Pagina 59 di 108 primaprima ... 949575859606169 ... ultimoultimo
Visualizzazione dei risultati da 581 a 590 su 1080
[ROM][DOWNLOAD] MIUI DEVELOPER MULTILANGUAGE xiaomi.eu
  1. #581
    Ringraziato 34 volte in 26 Posts
    CHANGELOG eu.5.11.05
    [System]
    Optimization - Reduced LCD flickers (Mi 4c) (11-05)
    [Phone]
    Fix - Volume could not be adjusted while making VoIP calls (11-05)
    [Lockscreen, Status Bar, Notification Bar]
    Optimization - Support setting lockscreen and floating notifications separately (11-02)
    Optimization - App notifications page displays blocked apps first (11-02)
    Optimization - Reduced status bar RAM usage (11-02)
    Optimization - Support waking device with Volume buttons (Redmi Note 2) (11-03)
    Fix - Pushing blank sides in a floating notification could not fold it in landscape mode (11-02)
    Fix - Sometimes WiFi connection was recognized as portable hotspot (11-05)
    [Home screen]
    Optimization - Optimized background color of imperfect icons (incompletely ported icons) (10-31)
    [Gallery]
    Optimization - Album sync will stop when there is less than 20% power left (11-02)
    [Music]
    Optimization - It will not exit Select mode after batch operation (11-05)
    Optimization - Unified sorting buttons' style in all categories under My music (11-05)
    Optimization - The current playing music will be displayed in visible area when entering music list from playing now page (11-05)
    Fix - Local music are not synced timely (11-05)
    [File Explorer]
    New - Support listing starred files by editing time (11-03)
    Optimization - Optimized images display method (11-03)
    Optimization - Progress status display method of compressing/decompressing etc. (11-03)
    Optimization - Changed Mi Drop category page default ordering method to descending by time (11-03)
    Fix - Thumbnails are not displayed in searching result (11-03)
    [Calendar]
    New - Added privacy policy/user agreement/Internet connection permission prompt (11-03)
    Moderatore SENIOR L'avatar di Fortinho
    Xiaomi Mi 9T
    Ringraziato 3,056 volte in 2,161 Posts
    Quote Originariamente inviato da Of_silence10 Visualizza il messaggio
    Capisco il dubbio, ma l'installazione obbligatoria tramite twrp avviene dalla 5.9.22.
    Io ho installato sia la .22 che la .29 (la 11.1 l'ho saltata) tramite updater.
    Ora la mia domanda è ma gli altri dopo che Xiaomi ha cambiato firma hanno provato ad installare la Rom tramite updater o sono andati di twrp?
    Giusto per sapere
    Purtroppo non ho in Redmi Note 2 altrimenti farei dei test io stesso, speriamo qualcuno ci risponda. Fammi sapere per l'aggiornamento di oggi, giusto per completezza.
    Quote Originariamente inviato da seibard Visualizza il messaggio
    Scusate ma se io divulgo una mia esperienza significa dare male informazione?
    Buon proseguimento e mi raccomando siate dei bravi professori.
    Quote Originariamente inviato da Fortinho Visualizza il messaggio
    Detto questo, chi ha riscontrato una cosa diversa fa benissimo a segnalarlo, l'avrei fatto anche io senza ombra di dubbio.
    Avevo anche gentilmente chiesto di farci sapere se chi ha aggiornato con Updater aveva la TWRP installata, anche se Of_silence10 ha risposto avere più riscontri è sempre positivo. Sarebbe stato più utile dare una mano, ma grazie lo stesso.
