Pagina 311 di 597 primaprima ... 211261301309310311312313321361411 ... ultimoultimo
Visualizzazione dei risultati da 3,101 a 3,110 su 5967
[ROM] KANG over CyanogenMod 204 and CM10(Optimus Dual)
  1. #3101
    Io sto provando ora la temasek rc1 prima rom non stock che provo. Mi trovo cosi bene che ho paura ad aggiornare alla RC2. Se notate miglioramenti visibili ditemelo
    Baby Droid L'avatar di temasek
    Ringraziato 16 volte in 9 Posts
    Quote Originariamente inviato da eiar Visualizza il messaggio
    Per chi ha installato la rc2 101 di temasek: avete provato a cambiare la bootanimation? Se clicco su "choose a bootanimation" mi si apre il gestore dei file. In quale cartella trovo i boot da scegliere?
    1. You can choose your custom bootanimation file using ANY FILE Manager, from anywhere.
    2. Your custom bootanimation don't have to be named as "bootanimation.zip" as the feature will auto rename it for you if necessary.
    3. Your custom bootanimation when selected, will be saved in /data/data/com.cyanogenmod.bootanimation/files
    4. When you select "Restore" in the bootanimation option, it will delete the bootanimation.zip in /data/data/com.cyanogenmod.bootanimation/files
    5. custom bootanimation no longer works using /data/local folder.
    This choosing of custom bootanimation feature is very neat and good. No more manual copy/paste or flashing from recovery.
    Enjoy
  4. I seguenti 3 Utenti hanno ringraziato temasek per il post:
    eiar (14-05-12),mattyfog (14-05-12),redefined (14-05-12)
  5. #3103
    Venezia
    S4 & G3
    temasek's UNOFFICIAL BUILD RC2-101
    1. Fixed Status Bar ICONS
    2. Further added status bar icons from CM9 (excluding signal icons)
    3. CM9 bootanimation by default
    PORTS FROM EXTERNAL SOURCE
    - Forgot to change intent on bootanimation chooser
    - Add preference to bootanimation chooser
    - Add preference for bootanimation chooser
    - CM Boot Animation Helper
    - Add bootanimation changer to CMParts (1/2)
    - Custom action on the double tap on the home key.
    - Increase double-tap delay for home key extra activity launcher
    - Add a green gps-fixed icon to status bar
    - try color changes to cmbattery and cmsignal text
    - Improve functionality of status bar restart + cleanup
    - Add option to restart status bar to CMParts
    - fix notification background changes2
    - added jerryscript notification backdrop changer 1/3
    - Add ability to show/hide remaining system icons in status bar (1/2)
    - Add ability to show/hide remaining system icons in status bar (2/2)
    - Make status bar dateview use clock's color
    - dropdown menu fixes
    - Statusbar color change mod by jerryscript
    - notification backdrop changer by jerryscript 1/2
    - notification backdrop changer by jerryscript 2/2
    - center clock 2/2 by Jerryscript
    - Statubar date fix
    - Statusbar mods by jerryscript
    MERGED COMMITS UP TO
    Change I3ccd8711: Safeguard against dumping large amounts of memory if SP is bogus.
    Gerrit Code Review
    CHERRY-PICKS
    If you see any picking is missing from last build, it is because it was merged, abandoned, reverted by me or I've eaten it up.
    NEW - Change Idefc28d1: Make compcache script fail-safe
    NEW - Change Id8344e55: Bulgarian T9 and dialer buttons
    NEW - Change Ic17995e4: Added Straight Talk (US) APN settings.
    Change I90858354: Optimize T9Search performance / memory consumption
    Gerrit Code Review
  6. #3104
    Androidiano VIP L'avatar di valledeitempli
    Oneplus one
    Ringraziato 144 volte in 122 Posts
    Anche a voi la status bar per esempio quando si elemina un'icona dalla home si blocca per qualche secondo con l'immagine del cestino e dell'app trascinata ??
    Inviato dal mio Optimus 2X usando Androidiani App
  7. #3105
    Jan 2011
    Lg Optimus One, Lg Optimus Dua
    Ringraziato 13 volte in 5 Posts
    Non ho capito se è meglio mettere la temasek 100 (RC1) 101 (RC2) o La Rc2 stock (per modo di dire) =)
  8. #3106
    Apr 2011
    Quote Originariamente inviato da alekerchak Visualizza il messaggio
    A me no.
    Le icone dell a barra delle notifiche sono davvero brutte (a mio parere ). Si possono cambiare tramite i settaggi?
    Optimus Dual
  9. #3107
    Venezia
    S4 & G3
    Quote Originariamente inviato da WidowMaker Visualizza il messaggio
    Considerato che passati alla RC2 sarebbe assurdo mettere una RC1, il resto è una scelta peronale. La cyano è "pulita", la kang ha parecchie aggiunte che possono piacere o meno. Temasek (e MisjudgedTwat's) in queste ultime versioni ha preso molto anche da altre fonti facendo, per molti, parecchie migliorie estetiche / funzionali. A te la scelta.
  10. #3108
    Venezia
    S4 & G3
    Aggio di MisjudgedTwat's .... unofficial-cm7.2-p990-RC2-15
    Modifiche / aggiuntedi questa versione:
    CHERRY-PICKS
    NEW Idefc28d1: Make compcache script fail-safe
    NEW I913ec989: Remove misleading "default" indication
    NEW Id8344e55: Bulgarian T9 and dialer buttons
    NEW Ic17995e4: Added Straight Talk (US) APN settings.
    NEW I90858354: Optimize T9Search performance / memory consumption
    UPDATED I13b3108c: reboot: applet for bootmenu standalone version (gb variant)
    UPDATED Ice487342: Prevent Sym key from showing the IME picker
    MERGED Ic47a60ab: toolbox: remove TARGET_RECOVERY_PRE_COMMAND, defined in libreboot
    MERGED I3ccd8711: Safeguard against dumping large amounts of memory if SP is bogus.
    MERGED I9794688f: Busybox 1.20.0 squashed commit for gingerbread
    PORTS FROM OTHER SOURCES
    commits for double tap on home key:
    NEW - Custom action on the double tap on the home key. (Framework)
    NEW - Increase double-tap delay for home key extra activity launcher
    NEW - Custom action on the double tap on the home key. (CMParts)
  11. #3109
    Senior Droid L'avatar di 480p
    Ringraziato 142 volte in 120 Posts
    A me no.
    Scarichi un tema che ti piace e lo applichi tramite theme chooser
    Inviato dal mio Optimus 2X con Tapatalk 2
  12. #3110
    Venezia
    S4 & G3
    BB 420 + ril 1120... risultato:
    permane il bug di numeri speciali (155, 4242.... wind)
    Consumo similare bb 1120 e 313
    connessione rete stabile ma mi sembra migliore la 1120
    WiFi ok
    gps ok
    torno alla 313 solo per non aver il problema dei numeri speciali ma, per ora, credo che la migliore rimanga la 1120.
LinkBacks (?)
