Pagina 42 di 233 primaprima ... 3240414243445292142 ... ultimoultimo
Visualizzazione dei risultati da 411 a 420 su 2323
[ROM][CM11][4.4.2]temasek's UNOFFICIAL all build r3p2MALI(I9300)
  1. #411
    Androidiano VIP L'avatar di almaximo
    Sep 2010
    Mate 10 PRO / Samsung S8
    Ringraziato 234 volte in 191 Posts
    Giusto per non farvi annoiare :
    Build V64
    md5sum: 70cb7218d66ca42f756ee16ebd8f3bf4
    2nd build of the day
    • Revert "dynamic PIE menu button + navbar menu logic cleanup" by SlimROM
    • By user request - The return of MENU key in navigation bar
      - Also Retained dynamic MENU key in PIE
    • FIX SystemUI FC when using inverted UI or toggling Dark Droid - @Cristiano Matos
    • Updated cm source
    Originally Posted by temasek
    Oh damn.
    Dynamic MENU button in PIE needs to be temporary reverted in next build. Its not compatible with current MENU key implementation of navigation bar. Both are abit connected.
    I have to keep both tablets & phones compatible. Phone compatible may not be tablet compatible. I need to maintain both working.......
    decidete voi se aggiornare o aspettare la prossima
    Ultima modifica di almaximo; 25-10-13 alle 16:12
    __________________________________________________ ________________________________
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  2. Il seguente Utente ha ringraziato almaximo per il post:
    mixmaxmux (25-10-13)
    Sep 2010
    anzi.....visto vari problemi non aggiornate
    passate direttamente alla prossima, non credo che starà tanto ad arrivare
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  5. #413
    Sep 2010
    Build V65
    md5sum: 59401cb742e89e76366330f664f1fd6b
    This is actually my 2nd build of the day. First build was done and it FROZE on boot. My first thoughts was something changed and I need to clobber my build. And yes its good after clobbering.
    WARNING:
    Temasek kernel users, pls backup your profile before flashing temasek kernel over V65.
    • Clobbered build.
    • Advanced Display making a comeback.
      - Settings -> Display & lights -> Advanced Display
      - Because of the above, those on AndreiLux's display settings via kernel tweaks may have to re-enable your settings via STWeaks.
    • Lots of merged stuffs, read on your own.
    • Updated cm source
    Ultima modifica di almaximo; 27-10-13 alle 19:38
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  6. #414
    ragazzi come faccio a mettere la fotocamera stock samsung (o magari ancora meglio quella del note 2 moddata) su questa rom? perché la fotocamera stock google android 4.3 da problemi e non mi fa impazzire...
  7. #415
    Androidiano L'avatar di crazyniko
    Ardea (RM)
    Oneplus One & Galaxy S5
    Quote Originariamente inviato da almaximo Visualizza il messaggio
    Build V65
    WARNING:
    * Clobbered build.
    * Advanced Display making a comeback.
    * Lots of merged stuffs, read on your own.
    * Updated cm source
    I'm kinda busy both at work and family atm so excuse me if I'm not very active for sometime.
    Enjoy
    Ciao Almaximo tu l hai flashata la v 65? Come va questa build dopo i problemi scorsi? Perché stavo leggendo su xda che ci sono problemi a riconoscere altri kernel!
    Oneplus one 64 gb sandstone black
    CyanogenMod 12.1-20150701-Nightly - recovery TWRP 2.8.6.1
    Kernel AK.270
  8. #416
    Sep 2010
    IO la sto usando e ho flashato la 65 sopra la 64 che avevo messo e il kernel temasek ultimo, quello su base 101, sopra la 65
    per adesso nessun problema visibile ma ho letto anch'io dei probemi ......
    Ultima modifica di almaximo; 27-10-13 alle 19:43
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  9. Il seguente Utente ha ringraziato almaximo per il post:
    crazyniko (27-10-13)
  10. #417
    Sep 2010
    non la puoi mettere, solo AOSP
    prova FOCAL se vuoi o CAMERA ZOOM FX se quella std non ti piace o ti da problemi di malfunzionamenti
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  11. #418
    Ardea (RM)
    Appena flashata la build v.65 e poi il kernel temasek Wolfson x ora sembra tutto perfetto!
    Kernel AK.270
  12. #419
    Sep 2010
    Build V66
    md5sum: 5a34a6d4d7586188230e8b7f141a70f2
    Some important bug fixing in cm sources.
    • Clobbered build
    • Updated cm source
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  13. Il seguente Utente ha ringraziato almaximo per il post:
    crazyniko (28-10-13)
  14. #420
    Galaxy SIII + GalaxyTab 2 10.1
    Ringraziato 36 volte in 30 Posts
    ciao a tutti... ho visto che ci sono 4 kernel diversi... qual è il migliore in funzione del risparmio della batteria?
