Pagina 54 di 233 primaprima ... 444525354555664104154 ... ultimoultimo
Visualizzazione dei risultati da 531 a 540 su 2323
[ROM][CM11][4.4.2]temasek's UNOFFICIAL all build r3p2MALI(I9300)
  1. #531
    Androidiano VIP L'avatar di almaximo
    Sep 2010
    Mate 10 PRO / Samsung S8
    Ringraziato 234 volte in 191 Posts
    BUILD - V1
    md5sum: 74b7dd2f81edad6f1c433539d6de7ede
    This is the first unofficial official build.
    You are NO LONGER required to use my temasek cm11 kernel as WIFI/Camera/external sdcard will WORK out of the box without any external fixes or custom kernels.
    Instructions:-
    1. Use latest Official CWM Recovery 6.0.4.4
    2. Boot to recovery
    3. If you are from stock sammy, do a FULL WIPE then flash cm11
    4. If you are from cm-10.2, just flash cm11
    5. Flash correct gapps (you may use my gapps in misc folder or PA GAPPS)
    6. Flash temasek cm11 kernel (Recommended)
    7. Reboot
    FULL CHANGELOG SINCE 1st PREVIEW
    • Most of the ports will now be in "temasek spare parts"
    • Status bar clock style from SlimROM
    • Network traffic meter
    • Brightness control from SlimROM
    • Notification background & transparency
    • Notification shortcuts
    • Low battery warning options
    • Screen-On Notification light option
    • CRT animation from SlimROM
      - cm native crt animation commented out from source
    • Use Alt default app grid
    • Show CPU info
    • Restart SystemUI
    • Dark UI (TRDS 2.0) from SlimROM
      - I will progressively bring TRDS to many parts of the system.
    • Ensure restart SystemUI will not replace your current wallpaper.
    • Screenshot QuickTrash
    • .....I forgotten the rest
    • Temasek CM11 Bootanimation by @2uk3y
      - I will temporary use this till something better comes about
      - That doesn't mean I don't like it. Thanks to @2uk3y
    • Custom System Animations by AOKP
    • Battery Styles with colors by SlimROM
    • Ability to use data over VOICE - Untested
    • FIXED - Camera FC on 1st run
    • Updated cm source
    __________________________________________________ ________________________________
    Huawei Mate 10 Pro
    Huawei Mediapad M5
    Sep 2010
    installata
    per far rifunzionare tutto come lo avevo lasciato ho dovuto installare ROM, PAGapps e Kernel temasek in sequenza seguiti da un bel wipe dalvik
    con l'intasllazione della sola rom avevo perso calendario e gmail tornati a posto dopo aver riflashato tutto come sopra
    comunque un gran bel lavoro !!!!!
    seguiranno commenti
    Ultima modifica di almaximo; 14-11-13 alle 08:45
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  4. Il seguente Utente ha ringraziato almaximo per il post:
    crazyniko (14-11-13)
  5. #533
    Sep 2010
    Quote Originariamente inviato da Volpe92 Visualizza il messaggio
    Ok, intanto provo la Omni... Che più o meno saranno là... Ma ti chiedo una cosa:
    Il kernel temaseak per cm11 posso metterlo con la Omni 4.4?
    ricordati che disabilita SElinux ..... e questo ha permesso di far funzionare wifi, camera & Co
    Ricordati anche che c'è un kernel apposito per la omni Temasek nella cartella OMNI del Repository (per la 4.3.x)
    e per ultimo considera che OMNI non è una CM .....
    non so se ci sono stati altri aggiustamentei Temasek per la propria ROM ma stamani installando V1 alcune cose non andavano e hanno ripreso a vunzionare solo con ik kernel Temasek
    quasi sicuramente non ha impatti ma nel caso di malfunzionamenti, prima di diventare matto ....
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  6. Il seguente Utente ha ringraziato almaximo per il post:
    Volpe92 (14-11-13)
  7. #534
    Modena
    Samsung Galaxy S3 i9300
    Quote Originariamente inviato da almaximo Visualizza il messaggio
    installata
    seguiranno commenti
    Quindi niente full wipe proveniendo da temasek rom 4.3? Basta flashare in sequenza più dalvik?
    Volevo evitare di fare il full.
    Grazie.
  8. #535
    ho installato la V1 per ora funziona alla grande
  9. #536
    Mar 2010
    A me si era perso la posta aziendale...
    Cmq ho seguito la seguente installazione:
    - installata ultima cwm e riavviata
    - installato 4.4
    - installato gapps di temasek
    - installato kernel
    -in fine reboot
    Stefano
  10. #537
    Androidiano VIP L'avatar di Enr1988
    Legend-DS-GS2-GS3-MotoG-Lg G2
    Ringraziato 989 volte in 743 Posts
    installata
    seguiranno commenti
    Cavolo Almaximo, sei un maniaco di Temasek come me..io ho flashato la v1 alle 8:10 e pensavo di essere uno dei primi in Italia, ma tu sei stato più veloce
    detto questo la rom va già molto bene, nessun fc o altro, mancano giusto un paio di feature che Temasek aveva aggiunto, ma diamogli tempo...trovo la gestione Ram nettamente migliorata rispetto al jb 4.3 e questo per il nostro s3 castrato da 1 solo Gb di ram è tanta roba!
    Se ti ho aiutato usa il tasto THANKS per ringraziarmi!!
    [B]Oneplus 3/B] Oxygen Os Beta 19 Dorimanx Kernel
  11. #538
    Sep 2010
    Quote Originariamente inviato da lyper Visualizza il messaggio
    Grazie.
    niente full wipe !
    solo dalvik
    non perdi niente
    se al primo riavvio ti sembra che manchi qualcosa, torna in recovery, secondo wipe della dalvik e riavvia
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  12. #539
    Sep 2010
    Quote Originariamente inviato da Enr1988 Visualizza il messaggio
    Oramai la fiducia è tale che vado a occhi chiusi
    La RAM è eccezzionale
    secondo me c'è anche qualche piccolo lag negli scroll, ma potrebbe non essere colpa della ROM
    per il resto "Tema" è un mostro, ha messo a posto la CM11 in 2 giorni scarsi e l'ha resa perfettamente fruibile
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  13. #540
    Sep 2010
    avevo mandato un PM a Dieguccio per cambiare il titolo del thread.....spero presto
    comunque siamo passati inesorabilmente a [CM11][4.4][ROM] temasek's UNOFFICIAL All Build (GT-I9300)
    Huawei Mate 10 Pro
    Huawei Mediapad M5
