Pagina 44 di 233 primaprima ... 3442434445465494144 ... ultimoultimo
Visualizzazione dei risultati da 431 a 440 su 2323
[ROM][CM11][4.4.2]temasek's UNOFFICIAL all build r3p2MALI(I9300)
  1. #431
    Androidiano VIP L'avatar di almaximo
    Sep 2010
    Mate 10 PRO / Samsung S8
    Ringraziato 234 volte in 191 Posts
    Quote Originariamente inviato da asr77 Visualizza il messaggio
    ragazzi la fotocamera è un pò un disastro vero?o sono semplicemente jellato io?
    dimenticavo, prova a cancellare cache e dati dell'applicazione galleria
    a me ha funzionato e la camera è usabile
    __________________________________________________ ________________________________
    Huawei Mate 10 Pro
    Huawei Mediapad M5
    Sep 2010
    Build V68
    md5sum: 87760a4a2cf361f4166685ab529bde9c
    • Revert "Network Traffic Meter"
    • Added "Network usage stats to status bar" - 0xD34D
      - ul/dl indicators
    • NetStats: Don't update stats when screen is off
    • Network stats custom colors - @Cristiano Matos
    • smdk4412-common: camera: Block out endlessly looping focus clause
      - capture_auto_focus_result isn't updated from any realtime focus callback, so waiting for it to change in order to complete the capture introduces delay, and in some cases an infinite loop.
      - Remove the focus state verification, at least until such a callback can be put in place.
    • Updated cm source
    e inoltre
    Temasek Kernel for CM-10.2
    Dated: 30 Oct 2013
    • SELinux: don't check permissions on already freed ressources - AndreiLux
    • Fix touch wake - Owain94
    • mm: writeback: every 500ms the writeback daemon kicks in and flushes the dirty pages into disk. Thats not very pleasant for performance and *maybe* battery. This patch disables the writeback function while the screen is on, and enables it back when the screen is off to flush all the dirty pages. In my real world usage testing I notice a slight bump in smoothness and performance while using the device. - franciscofranco
    • dirty writeback/expire interval tweaks - Boy Petersen
      - for less lag when screen is on and less wakeups when screen is off
    • tweak dirty writeback - Boy Petersen
    • page-writeback.c: subtract min_free_kbytes from dirtyable memory - Boy Petersen
      - When calculating amount of dirtyable memory, min_free_kbytes should be
      subtracted because it is not intended for dirty pages
    • different dirty ratios behavior for screen-on / screen-off - Boy Petersen
      - smoothness for screen-on, relaxed values for screen-off
    • mm/page-writeback.c: less dirty memory with screen on - Boy Petersen
    • mm/page-writeback.c: adjust dirty writeback for previously introduced lower vmalloc - Boy Petersen
      - Ever since vmalloc=182M, all available RAM is low memory. By leaving the
      dirty ratios unchanged, this resulted in a massive increase in dirtyable
      memory. The new values adjust the ratios to achieve roughly the same amount of dirtyable memory in megabytes as before.
    • fs/dcache.c: adaptive vfs_cache_pressure on suspend / resume - Boy Petersen
      - low vfs_cache pressure values save battery while idle, while a low value also causes stutter with longer up times.
    • fs/dache.c / mm/page-writeback.c: allow modification of dirty_-values and cache_pressure despite the dynamic suspend/resume values - Boy Petersen
    Ultima modifica di almaximo; 30-10-13 alle 08:27
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  4. #433
    Sep 2010
    Build V69
    md5sum: 63df671117e41c4e02faa341ed8471f1
    ..yet another 2nd build of the day
    NOTE: This build is UNTESTED
    A couple days ago I PM @Cristiano Matos with regards to porting this user request feature "Suspend Actions & Wakelock Blocker". I just received PM from @Cristiano Matos that he had completed it. Big THANKS to him (and of course the original author maxwen), now its incorporated into this rom.
    • Suspend Actions & Wakelock Blocker - maxwen
      - Ported by @Cristiano Matos - BIG THANKS.
    • By user request, re-added "Add reboot tile to QS"
    • Hide network stats if there's no traffic - @Cristiano Matos
    • Updated cm source
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  5. #434
    Sep 2010
    queste due opzioni a menù inserite da sole valgono la ROM - dateci un okkio e regolatevele con il vostro funzionamento
    dovrebbero ottimizzarvi i consumi in maniera incredibile
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  6. Il seguente Utente ha ringraziato almaximo per il post:
    crazyniko (30-10-13)
  7. #435
    Sep 2010
    Build V70
    md5sum: 2fbaa8106bf7f75d0a87908876aecf85
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  8. #436
    Sep 2010
    La camera dovrebbe essere a posto. Chi aveva problemi puo confermare dopo aver cancellato fata e cache dell'app galleria?
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  9. Il seguente Utente ha ringraziato almaximo per il post:
    crazyniko (31-10-13)
  10. #437
    Androidiano L'avatar di crazyniko
    Ardea (RM)
    Oneplus One & Galaxy S5
    Quote Originariamente inviato da almaximo Visualizza il messaggio
    Confermo! Fatto così come hai detto ora la camera è ok, zooma e scatta senza problemi!
    Oneplus one 64 gb sandstone black
    CyanogenMod 12.1-20150701-Nightly - recovery TWRP 2.8.6.1
    Kernel AK.270
  11. #438
    Modena
    Samsung Galaxy S3 i9300
    Qualcuno ha notato miglioramenti con l'ultima versione ? (Camera a parte).
    Io son rimasto alla v61.
  12. #439
    Sep 2010
    Quote Originariamente inviato da lyper Visualizza il messaggio
    Io un aggiornamento lo farei....non fosse altro per tutta la pulizia fatta sul codice ;-)
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  13. #440
    Sep 2010
    V70 TINY UPDATE
    V70-UPDATE-temasek-i9300.zip
    FIXED - FC on HALO Settings due to wrong path in Settings header xml file.
    Instructions:- Flash over V70
    Huawei Mate 10 Pro
    Huawei Mediapad M5
