Pagina 188 di 252 primaprima ... 88138178186187188189190198238 ... ultimoultimo
Visualizzazione dei risultati da 1,871 a 1,880 su 2511
[ZOPO 980/990/C2/C3/C7] ROM KitKat 4.4.2
  1. #1871
    Oct 2013
    Ringraziato 26 volte in 24 Posts
    Quote Originariamente inviato da leonkn Visualizza il messaggio
    Thanks for the answer, but I did not help unfortunately. When approaching the phone to ear the screen turns off, but after 2 seconds again turn on. I'm in the first post was wrong, is not caused by a screensaver and just the sensor is triggered and a couple of seconds, and then turns on the screen
    For me it worked
    I don't have enabled S2W, maybe it's this
    Ultima modifica di vayavalla; 23-10-14 alle 13:37
    Inviato dal mio ZOPO 980 QUADCORE 2/32GB con la favolosa kitkat 4.4.2 by paolothlw8 ANDROIDIANI.COM
    Oct 2014
    Hello i got a serious issue, when i lock the screen after some minutes if i try to unlock it, the phone stuck with the black screen and the only way to use it again is taking out the battery and turning on again. I've noticed that its happens when the phone gets into Deep Sleep, any solution? Now im using a tool to keep the CPU awake but it takes too much battery. I disabled the Fast Boot option but im still with the problem.
  4. #1873
    Quote Originariamente inviato da zurbran Visualizza il messaggio
    which version you have installed?
  5. #1874
    Oct 2014
    Quote Originariamente inviato da daltanius66 Visualizza il messaggio
    I got the 1.0.7 version. Do i have to try with an old one?
  6. #1875
    I had the same problem with all versions except with the 1.0.6.
  7. #1876
    Oct 2014
    Thanks daltanius66 , i will try 1.0.6 , i hope paolothlw8 can solve this its a great rom! I will check and ask sometimes if maybe someone find the solution!
  8. #1877
    Salve !!!!
    Posseggo un 980 Mod A 1gb 16gb ho installato questa rom ho notato che all'arrivo di un massaggio email o un sms non mi fa' vedere sopra all'iconcina corrispondente il numero dei nuovi sms/email.
    Complimenti x il lavoro svolto su questa rom e vi ringrazio anticipatamente
    Ultima modifica di tuttomax; 23-10-14 alle 19:01
  9. #1878
    Sep 2013
    Ringraziato 2 volte in 1 Post
    Hi, I would like to install the gravity box in my ZOPO C2 PLATINUN 16G ROM, 1GB RAM Version B, with ROM C2/Version A.
    This could be some problem?
  10. #1879
    Senior Droid L'avatar di klausnik
    LG G3 D855 32GB
    Ringraziato 81 volte in 62 Posts
    Quote Originariamente inviato da nayton Visualizza il messaggio
    Actually no, you can install as usual on other supported ROMs
  11. Il seguente Utente ha ringraziato klausnik per il post:
    nayton (23-10-14)
  12. #1880
    Sep 2013
    Hi.
    The flashled of the my camera is very poor.
    Ultima modifica di nayton; 24-10-14 alle 15:54
