Pagina 74 di 258 primaprima ... 2464727374757684124174 ... ultimoultimo
Visualizzazione dei risultati da 731 a 740 su 2571
DjangoManouche 1.2 - Renaissance - Dedicated to Superskill and Topogigi
  1. #731
    Senior Droid L'avatar di carburano
    Rimini, Italy
    Xperia Z3 Copper
    Ringraziato 476 volte in 163 Posts
    DJANGO MANOUCHE 1.0
    5 versions:
    1 - Spica RC12-R OC
    2 - Spica RC12-R NO-OC
    3 - Gueste Kernel 1.1 EXT3
    4 - Gueste Kernel 1.1 EXT4
    5 - Fajarep SiKancil 0.2 EXT3
    6 - Stock with 20q kernel - EXT3
    Done
    - ALL NO WIPE (so remember to convert to ext3 to install ext3 versions)
    - 20q base
    - New sqlite lib 3.7 with full support to WAL mode (thanks Spica!)
    - No Ota update in settings (+20 Mb ram)
    - No OSP in settings and fully removed
    - Transparent curtain and circular battery
    - ICS animation
    - CM APN
    - Bravia Engine Mod
    - Build.prop tweaked for market compatibility
    - 20q ril (suggested baseband: 20q)
    - 3 new profiles for memory management in 90carbutweak script
    - Enabled ADB
    - Optimized host to remove spam and ads
    - Stock camera from 20q
    - Removed 2x reboot
    - Removed Battery Calibration
    - Removed LG UI 2 Weather, many animated wallpapers and other LG apps
    - Added DSP Manger (Thanks Spica)
    - Added Android weather (light and simple )
    - Back to Adobe flash 10.3 (IMHO best performance)
    - Removed LGStartupWizard
    - Gmaps up to date
    - ES file explorer Up to date
    - Su binary up to date
    - Facebook up to date
    - Google Music Up to date
    - Voice Search Up to date
    - Titanium Backup Up to date
    - Updated Supercharger script in /systems/xbin folder
    - Deactivated scrolling cache
    - Twitter Up to date
    - 2 launchers: TW launcher and QQLauncher
    5 transformation packs:
    - ICS theme by Gabriesu
    - IceComb by Gabriesu
    - Swishstyle by Gabriesu
    - Back to DjangoManouche Stock
    - Back to LG Stock (with LG Launcher and stock framework)
    Download:
    1 - Spica RC12-R OC - SOON
    2 - Spica RC12-R NO-OC - SOON
    3 - Gueste Kernel 1.1 EXT3 - Download
    4 - Gueste Kernel 1.1 EXT4 - Download
    5 - Fajarep SiKancil 0.2 EXT3 - SOON
    6 - Stock with 20q kernel - EXT3 - Download
    Screenshots:
    IF YOU LIKE MY WORK YOU CAN:
    DONATE TO "EMERGENCY" (To help war hospital) HERE
    or you can offer me a beer
    HERE
  2. I seguenti 2 Utenti hanno ringraziato carburano per il post:
    docmoody (25-02-12),marcelloa (25-02-12)
    Apr 2011
    HTC One
    Ciao Carburano grazie di tutto. Bravo e capace.
    Il tema ics, gabriesu ha di nuovo eliminato la batteria circolare? È così comoda..
  5. #733
    Con la 1.0 stock ci sono problemi di sorta? Foto/videocamera, giochi, o quant'altro.
    Si potrebbe tenere traccia in un posto dei bug noti con queste release?
  6. #734
    Androidiano VIP L'avatar di rizzotti91
    Messina
    Samsung Galaxy Note 2
    Ringraziato 239 volte in 228 Posts
    Ho su la Gueste v3.1 da quando è uscita, attualmente, causa vari impegni non ho seguito molto il panorama delle rom uscite, dite che mi conviene passare a questa? Noterei vantaggi?
  7. #735
    Baby Droid L'avatar di ROSSOBLU
    Zena
    LG Optimus Dual
    Stesso dubbio... anche io ho la gueste 3.1!
    Ora non so se provare questa o la gueste 3.2
    Mah.....
    Inviato dal mio Optimus 2X usando Androidiani App
    GARRONE SANTO SUBITO!!
  8. #736
    Androidiano VIP L'avatar di mats25101979
    Bologna
    Huawei Mate 10 pro
    Ringraziato 278 volte in 240 Posts
    Volevo sapere se è rimasto lg pcsuite su questa versione o è stato cancellato come nelle altre django
    Inviato dal mio LG-P990 usando Tapatalk
  9. #737
    Zena
    LG Optimus Dual
    In download! Volevo chiedere se è possibile avere qualche screen dei temi. Se flasho un tema e poi non mi piace posso tranquillamente flasharne un altro o devo, in qualche modo, eliminare il precedente? Grazie!
  10. #738
    Androidiano VIP L'avatar di chefare
    Dec 2009
    Torino
    Ringraziato 431 volte in 406 Posts
    Ma quella ricetta del tiramisu durante l'installazione è un attentato alla salute, e poi anche con la panna giusto per alleggerire un po', eh...
  11. #739
    Androidiano L'avatar di virtvs
    Vicenza
    LG Optimus Dual, LG P880 4X HD
    Quote Originariamente inviato da ROSSOBLU
    Puoi tranquillamente flasharne un'altra da recovery...
    IN MEDIO STAT VIRTVS
  12. Il seguente Utente ha ringraziato virtvs per il post:
    ROSSOBLU (25-02-12)
  13. #740
    ma purtroppo è basata sempre su v20q quindi sicuramente sarà meno fluida della cyano
