Pagina 111 di 233 primaprima ... 1161101109110111112113121161211 ... ultimoultimo
Visualizzazione dei risultati da 1,101 a 1,110 su 2323
[ROM][CM11][4.4.2]temasek's UNOFFICIAL all build r3p2MALI(I9300)
  1. #1101
    Androidiano VIP L'avatar di Volpe92
    Venezia
    S3, S6 edge 64gb, note 3
    Ringraziato 172 volte in 139 Posts
    Build V14
    md5sum: bf4ea300c0dc81008c94aaf829f9791f
    CHANGELOG FOR V14
    • FIXED - APN Editing
    • FIXED - Screeching sound while playing music when locksceen sound / notifications produced.
    • FIXED - ListView FC reported by some users.
    • Add back Omni Non-intrusive InCallUI, now with option to enable/disable. - Not tested
    • Notification background & transparency - SlimROM
      - Past builds was a port from jellybean slimrom
      - Now its kk4.4 updated version.
    • fb: support for keyguard widget carusell on tablets
      - support it as well on tablets and reduce used memory in general and remove the not needed view instead of just hiding it.
    • fb: post time-critical systemui flags to window manager -SlimROM
      - thanks Kiril for this suggestion. We are already using window manager for other things in immersive mode....so nice addition to fix a race condition
    • fb: add back small bottom margin 1px - SlimROM
      - 2px was to much 0 was to less.....1 seems to be perfect
    • Add "Configurable 0, 90, 180 and 270 degree rotation"
    • Better Expanded desktop icons - PA
    • SystemUI: do not collapse panels if keyevent was canceled.
    • Keyguard: fix statusbar lags when default widget shown.
      - When statusbar became expanded KeyguardStatusView receives onKeyguardVisibilityChanged callback and refreshes ClockView. Because it receives more than one call and every time it reads new values from resources it cause lags in opening statusbar panel.
      - Replace this code with BroadcastReceiver and ContentObserver to refresh it only in case something was changed.
    • Quiet Hours: Clean up and consolidate code
      - Added: Allow disabling of system sounds
    • Revert "smdk4412: camera: include support for snapshot while recording"
    • smdk4412-common: camera: fix heap corruption - dhiru1602
    • smdk4412: audio: Remove hackaround for broken audio in first call - Omni
    • The rest...can't remember
    • Updated cm source - lots of it. Help yourself and read it in cm gerrit.
    DOWNLOAD SITES
    temasek.hopto.org
    Dev-Host
    AndroidFileHost
    MediaFire
    Available for i9300 ( tilapia & grouper coming soon )
    Enjoy
    Senior Droid L'avatar di luigiv97
    Ringraziato 48 volte in 40 Posts
    Ragazzi io sono rimasto a molte versioni indietro...a che punto si trova la rom? La durata della batteria com'è? Grazie in anticipo
  4. #1103
    Venezia
    V14 TINY Flashable Update
    V14-UPDATE-i9300-temasek.zip
    FIXED - Settings FC in notification drawer -> Background and transparency
    Instructions:- Flash over V14
    Available in ALL 4 download sites.
  5. #1104
    Androidiano VIP L'avatar di almaximo
    Sep 2010
    Mate 10 PRO / Samsung S8
    Ringraziato 234 volte in 191 Posts
    Quote Originariamente inviato da Volpe92 Visualizza il messaggio
    aveo appena finito di aggiornare...ahahahahhha
    __________________________________________________ ________________________________
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  6. #1105
    Androidiano VIP L'avatar di Locaa92
    Torino
    Galaxy SIII
    Ringraziato 236 volte in 213 Posts
    What's this? :what:
  7. #1106
    Androidiano VIP L'avatar di ClaudìoS3
    Profondo SUD
    GACE, Ascend P1, GS3, ZUK Z1
    Ringraziato 280 volte in 191 Posts
    che cambia fra i 2?
    Se ti sono stato utile, clicca il tasto "THANKS" a sinistra
    LENOVO ZUK Z1
    ROM: Cyanogen OS 12.1 Android: 5.1.1 Lollipop
    EX Nick: GalaxyAceICS; ClaudìoP1
    Tutto è possibile, l'impossibile richiede soltanto più tempo.
  8. #1107
    Torino
    Galaxy SIII
    Quote Originariamente inviato da ClaudìoS3 Visualizza il messaggio
    che cambia fra i 2?
    Devi flashare entrambi, il secondo è uno zip che si integra alla v14
  9. #1108
    Sep 2010
    È un impressione mia o sembra diventata un scattosa?
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  10. #1109
    Mar 2010
    Ancora non ti so dire... Ho flashato solo ieri sera.
    Stefano
  11. #1110
    napoli
    Samsung S3 CM 11 temasek
    Che significa scattoso? ho flashato stanotte al momento è tutto Ok
