Pagina 96 di 233 primaprima ... 46869495969798106146196 ... ultimoultimo
Visualizzazione dei risultati da 951 a 960 su 2323
[ROM][CM11][4.4.2]temasek's UNOFFICIAL all build r3p2MALI(I9300)
  1. #951
    Androidiano VIP L'avatar di Volpe92
    Venezia
    S3, S6 edge 64gb, note 3
    Ringraziato 172 volte in 139 Posts
    Build V10
    md5sum: 15d2c3e4e4d9fd24991188bfc127ca82
    CHANGELOG FOR V10
    [HIDE]
    • FIXED - NPE when on long press POWER button
      - When user did not enable airplane mode in Global menu, it will result in NPE and will reboot the phone.
    • Revert "Clear recents screen"
      - Users prefer "shadow" background over clear.
    • Revert "Add battery level around unlock ring"
      - This is temporary till I find a way to ensure this works with the new feature
    • Revert "CM's Lockscreen - Customizable shortcuts"
    • Add "Port Lockscreen Targets and Shortcuts" - SlimROM
      First thanks to PA and CM which gave us partly code and some ideas.
      Still some parts of the original implementation are/were buggy as well
      we needed to ehance it.
      Whatever the new Slim version is now ready and seems to be completly bug
      free.
      - Configurable lockscreen targets...on tablets 8 on phone either 5 or 8
      - configurable lockscreen shortcuts only on phones...up to 5 shortcuts
      - Centralazing some methods....using now then rounded corner on custom
      images systemwide...means on all other shorcut features we have
      - multiDpi compatible
      - new settings logic
      - instance handling of all dialogs like we do on all other places
      way nicer this way
      - tons of fixes
    • fb: set correct providers default value am/pm - SlimROM
      - fresh install shows am/pm on english timezones which does not fit with the aosp default behaviour. Go inline with it and hide it as default. User can change it then.
    • Add "Active Display" - ChameleonOS
      - Not tested
    • smdk4412-common: camera: fix scene mode snapshot capture crashes - dhiru1602
      - Few Scene Modes (like Night, High Sensitivity) if set as default, after the camera opens, require the scene mode to be set when the stream is turned on inorder to properly take effect. Not doing so will result in crashes while trying to capture the snapshot.
    • ART Runtime - "Add verifier: Bypass monitor-{enter,exit} depth checks
      Per Google Bug 61916[1], the monitor-enter and monitor-exit checks in
      dex2oat are excessively strict and will reject some valid APKs, such as
      WhatsApp[2]. This change attempts to relax those requirements." - cernekee
    • Updated cm source - lots of it. Help yourself and read it in cm gerrit.
    [/HIDE]
    DOWNLOAD SITES
    temasek.hopto.org
    Dev-Host
    AndroidFileHost
    MediaFire
    Available for i9300 only
    @brunodmjr fyna
    Enjoy
  2. I seguenti 2 Utenti hanno ringraziato Volpe92 per il post:
    almaximo (27-11-13),idiversss (27-11-13)
    Senior Droid L'avatar di idiversss
    Nov 2010
    Firenze
    Ringraziato 36 volte in 34 Posts
    Ottimo..si metterà su anche questa... Domanda...è già un paio di volte che in carica la notte mi si impala e devo resettare ...ovviamente non mi sveglio in orario :-( è capitato anche a voi?
    GALAXY S
  5. #953
    Androidiano VIP L'avatar di almaximo
    Sep 2010
    Mate 10 PRO / Samsung S8
    Ringraziato 234 volte in 191 Posts
    wipe cache
    flash rom V.10
    flash PA gapps del 26 novembre
    flash kernel temasek r3p2
    flash superSU 1.80
    tutto a posto salvo che è sparito AOSP keyboard ....
    non è una grossa perdita visto che non la uso ma già immagino valanghe di post di gente disperata....
    possibile che non riescono a fare delle gapps stabili, che non rompono le palle ogni volta ? e che non ci sia bisogno di rflasharle ogni volta ?
    __________________________________________________ ________________________________
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  6. Il seguente Utente ha ringraziato almaximo per il post:
    crazyniko (27-11-13)
  7. #954
    Sep 2010
    Quote Originariamente inviato da idiversss Visualizza il messaggio
    no, mi era successo solo una volta tanto tempo fa con le 10.2
    se non ricordo male un bel wipe cache e dalvik e dovrebbe andare tutto a posto
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  8. #955
    Sep 2010
    Quote Originariamente inviato da loken Visualizza il messaggio
    ho tolto la miui e.... un bel problema... non riesco a vedere le immagini su Galleria, ho installato la v9 e i gapps del 26...
    consigli?
    era già successo in passato a qualcuno
    se cerchi nel thread secondo me trovi qualcosa
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  9. #956
    Sep 2010
    Quote Originariamente inviato da anarky81 Visualizza il messaggio
    Almaximo caro...,
    dove sono le nuove gapps del 26 ?!?
    se davvero sono un porting dei nexus (google experience) le provo appena torno a casa !!!
    Poi vi dico...
    Ora sto sul treno e banda mobile permettendo me le scarico al volo.
    Aspetto tue urgenti !!!
    Stefano
    Io ho trovato questo... ma sono pezzetto per pezzetto !!!
    http://www.androidfilehost.com/?a=sh...iles&flid=9199
    che intendevi queste tu ???
    Stefano
    un dubbio.... ma cercavi le PA o le BaNks ?
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  10. #957
    Androidiano L'avatar di crazyniko
    Ardea (RM)
    Oneplus One & Galaxy S5
    scusa Alma dove posso trovare superSU 1.80?
    grazie mille
    trovato!!! grazie lostesso
    http://forum.xda-developers.com/show....php?t=1538053
    Quote Originariamente inviato da almaximo Visualizza il messaggio
    wipe cache
    flash rom V.10
    flash superSU 1.80
    Ultima modifica di crazyniko; 27-11-13 alle 10:13
    Oneplus one 64 gb sandstone black
    CyanogenMod 12.1-20150701-Nightly - recovery TWRP 2.8.6.1
    Kernel AK.270
  11. #958
    ho provato a installare la v10 ma una volta che restarto il cell mi compare la scritta " il processo com.android.system si e' interrotto".
    allora premetto che monto questa rom dalla v1 e che non ho mai avuto nessun probblema, come sempre ho fatto un wipe parition, un wipe dalvik, ho installato la v10 le gaps del 26 il kernel r3p2 come ogni volta.
    Dove sto sbagliando?
    A cosa serve flashare il superSU 1.8?
  12. #959
    napoli
    Samsung S3 CM 11 temasek
    Domando sulla 10 bisogna mettere su le gapp del 26 Nov o posso andare avanti con quelle del 9 Nov? in cosa si migliora con la 10? io con la 9 ho trovato un buon equilibrio a parte qualche piccolo bug
  13. #960
    Sep 2010
    Quote Originariamente inviato da criiistian Visualizza il messaggio
    SuperSU non serve a niente, lo metto io per provare visto che ogni tanto qualcuno chiedeva ma la ROM ha già il suo bel root che funziona egregiamente
    tutti quei wipe non servono
    finche vai avanti con la stessa ROM in versione successive e con la stessa tipologia di gapps un wipe cache è più che sufficiente (e forse potremmo fare a meno anche di quello)
    controlla che non ci siano stati errori nel download, per scrupolo riscarica tutto
    le gapps del 26 quali stai mettendo ? le solite PA o quelle nuove di qualche post sopra ? io sto continuando con le PA
    Huawei Mate 10 Pro
    Huawei Mediapad M5
