Pagina 95 di 252 primaprima ... 45859394959697105145195 ... ultimoultimo
Visualizzazione dei risultati da 941 a 950 su 2511
[ZOPO 980/990/C2/C3/C7] ROM KitKat 4.4.2
  1. #941
    Jul 2014
    The kernel might be easily uploaded to, you already have an old version at github...
    As for the KK, I guess it is based on the MediaTek SDK for KK released here http : // labs. mediatek. com /site/global/developer_tools/mediatek_android/mediatek_sdk_android/index. gsp, so you can just create a diff between your codebase and the original SDK (which will be in a reasonable size) and upload to some file hosting service (or even github as a gist)
    Thanks
    Quote Originariamente inviato da keymit Visualizza il messaggio
    Thanks
    in this link there is a 250MB zip file...is not the same thing
    from readme inside the zip
    codice:
    This is the initial release of MediaTek SDK.
    Revision Date
    September 8, 2014
    Packages
    mediatek_android_sdk_api-19.3.1.zip
     * emulator - Linux and Windows executables.
     * images - Images needed by emulator.
     * libs - API libraries.
     * samples - API sample applications.
     * skins - 720p / 1080p skin for emulator.
    mediatek_android_sdk_tools-19.3.2.1.zip
     * ddms-linux-x86_64 - MediaTek customized DDMS (Linux version)
     * ddms-win - MediaTek customized DDMS (Windows version)
    MediaTek SDK API (up to Level 3)
     * Multi-SIM Telephony
     * Audio / Video
     * Camera MAV
     * HotKnot
     * Portrait Enhancements
     * Image Transformation
     * Gesture
     * API Level Version Check
    for the complete rom source i have to upload the 5GB zip
    edit:
    uploading...15 hours left -.-
    Ultima modifica di PaoloW8; 23-09-14 alle 19:20
    Nubia Z7MAX
  4. #943
    Oct 2013
    Ringraziato 18 volte in 11 Posts
    Quote Originariamente inviato da aquilacd70 Visualizza il messaggio
    invece io ho provato a mettere Lenovo Camera...molto bella e con moltissime opzioni solo che fa scaldare parecchio il cell e l'app Clean Master mi dice di disinstallarla ...invece quella di Google funziona ma tra le due preferisco la stock.........approposito di Lenovo ,Paolo ti ricordi (ovviamente quando hai tempo) di guardare per una rom KK stile VibeUI?
    Effettivamente anche io preferisco la camera stock
    Comunque da oggi potrò utilizzare anche io l'architettura ART, dato che utilizzavo xposed per il menù riavvia
    Ultima modifica di Filippo1193; 23-09-14 alle 19:30
  5. #944
    Jul 2014
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    codice:
    Revision Date
    September 8, 2014
    Packages
     * Audio / Video
     * Camera MAV
     * HotKnot
     * Gesture
    edit:
    you are right, that is totally NOT what I thought it was, sorry...
    anyway, I see that you are uploading the big stuff now, thanks. I will upload to github or bitbucket (whichever allows such a huge codebase) and send you repo access in case you want to use
  6. #945
    aiuto!
    ho un grosso problema!
    ho seguito passo passo tutte le istruzioni e ho provato a installae la rom 1.0.0.4
    ma dopo il reboot finale, il cell va in loop, alternando la videata "Loading MediaTek" alla videata con le palline colorate e la scritta android....
    anche togliendo la batteria e riprovando, non cambia niente!
    cosa è successo?
    a qualcuno è successo
  7. #946
    Senior Droid L'avatar di aquilacd70
    cuneo
    One Plus X - S3 Neo
    Ringraziato 58 volte in 49 Posts
    Quote Originariamente inviato da sbuzziol Visualizza il messaggio
    aiuto!
    cosa è successo?
    É già successo, prova a installare prima la 1.0.3 con tutti i wipe e poi la 1.0.4 solo con i 2 wipe già spuntati.
    Inviato dal mio ZOPO usando Androidiani App
    One plus X spettacolare!!
    EX (zopo 980 Turbo 2/32 Rom ITG KK 4.4.2 by Paolo)
  8. #947
    ahhh
    scarico (lentamente, purtroppo) e ci provo
  9. #948
    Nov 2013
    Ringraziato 21 volte in 21 Posts
    Ciao Paolo. Torno a farmi sentire dopo un bel pò, anch'io ho avuto un brutto periodo, e mi dispiace anche per te .......
    Ho letto tutto dall'ultima volta, ci ho messo un bel pò. Ho aggiornato poco fà alla 1.0.4 dalla 1.0.0 o 1.0.1 non ricordo. Ti riporto come ho risolto il problema del bootloop, si è successo anche a mè, al primo tentativo ho fatto come al solito con i 2 wipe delle cache, al termine come mio solito ho salvato il log, si sono una persona curiosa, reboot e nada, bootloop. Lo attacco al PC e vado a guardarmi il log per capire cosa è successo e con sorpresa vedo che il file di log è 0 byte. Ripeto l'operazione più volte e capisco che se dò il reboot da aroma il log è sempre di 0 byte, se invece tolgo la spunta dal reboot in aroma e do reboot da recovery il file log è completo. Al termine di queste prove posso dirti che la Rom si installa correttamente sul mio terminale se tolgo la spunta finale al reboot in aroma. Trai tu le tue conclusioni, io ho imparato che su questi Mtk non cè verita assoluta .... Ci vorrebbe qualcun'altro che confermasse la cosa....
  10. #949
    Ma quindi se togli il reboot e poi lo fai da recovery la ROM parte e non va in bootloop ?
    Lol certo che è strano...io cmq ho sempre fatto il reboot da aroma però se è solo quello nella prossima versione posso togliere il reboot
    Nubia Z7MAX
  11. #950
    Quote Originariamente inviato da ZopoDroid Visualizza il messaggio
    Prova a riflashare la rom facendo solo wipe cache e dalvik da aroma! Ho seguito questo consiglio di paolo e ieri il problema che avevo é scomparso
    Inviato dal mio ZOPO 9xxQuad usando Androidiani App
    Ciao ho provato anche cosi ma niente da fare. Ho fatto full wipe poi 0.4 e ho il bootloop, poi full wipe e 0.3 poi wipe di tutto anche /system ecc (tutte le voci di aroma) poi ricominciato con la 0.3. Poi aggiornamento a 0.4 sia con full wipe che con solo cache e dalvik e niente.
    Cosa strana è che quando accendo mi si presenta lo splash iniziale della vecchia ROM (di marsapa).
    Qualcuno sa dirmi qualcosa?
