Pagina 41 di 268 primaprima ... 3139404142435191141 ... ultimoultimo
Visualizzazione dei risultati da 401 a 410 su 2678
[ROM] [AOKP] Android Open Kang Project 4.0.4 - BUILD 36 - MIL 5
  1. #401
    Senior Droid L'avatar di alexdesire
    Jul 2010
    Galaxy S III
    Ringraziato 91 volte in 83 Posts
    Changelog build 21
    change log
    quad lockscreen now uses awesome layout from b19
    slight ROM Control overhaul -- new icons from kwesley snipes and included some descriptions
    added ability to change nav bar button transparency
    added ability to change nav bar glow animation time (quick glow mod as some people call it)
    added option for large menu button (originally seen in RootzBoat, thanks xoomdev!)
    you can also remove the original menu buttons on the left/right, be sure to do that, it's in Menu location
    nav buttons should space out better on higher LCD densities, while still looking good on stock (also sizes now same as stock)
    should have fixed the hide nav bar option (let me know if it's still broken, works great for me)
    lockscreen should be quick again
    lockscreen will have default camera/unlock shortcuts IF YOU HAVENT SET THEM BEFORE
    fixed nasty volume bug some people were experiencing -- also improved stability of hold to skip while screen off (won't wake your screen anymore)
    horizontal task switcher layout updated
    Power Saver shouldn't touch anything while you're on a phone call now
    misc fixes (clock not updating, hopefully, battery bar disappearing in nav bar, etc)
    using CM squisher with build now, adds about 21024*the amount of butter we had previously
    optimizes all APKs/images
    enabled full hardware*acceleration*in galaxy nexus builds to fix quardrantlololololololol
    updated Contacts app (including all latest T9 fixes from CM)
    updated Nova Launcher to b13
    tablets: including Trebuchet launcher instead of Nova for you guys
    p4wifi: removed device assert when compiling from source (easier for me, easier for you)
    That's it I think! Grab yours from the builds section to the left!
    Mica male. Un bel changelog .
    Galaxy S III: S4 Revolution v6.0
    PIsKeLL0
    Ti apre in automatico la casella email per l'invio in automatico del BUG riscontrato! invialo
    Quote Originariamente inviato da simone87stilo Visualizza il messaggio
    Provando la rom ho trovato un piccolo bug penso. In pratica se lascio in cell in stand by quando vado per sbloccare la tastiera questa si blocca reglarmente ma il cell vibra e si apre in automatico una bozza di gmail con scritto questo. Non lo fa sempre o spesso mi é successo 3 volte finora. Cosa può essere?
    Inviato dal mio Galaxy Nexus usando Tapatalk
  4. #403
    Androidiano VIP L'avatar di enricoandreoli
    Sep 2010
    Mirandola (MO)
    Non ho uno smartphone
    Ringraziato 117 volte in 100 Posts
    UPDATE
    Build 21 rilasciata, download al solito posto, ricordatevi le gapps (bartman se ne scrivi una delle tue giuro che ti vengo a trovare con un mazzo di rose <3 )
    Caporedattore di Androidiani.com
    Google e il tasto cerca sono i vostri migliori amici
  5. #404
    Androidiano VIP L'avatar di matiu
    Apr 2009
    Rimini
    Ringraziato 122 volte in 116 Posts
    per il momento rimango sulla foxhound, era da troppo tempo che dovevo provarla a fondo
    Aspetto la milestone 3, sperando poi che inserisca la possibilità di rendere più trasparente la status bar
    Non rispondo a messaggi privati!
    Le domande fatele sul forum.
  6. #405
    Sep 2010
    Mirandola (MO)
    Non si tratta di un bug, è una funzione della ROM. In pratica a te sembra di premere solo il tasto di sblocco, ma invece accidentalmente premi anche il tasto vol giu, quindi genera uno screenshot e dato che sei nel lockscreen genera anche un file di log. Poi ti chiede ovviamente cosa farne, si vede che te hai impostato di inviarlo automaticamente via email, ma non te ne fai assolutamente niente a meno che tu non voglia leggertelo tutto
  7. Il seguente Utente ha ringraziato enricoandreoli per il post:
    simone87stilo (27-01-12)
  8. #406
    ragazzi domanda magari un pò fuori tema....
    ogni volta che flasho una nuova build faccio i vari backup e restore direttamente dalla recovery... col risultato che ho quasi 10 backup XD .... ma come si fa a cancellarli?
  9. #407
    Androidiano L'avatar di ars3n
    Napoli
    Galaxy nexus
    Aaah ecco! Ora ho capito! anche a me è capitato svariate volte e mi ero accorto che capitava quando la mattina nel dormiveglia per sbloccarlo premevo nn solo il tasto di sblocco ma anke quelli del volume xD ! Svelato l arcano
    DEVICE: Google Samsung Galaxy NeXus 16 GB
    ROM: [AOSP] Android Open Kang Project 4.0.4
    KERNEL: Franco Kernel |4.0.4| # 174
    RECOVERY: ClockworkMod 5.5.0.2
    Google Experience
  10. #408
    Napoli
    Galaxy nexus
    Quote Originariamente inviato da AirGT Visualizza il messaggio
    Un qualsiasi gestore file --> clockworkmod --> backup ed elimini la cartella di backup che ti interessa!
    Ultima modifica di ars3n; 27-01-12 alle 12:28
    Google Experience
  11. #409
    Quote Originariamente inviato da ars3n Visualizza il messaggio
    grazie mille.... un pò di spazio liberato ehehehe
  12. #410
    Androidiano VIP L'avatar di simone87stilo
    Pontecchio Polesine (ROVIGO)
    LG G4
    Ringraziato 187 volte in 172 Posts
    Quote Originariamente inviato da enricoandreoli Visualizza il messaggio
    Ti rin grazio della spiegazione! In effetti ho provato e succede se premo volume giu e sblocca Bè meglio che non sia nessun bug dai! E' uscita la build 21 chi l'ha provata cosa ne penso? Io tutt'ora ho la build20 e mi trovo bene non vorrei cambiarla subito
    Se il mio aiuto è servito, un click su "Thanks" è sempre gradito!
