Pagina 348 di 792 primaprima ... 248298338346347348349350358398448 ... ultimoultimo
Visualizzazione dei risultati da 3,471 a 3,480 su 7917
[ROM][JB] Tsunami X --- by Team Tsunami [AOKP Jelly Bean][OTA]
  1. #3471
    galaxy s i9000
    Ringraziato 26 volte in 18 Posts
    quando esce la tsunami 4.1.2.........inoltre c'è la possibilità di mettere il multy windows.....o abbiamo pochissima ram
    ROM: LA + BELLA, LA + VELOCE, LA " MIGLIORE" = TSUNAMI X 3.0
    MODEM = ZSJP
    KERNEL = SEMAPHORE 2.4.4
    team tsunami = google, samsung ,iphone, steve jobs, ecc I MIGLIORI
    Androidiano VIP L'avatar di xlory
    Trento
    Galaxy S - Galaxy S3
    Ringraziato 4,937 volte in 2,433 Posts
    ROM in upload...... rilascio domani......
    www.x-planet.it adesso i download vengono fatti direttamente dal Ns FTP server-......
    Changelog Tsunami X 2.5
    • Base AOKP Build 5
    • Rebuild with AOSP 4.1.2
    • Semaphore 2.4.4s
    • Patch HUGEMEM (for use bigmem to 404 mega….break video)
    • Script tweaks….. evrey reboot system optimization
    • MMS new version…. Temable (change color, avatar, bubble, split sms, convert to MMS…)
    • Gmail 4.2 inverted
    • Playstore 3.9.16 patched and inverted
    • SQLite optimization
    • Fix GPS
    • Updated Google apps for Android 4.1.2
    • Change tweaks for sytem in build.prop
    • Add in OTA many addons….. CAR KIT, Kernel, Small Font…
    • Zipaligned every apps when reboot
    • New Locckscreen (2-4-6-8 targets)
    • Transpaency in notification bar
    • Chage icons for mobile signal from Tsunami X Control
    • DPS Manager with mod library
    • New features from AOKP:
    • Custom NavBar for TabletsNavBar
    • widgets are back from ICS
    • Highly customizable*Lockscreen Ring*targets, with a shiny new editor in ROMControl!
    • Alternate default app picker (like in GB)
    • Menu UI Overflow
    • ToggleOption to disable vibration for Notification expansionRAM Bar in the Recents panel
    • Timeout and instant lock options for Slide lockVPN Traffic amount in human readable format
    WarningIf you are a flashoholic and*not*coming straight from Build 4*(you built it from source, or tried some unofficial/ nightly builds), you might have to*reset your Lockscreen targets, as we changed some critical code in the last few days.
    Samsung Galaxy S - Tsunami X AOKP JB - VorteX CM10 - XanaX slim
    Samsung Galaxy S3 Tsunami X AOKP JB - UltimaRom - Vortex Cm10.1
    Samsung Galaxy P3110 - Tsunami X JB
    Ti sono stato utile?..... un Thanks....
  4. I seguenti 14 Utenti hanno ringraziato xlory per il post:
    felix7417 (23-10-12),Frank_9.5 (23-10-12),fransis1981 (23-10-12),jacksamba (23-10-12),Joelogs (23-10-12),konsel89 (23-10-12),Marziovis (23-10-12),Morpheus88 (23-10-12),pinky40 (23-10-12),radicspeter (23-10-12),sanji1310 (23-10-12),tiso (23-10-12),trevor (23-10-12),Wagark (23-10-12)
  5. #3473
    Roma/Abruzzo
    Motorola Moto G 2014
    Ringraziato 29 volte in 26 Posts
    Per la 2.5 saranno necessari i tre wipe,giusto?
  6. #3474
    Senior Droid L'avatar di felix7417
    Romito Magra-La Spezia
    Nexus5- Galaxy Ace-Ideos
    Ringraziato 316 volte in 242 Posts
    Quote Originariamente inviato da 9Michele0 Visualizza il messaggio
    si..........
    Nexus 5_Pure Nexus 7.7.1-Galaxy ACE S5830I
    Operatore Mobile: 3_Opzione/Tariffa: ALL IN Teen (1000-100-10GB)
    Mediacom SmartPad MP-8S4B3G
  7. Il seguente Utente ha ringraziato felix7417 per il post:
    9Michele0 (23-10-12)
  8. #3475
    Androidiano VIP L'avatar di tiso
    Feb 2011
    Nexus 4
    Ringraziato 253 volte in 216 Posts
    Quote Originariamente inviato da xlory Visualizza il messaggio
    • Base AOKP Build 5
    • Semaphore 2.4.4s
    • Fix GPS
    • Menu UI Overflow
    woooo grandissimo non vedo l ora di flashare soprattutto perché con la 2.1 avevo qualche problema coi consumi e con l app dei messaggi
    Inviato dal mio GT-P3100 con Tapatalk 2
    Il mio blog: OutOfBit
    Se ti sono stato un utile ringraziami premendo il Thanks qui sotto a sinistra
  9. #3476
    Trento
    Ecco il link... x chi non scarica da OTA..... rimanda alla pagina con il changelog....
    TSUNAMI X 2.5 Aokp
  10. I seguenti 6 Utenti hanno ringraziato xlory per il post:
    bottu80 (23-10-12),fransis1981 (23-10-12),pinky40 (23-10-12),radicspeter (23-10-12),tiso (23-10-12),vanzo (23-10-12)
  11. #3477
    Baby Droid L'avatar di bottu80
    primo?
    grazie xlory, non vedo l'ora
  12. #3478
    Galaxy s2
    Ringraziato 33 volte in 24 Posts
    Quote Originariamente inviato da bottu80 Visualizza il messaggio
    primo?
    Ho gia installato e sta scaricando da store.
  13. #3479
    Galaxy s2
    TSUNAMI X 2.5 Aokp
    Server velocissimo.
    P.S. ma la tsunami non c'e' per S2?
  14. #3480
    Androidiano VIP L'avatar di Vicky706
    Sesame Street
    Note edge
    Ringraziato 620 volte in 413 Posts
    Woau... bella sta 2.5.. senti lorenzo.. io l'ho Flashata sopra la 2.0 facendo solo due wipe... gira bene, credo.. dici di farli tutti e tre ??
    Sono vecchio e allora adesso con Note Edge
LinkBacks (?)
  1. 04-09-12, 08:40
