using might be blocking Viber's ports. Try this:
    1. First, please try uninstalling and reinstalling Viber when connected to different WiFi networks. Does it work now?
    2. Also, please make sure the following ports are enabled on your routers or firewalls:
    TCP: 5242 + 4244
    UDP: 5243 + 9785
    (if you are not sure how to enable ports, contact your router manufacturer)
  4. #343
    Thanks a lot
    Now everything goes right
  5. #344
    Quote Originariamente inviato da beppespeed Visualizza il messaggio
    Thanks a lot
    We are happy to help
    Please feel free to let us know if you have any other questions in the future.
  6. #345
    @BlackFritz -
    Hmm... strange issue.
    What Android version do you have? Is it a Custom ROM?
    Also, are you sure your C2DM service is working?
    The version of android is the 4.0.3, it isn't a custom ROM.
    What is the C2DM service? How I can see if it is working properly?
    HTC Sensation - Android Ice Cream Sandwich 4.0.3 + Nova launcher
    Nexus 7 32GB - Android Jelly Bean 4.2.2
  7. #346
    C2DM is a service that pops up notification messages upon events, run by Google's servers.
    Generally, if you have a Gmail account configured on your phone, C2DM should automatically be active.
    Please try uninstalling Viber then reinstall (note that this will cause the deletion of your current Viber message history). If the problem persists after that, please use this direct link to report the problem to our support team: Your ticket details | Viber Support
  8. #347
    ok, thank you for your help.
  9. #348
    My pleasure.
    If you need anything else, please let me know
  10. #349
    Androidiano VIP L'avatar di gladiatore69
    bologna
    Galaxy S5 Galaxy S4mini Tab3
    Ringraziato 40 volte in 36 Posts
    ma anche a voi con ics sul samsung 2 non compaiono i contatti nella rubrica?
  11. #350
    Quote Originariamente inviato da gladiatore69 Visualizza il messaggio
    Do you mean that your Viber contact list is empty on your ICS ?
