Pagina 309 di 597 primaprima ... 209259299307308309310311319359409 ... ultimoultimo
Visualizzazione dei risultati da 3,081 a 3,090 su 5967
[ROM] KANG over CyanogenMod 204 and CM10(Optimus Dual)
  1. #3081
    Venezia
    S4 & G3
    MisjudgedTwat's è uscito con la RC1-14
    CHERRY-PICKS
    NEW Idefc28d1: Make compcache script fail-safe
    NEW I913ec989: Remove misleading "default" indication
    NEW Id8344e55: Bulgarian T9 and dialer buttons
    NEW Ic17995e4: Added Straight Talk (US) APN settings.
    NEW I90858354: Optimize T9Search performance / memory consumption
    UPDATED I13b3108c: reboot: applet for bootmenu standalone version (gb variant)
    UPDATED Ice487342: Prevent Sym key from showing the IME picker
    MERGED Ic47a60ab: toolbox: remove TARGET_RECOVERY_PRE_COMMAND, defined in libreboot
    MERGED I3ccd8711: Safeguard against dumping large amounts of memory if SP is bogus.
    MERGED I9794688f: Busybox 1.20.0 squashed commit for gingerbread
    PORTS FROM OTHER SOURCES
    commits for double tap on home key:
    NEW - Custom action on the double tap on the home key. (Framework)
    NEW - Increase double-tap delay for home key extra activity launcher
    NEW - Custom action on the double tap on the home key. (CMParts)
    torino
    Xiaomi mi A1
    Ringraziato 56 volte in 52 Posts
    Ragazzi ho scaricato Dal market ics Gallery :a parte che va in crash con rom temasek .sarebbe bello avere anche il widget ..conoscete qualcosa?
    Inviato dal mio Optimus 2X usando Androidiani App
  4. #3083
    Androidiano L'avatar di Napoletano80
    lg p990 dual core
    Quote Originariamente inviato da redefined
    CHERRY-PICKS
    Ciao io ho la 13 ki la sta provando la 14 quali sono le diff Con la 13 grazie
    lg p990 dual core
  5. #3084
    Venezia
    S4 & G3
    Uscita la CyanogenMod ufficiale 7.2 RC2
    link in prima pagina
    Safeguard against dumping large amounts of memory if SP is bogus. (android_system_core)
    toolbox: remove TARGET_RECOVERY_PRE_COMMAND, defined in libreboot (android_system_core)
    Update Pepephone Internet APN (android_vendor_cyanogen)
    Update Telenor Online apn settings (android_vendor_cyanogen)
    Busybox 1.20.0 squashed commit for gingerbread (android_external_busybox)
    init.rc: update the permission of /data/local. (android_system_core)
    Restrict zygote to system user. (android_system_core)
    Applying theming to more framework items. (android_frameworks_base)
    Implementing Sunfire-related fixes (android_frameworks_base)
    This will expand the build time GCC check to include 4.7.x (android_external_webkit)
    Implement a new use case where the phone has a one-stage camera button only (sunfire). (android_packages_apps_Camera)
    Make absolutely sure the keyboard is never shown over the dialer. (android_packages_apps_Contacts)
    Fix call forwarding indication. (android_packages_apps_Phone)
    Fix for a Phone app crash related to multiradio operation. (android_packages_apps_Phone)
    Bluetooth: Fixup problems with the SDP records (android_external_bluetooth_bluez)
    Ultima modifica di redefined; 13-05-12 alle 13:01
  6. #3085
    Quote Originariamente inviato da redefined Visualizza il messaggio
    Provata? Miglioramenti?
  7. #3086
    Androidiano L'avatar di Kraaker
    Nexus 4 + LG Optimus 2X (P990)
    Io non riesco a scaricarla, non funzionano i link sul loro server!
    Con le MisjudgedTwat's ho notato che funziona male la regolazione del volume audio dei player, succede a qualcun'altro?
    Ultima modifica di Kraaker; 13-05-12 alle 13:05
  8. #3087
    Venezia
    S4 & G3
    Quote Originariamente inviato da andreanic Visualizza il messaggio
    Installata da poco.... nessun problema riscontrato, fluida e reattiva come sempre. Ho installato il buon vadonka kernel LGE-KaNG-120113 e questa volta, a differenza della 7.2 RC1, si è correttamente installato. Inoltre da ieri sto testando la bb 420, che presenta il solito problema con alcuni numeri speciali, con ril 1120.
  9. #3088
    Venezia
    S4 & G3
    Quote Originariamente inviato da Kraaker Visualizza il messaggio
    Ho scaricato usando il torrent. viaggiava a quasi 400 ... pochi minuti e l'ho installata.
  10. #3089
    Ok, partita!;-)
  11. #3090
    Ra_
    Ra_ non è in linea
    dannazione ho installato l'"ultima" kang proprio 2 giorni fa! Fatemi sapere come va questa che in caso aggiorno...i fix sono interessanti ma non mi sembrano necessari...per il resto salvo qualcosa di strano, è nettamente superiore alla stock... Continuo a fare domande comunque:
    -in op c'era il widget per il calendario e anche quello per la fotocamera stock...c'è qualcosa per il player musicale?
    -per cambiare font come devo procedere?
LinkBacks (?)
