Utente del giorno: bluemask con ben 6 Thanks ricevuti nelle ultime 24 ore
Pagina 1 di 14 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 132
!!_[ROM]_LeeDrOiD_HD_!!
    Androidiano VIP L'avatar di adonis
    Nov 2009
    Samsung Galaxy S6 Flat
    Ringraziato 224 volte in 141 Posts
    Talking
    Ecco a voi questa bellissima Rom
    Ho letto vari post su XDA e molti dicono che è stupenda alla pari dellla rev "forse" anche migliore, per vedere se è vero propio ora l'ho installata sul mio DHD vi terro aggiornati con i risultati da me ottenuti
    What you get:
    * Base Android 2.2.1 - Official HTC RUU 1.72.405.3
    * You will NOT loose root or S-off...
    * Unsecured boot.img with ADB Remount
    * De-odexed & Zipaligned
    * HEUGE BATTERY IMPROVMENT!!
    * Kernel - LeeDrOiD Ace V2.2.2 - 2.6.32.29 (based on lates HTC source) LeeDrOiD@GitHub
    * Available CPU governors - On Demand, Performance, Conservative, Powersave, Userspace, Smartass & Interactive << (If running benchmarks :rolleyes; , switch to performance.. I would recommend using Interactive or Smartass for day to day usage)
    * Slightly Undervolted with an OPTIONAL OC up to 1804MHz using Set CPU, free for XDA members
    * Default CPU config = Smartass governor @ 245MHz - 1036MHz (only 12MHz above stock)
    * Increased WiFi Performance whilst "sleeping".
    * BFQ, CFQ & Deadline I/O Scheduler's
    * GPU+ mod (Improved 2D & 3D Graphics performance)
    * Improved WiFi Driver & PM = Fast (in sleep )
    * 20% audio boost across all outputs 25% main speaker
    * SLQB Memory allocator
    * CIFS support & Manager
    * Open VPN
    * Optional A2SD+Patch (move apps & dalvik cache to an ext partition on your MicroSD)
    * Rooted with Superuser permissions
    * Busybox 1.18.1
    * Nano command-line text editor support
    * Bash command shell support
    * /data/app/ zipaligned on boot (Improved RAM performance)
    * Ram Optimizations
    * Fully optimized framework
    * Reboot options in power menu Normal/Bootloader/Recovery/Hot Reboot (thanks to snq-)
    * Improved auto brightness values
    * Clean, Fast & Stable!
    * Browser Optimizations
    * Increased Dalvik-VM Heap size
    * Huge APN List
    * Custom LeeDrOiD Bios Boot animation
    * Cusom LeeDrOiD Locales & Language support
    * Minor UI Tweaks
    * Semi transparent app drawer & notification pull down
    * Titanium Backup & Rom manager
    * HTC Notes, Coin & Sand timer widgets
    * Voice Dialer (working with Bluetooth)
    * AD-free & hosts (Updated & working)
    * Spare parts (advanced configuration tool)
    * Genie News & Weather widget
    * Launcher2 (Optional Stock android launcher)
    * Fancy widget
    * Android market V2.3.3
    * Voice Search V2.1.1
    * Adobe Flash Player V10.1.106.16
    * Google Maps V5.0.0
    * Facebook V1.5.0
    * Updated Gmail V2.3.4.1
    * YouTube 2.1.6
    * R2D2
    * Clear default home app
    * Lots of performance & stability boosts!
    * Supported Languages: English, Czech, German, Espanol, French, Italian, Dutch, Polish, Russian, Norwegian, Korean, Greek, Turkish, Swedish, Danish, Portuguese, Finnish, Thai, Korean, Vietnamese, Chinese, Japanese, Portuguese, Croatian. < All tested! (some locals may only be partial as they will not be coded into all applications)
    LeeDrOiD HD V2.2.2 FULL ROM
    * * To be flashed with CWM 2xxxx
    * Kernel - Updated LeeDrOiD Kernel V2.2.2
    * Kernel - Re-based on official HTC 2.2.1 source
    * Kernel - Updated video drivers
    * Kernel - Updated WiFi Drivers
    * Kernel - Updated prox sensor drivers
    * Kernel - Optomised cpu table & voltages
    * Kernel - Max OC @1.8Ghz (1036Mhz Default)
    * Kernel - Deadline IO shed as default
    * Kernel - SLQB memory allocator as default
    * Kernel - 20% audio boost across all outputs 25% main speaker
    * Kernel - Increased GPU memory allocation
    * Reverted to stock 1.72 Video decoder (lib.so)
    * Default install location set to internal (1)
    * GPS tweaked
    * Background Speed tweaks
    * Youtube & Video issues fully resolved!
    * Fixed Adobe reader FC's
    * Updated adfree hosts
    * Updated Android market V2.3.3
    * Updated Twitter V2.0.1
    * Updated Titanium backup
    * Updated Rom Manager
    * Cleaned up old obsolete files
    * Added LeeDrOiD No SeNsE Patch
    Recommended Radio version
    12.28e.60.140fU_26.04.02.17_M2
    DOWNLOAD LeeDrOiD HD V2.2.2
    DOWNLOAD LeeDrOiD V2.2.7 Custom Kernel
  2. I seguenti 3 Utenti hanno ringraziato adonis per il post:
    gerrydream (02-03-11),katosalento (07-03-11),skokko76 (18-03-11)
    Nov 2009
    Riservato...
  5. Il seguente Utente ha ringraziato adonis per il post:
  6. #3
    Nov 2009
    Beh gia dal bellisimo boot si deduce che sia un'ottima ROM c'ha un'animazione molto bella =), La Rom è super veloce il Touch Screen è sensibilissimo, nessun lag nel scrool dei prog, l'interfaccia c'ha gia delle simpatiche animazzioni, il segnale del Wi-FI è molto buono stessa cosa per il segnale delle chiamate, e ancora in fase di testing ma fino ad ora mi ha veramente sorpreso.
  7. #4
    Androidiano VIP L'avatar di nexus76
    Mar 2010
    come kernel cosa ha quello custom rispetto a quello di default?
  8. #5
    Nov 2009
    Quote Originariamente inviato da nexus76 Visualizza il messaggio
    * More CPU voltage tweaks for optimal performance
    * Fixed missing entry in CPU table
    * Rolled back config to save power
    * Standby drain 1-4mV
    * NuTtEr - Max OC 2016MHz
    * NuTtEr - Default I/O Sched bfq
    * NuTtEr - Increased ALL audio levels by 20% (still nice and clear )
    Queste sono le caratteristiche
  9. #6
    Mar 2010
    adonis, tra il custom kernel e questo quale reputi migliore?
    https://www.androidiani.com/forum/ht...husiasts_.html
  10. #7
    Nov 2009
    Il kernel postato da me in quel tread è ottimo, pero prima ti consiglio di fare cosi allora prima di tutto lascia il kernel di base e testalo come lo sto tesando anche io 2,3 gg vedi se c'ha un'ottima stabilita/prestazzioni/autonomia se ti sembra che vada bene non cambiarlo se invece non ti convince priva prima a mettere sempre questo della leedroid se anche questo non ti convince allora metti quello postato da me nell'altro thread, per ogni cosa basta chedere spero che ti sia stato d'aiuto ^_^
  11. #8
    Mar 2010
    ok, grazie
  12. #9
    Nov 2009
    ok, grazie
    Per non intasare il topic per ringraziare usa il tasto grazie ( Thanks)
  13. #10
    Mar 2010
    ok, scusa..un'altra domanda: se alzo la frequenza con setCPU posso avere dei blocchi? tu come l'hai impostato?
