Pagina 135 di 570 primaprima ... 3585125133134135136137145185235 ... ultimoultimo
Visualizzazione dei risultati da 1,341 a 1,350 su 5691
[Supporto MODDING] Thread di Aiuti e Consigli alle Operazioni di Modding (Galaxy S5)
  1. #1341
    Apr 2011
    Galaxy S3
    Ringraziato 116 volte in 31 Posts
    Scusate per il doppio post... ho estrapolato una conversazione....proprio adesso:
    Rickin: Hi, thank you for contacting Samsung Technical Support. How may I help you today?
    Rickin: Not to rush you, are we still connected on the chat?
    Visitor: Hi, i have a Galaxy S5 SM-900F. There is KNOX warranty (in download mode) at 0x1. I have thewarranty?
    Rickin: I understand that you are facing issues with KNOX application, is that correct?
    Visitor: yes
    Rickin: May I know the model number of your phone? You can find the model number beneath the phone's battery which generally starts with GT, SM, SGH, SCH or SPH. You can also find it from device home screen app >> Settings >> About Device >> Model number.
    Rickin: Ignore the step.
    Visitor: i want know if with KNOX at 0X1 there is the Warranty
    Rickin: Let me check, I will provide you with the required information.
    Visitor: SM-G900F
    Rickin: Thank you for providing the model number.
    Visitor: if knox is altered at 0x1...I am covered by warranty ?
    Rickin: Thank you waiting.
    Rickin: I have checked the information, when the KNOX reaches 1x1. It would void the warranty provided by Samsung.
    Visitor: my knox is 0x1.. not 1x1
    Rickin: Yes, then it would be covered under warranty.
    Visitor: when i have purchased my Galaxy S5, KNOX is 0x0, now is 0x1
    Rickin: If it reaches 1x1 it would the warranty, so there is no issues with the warranty status of you device.
    Rickin: It would be covered under warranty.
    Visitor: Thank you... and if the device is rooted?
    Rickin: Then also the device voids the terms of warranty if the device is rooted.
    Visitor: okay
    Rickin: You're welcome. Is there anything else I can assist you with?
    Visitor: if i want reset knox at 0x0?
    Rickin: There are no options to revert it.
    Rickin: It depends on how many times you root the device.
    Visitor: and you how fix this?
    Rickin: The KNOX alters to 0x1 as its rooted once, if you root the device once more it would come under out of warranty device.
    Visitor: ok, thank you!
    Visitor: no no thank you.... good night
    Rickin: As of know there are no such options available, I will surely share your feedback with appropriate department.
    *** Non dimenticare il tasto Thanks ***
    [ROM][XXALF6] ●●● RoxRom ●●● [Online][SGS3] >>> HERE!
    Mio Sito Web: roxdragon.net
    ......in riva al mare
    GalaxyS2-GalaxyS3-GalaxyS5
    Quote Originariamente inviato da roxdragon Visualizza il messaggio
    Ma dai.... Non sa quello che dice
    Il knox che io sappia, non incrementa il numero davanti e soprattutto che significa "radicato una volta si garanzia, radicato più volte, no garanzia"
  4. #1343
    Androidiano VIP L'avatar di Robertom
    Apr 2011
    Ringraziato 84 volte in 76 Posts
    Spesso mi compare questa notifica:
    Ho anche provato ad installare supersu sotto system, ma il problema non si risolve.
    Qualcuno sa dirmi come risolvere?
    Naturalmente il problema è che la applicazione di turno (nella schermata sopra è llama) non ottenendo il permesso non fa quello che dovrebbe fare.
    Samsung S8 plus
  5. #1344
    Androidiano di Riferimento L'avatar di wuby
    genova
    s6
    Ringraziato 2,211 volte in 1,665 Posts
    Quote Originariamente inviato da Robertom Visualizza il messaggio
    Ti succede con tutte le app o solo 1? Hai provato a cancellare i permessi all' app e ridarli quando la apri?
    "Se guardate in cielo e vedete una stella a forma di moto non vi preoccupate, è il SIC" cit. VR46
    "Forse gli spagnoli dovrebbero giocare un po di più a carte, così almeno si rilassano. Pero tira il culo a perdere anche a carte." cit. SIC58
  6. #1345
    Ringraziato 37 volte in 33 Posts
    Ciao a tutti, mi è appena arrivato il gs5 e volevo successivamente utilizzare il tool per avere il knox a 0. Adesso però non ho tempo di seguire la guida e semplicemente vorrei passare le applicazioni nell s5 (da s4). È un brand tim e non penso di avere l ultima versione. Posso copiarmi tutte le applicazioni e dati nel s5 oppure non ha senso perché tanto poi le perdo quando farò il robot (perché ho letto che va cambiato firmware, ma magari se il firmware che monto va già bene allora non dovrei perdere i dati) ?
  7. #1346
    Senior Droid L'avatar di lolloandro
    Feb 2011
    Ringraziato 108 volte in 86 Posts
    è la scelta migliore, onde evitare problemi
    poi se vuoi, puoi provare a flashare così com'è, e casomai formatti in seguito se riscontri noie
    Ok allora aspetto chr esca su Sammobile....
    A sto punto quasi quasi aspetto Android L e faccio prima, tutto sommato non mi pare ci siano tutte ste differenze.....
    Ferrara
    Galaxy Nexus, Samsung S5
    Ciao a tutti,
    volevo solo darvi una informazione volante.
    Nella sezione download di cyanogen è apparsa la prima nightly ufficiale per klte in caso a qualcuno interessasse
    ciao!!!
  9. #1348
    Feb 2011
    Quote Originariamente inviato da lolloandro Visualizza il messaggio
    E' uscito il firmware su Sammobile, mo lo scarico e poi provo...
    La cosa che non ho capito, i file che devo andare a sostituire del kernel, quelli nella prima pagina non ci sono quelli Wind...
    oppure è indifferente??
    Androidiano L'avatar di Evasi0n3r
    Feb 2014
    Priverno (LT)
    GalaxyAcePlus_GalaxyS5_Nexus5
    Salve a tutti, ho un galaxy s5 sm-g900f (modello europeo credo) ho la rom stock rootata con il metodo Towelroot, quali impostazioni mi consigliate per setcpu? Vorrei prestazioni e durata della batteria. Grazie, Luca.
    Inviato dal mio Samsung Galaxy s5 usando Androidiani App
  11. #1350
    Feb 2011
    Ora servono i kernel per il root, con lo script non li estrae...
    Qualche anima pia?