    ►---►---►---►---► REGOLAMENTO --- FAQ FORUM --- CONSIGLI PER NUOVI UTENTI --- BBCODES ◄---◄---◄---◄---◄
    ❗ Chiarimenti versioni ROM MIUI + Link + FAQ + Fondamentali ❗
    Arrow OS - Android 11
    Un grazie è sempre gradito
  4. #583
    Mar 2014
    xiaomi redmi note 2 prime
    Ringraziato 118 volte in 111 Posts
    Quote Originariamente inviato da sparda83 Visualizza il messaggio
    Buongiorno, è uscita la la versione 5.11.5 qualcuno l'ha installata e ha notato migliorie?
    devo scaricarla penso che in giornata la provo @Fortinho ho installato quasi tutte le settimanali da settembre ad oggi e da recovery mi dopo la firma privata di xiaomi senza twrp
    non riuscivo ad aggiornare. quindi sempre da twrp non posso dare il riscontro
    Ultima modifica di tonno91; 06-11-15 alle 11:17
  5. Il seguente Utente ha ringraziato tonno91 per il post:
    Fortinho (06-11-15)
  6. #584
    Ciao, io penso che la 5.10.15 abbia in qualche modo patchato la recovery standard inserendo il controllo di firma in modo stabile, ma se si è saltata quella versione poi questa patch non sia stata più applicata, ma è solo una supposizione (la recovery non viene riscritta installando le ROM in modalità standard). Quello che è certo è che i developper consigliano espressamente il passaggio per la TWRP.
    Ciao L_D
  7. I seguenti 2 Utenti hanno ringraziato lobodroid per il post:
    giacomoelia (06-11-15),Sandrino75 (06-11-15)
  8. #585
    Xiaomi Mi 9T
    Aggiornato primo post con changelog tradotto della 5.11.5.
    Quote Originariamente inviato da tonno91 Visualizza il messaggio
    È un riscontro anche questo, negativo per quanto riguarda l'aggiornamento da Updater.
    Quote Originariamente inviato da lobodroid Visualizza il messaggio
    Ciao L_D
    È una supposizione, ma dubito che sia così. Comunque le ROM MIUI hanno la possibilità di installare la MiRecovery: se apri uno zip di una ROM troverai la cartella recovery e un file nominato "install-recovery.sh".
  9. #586
    Sep 2015
    Ciao L_D
    A suffragio dell'ipotesi di Lobodroid la mia esperienza è la seguente. Sono fermo alla 5.9.18 developer su recovery standard. Per circa 1 mese l'updater mi ha segnalato la disponibilità della 5.10.8, che comunque non ho aggiornato. Poi non mi ha più segnalato le successive 5.10.x. Fino ad oggi che mi dà come disponibile la 5.11.1
    Ne deduco che le ROM successive alla 5.10.8 avessero qualche peculiarità, che a questo punto credo sia la patch alla recovery standard. Ma è solo un'altra ipotesi.
  10. #587
    Androidiano L'avatar di Of_silence10
    Sep 2015
    Ringraziato 77 volte in 55 Posts
    Aggiornato oggi tramite updater la 5.11.5 ma ho problemi con il wifi.
    in pratica non riesco a collegarmi alla mia rete.
    in dhcp non riesco a connettermi prova all'infinito.
    con ip statico si connette ma non navigo...
    soluzioni?
  11. Il seguente Utente ha ringraziato Of_silence10 per il post:
  12. #588
    Androidiano VIP L'avatar di D4xel
    Mugello, Firenze
    Xiaomi RN 3 PRO, Nokia 6680
    Ringraziato 488 volte in 421 Posts
    soluzioni?
    Provato a fare wipe cache e dalvik?
  13. #589
    Sep 2015
    Quote Originariamente inviato da D4xel Visualizza il messaggio
    Si niente.
    Ho letto su Xiaomi.eu che molti lamentano il problema wifi.
    Ho provato ad installare anche wifi fix dal play store niente.
  14. #590
    Mugello, Firenze
    Si niente.
    Allora se è un problema che anche altri con tale rom lamentano probabilmente c'è da aspettare un fix della rom stessa e/o versione successiva!
  15. I seguenti 2 Utenti hanno ringraziato D4xel per il post:
    Of_silence10 (07-11-15),tonno91 (07-11-15)
