Pagina 59 di 73 primaprima ... 949575859606169 ... ultimoultimo
Visualizzazione dei risultati da 581 a 590 su 725
[ROM] CyanogenMod 7 Gingerbread (unofficial porting)
  1. #581
    Androidiano L'avatar di EmaxDj
    Dec 2009
    San Severo
    Oh grazie mille ragà (nel lockscreen lo sapevo già XD) Figata la Status Bar *_* peccato non ci sia comunque una scritta numerica...l'avrei tenuta!
    CyanoGENiano DOC
    乇 ʍ Д Ҳ
    Motorola Milestone Modded
    Sep 2010
    aversa
    MEIZU M2 NOTE
    Quote Originariamente inviato da Vinsent Visualizza il messaggio
    Dalla 7.1.0 dell' 8/10 le rom sono "odexed" e sul sito è indicato di fare il wipe di cache e dalvik. Inoltre su XDA avevo letto che poteva dare problemi con i temi personalizzati.
    Non ti spiego il termine "odexed" perchè nè ho solo una vaga idea...
    La percentuale si può visualizzare anche nella lockscreen:
    impostazioni -> cyanogenmod -> lockscreen -> opzioni widget -> visualizza sempre stato batteria
    ciao
    vinsent in quanto al termine odexed ho trovato questo :
    A .dex file is basically a compiled bytecode version of an app that has been built for the Dalvik VM which Android's apps run on. I believe it is short for Dalvik Executable, but I'm not sure if I'm remembering that correctly.
    An .odex file is an Optimized .dex file (hence the 'o'), meaning that it has basically been pre-compiled for a specific platform. The advantage to this is that startup time is much faster since the VM doesn't have to perform any optimizing at startup/runtime. The disadvantages are 1) That it takes up some extra space and 2) An odexed app won't run properly if it's put onto another device, and it must have the associated .odex file to run at all.
    ROMs are typically released in deodexed form because they can be themed and modified fairly easily, whereas theming/modifying an odexed ROM is basically impossible (at best things would crash like crazy). Some people also choose to release their ROMs in odexed versions for people who would prefer the performance gains.
    Most of the stock ROMs I've seen are odexed, I assume because the carriers/manufacturers want the performance boost. They also don't have any kind of official theming methods, so they probably don't care if you can't change the colors of your status icons or your system text or whatnot. Plus they have the advantage of knowing what device they want their system to run on, so they can pre-compile the .odex files very easily, I imagine. As an added bonus, it makes it difficult to pull .apk files off of the device and share them with people.
    Edit: Since I just realized that I was not very explicit about the difference here - an "odexed" ROM is one where the apps have been precompiled, and thus contain associated .odex files which are external to the .apk files. A "deodexed" ROM is one where data that would be optimized in the .odex files has been more or less merged back into the .apk files (meaning it is not optimized but basically platform agnostic), thus the .apk files are self-contained and there are no .odex files. This is usually just done with a deodexing utility, such as smali/baksmali.
  4. #583
    Oct 2010
    Avevo letto proprio le righe che hai riportato...ma con quel poco di inglese che so, senza tradurre o approfondire...tanto la rom funziona alla grande anche se rimango ignorante
    Comunque è da un pò che non esce un nuovo update, spero tanto che nadlabak stia lavorando su ICS...
  5. #584
    Androidiano L'avatar di terence
    Apr 2011
    Galaxy Note 4 Motorola Xoom 3G
    Ragazzi ho installato la nuova relase la KANG e venivo dalla precedente.. ma mi sta dando molti problemi tipo a livello di touch che non corrisponde e a volte non risponde proprio... a voi è capitato? un altro problema me lo da con lo sfondo bianco quello con i sassi classico mi appare tutto sfocato nel menu! a volte per interrompere una chiamata devo togliere la batteria!
    Cosa assurda mai capitato con la cyano...
    Peccato perchè questa rom mi piace.
    Grazie a tutti!
    Galaxy note 4 - Samsung Galaxy Nexus - Motorola Xoom 32GB 3G
    Addio vecchio è stato bello finche è durato Motorola Milestone root e cyanogenMod 7!
    Non bisogna essere bravi dobbiamo essere i migliori!!
  6. #585
    Mar 2010
    Ringraziato 58 volte in 52 Posts
    Come può star lavorando su ICS se Google non ha ancora pubblicato i sorgenti? Ma soprattutto se di conseguenza non esiste ancora Cyanogenmod 9?
    Ricordiamoci che quello di Nadlabak è un "porting" di Cyanogenmod 7.
    Cyanogenmod 9 uscirà a febbraio circa.
    Poi, non avremo ICS perché:
    - E' già tanto se abbiamo GB, visto che con bootloader bloccato siamo costretti a tenere il vecchio kernel 2.6.32.9 (la base di Froyo). Con quel kernel ICS non può funzionare.
    - Il Milestone ha poca RAM, ma non solo, ha anche una scarsa memoria interna. Già Nadlabak sta facendo i salti mortali per ottimizzare il poco spazio che abbiamo (vedi l'ultima trovata del deodexed).
    Personalmente sono contento già così, perché dal mio Milestone sto tirando fuori veramente tanto, quanto non avrei potuto immaginare.
    Il prossimo passo sarà, fra pochi mesi, comprare quella bestia dell'HTC Doubleshot (o "T-Mobile MyTouch4G Slide"), 768 MB di RAM e 1,2 GHz dual core a meno di 400 euro dagli U.S.A.. e bootloader sbloccato!
    Il Milestone è stato un buon inizio per conoscere il mondo del modding, ma mai più terminali con bootloader bloccato.
    Quote Originariamente inviato da terence Visualizza il messaggio
    Grazie a tutti!
    Io non ho nessun problema. Prova a fare un wipe cache e un wipe dalvik, e magari a riflashare l'ultima release.
    Comunque non serve togliere la batteria, se premi alt destro-shift sinistro-del ottieni lo stesso effetto senza aprire lo sportellino della batteria.
    Ultima modifica di Blash; 08-11-11 alle 14:20
    HTC One CM11
    Nvidia Shield
    Firmware stock, KK 4.4
    Sandisk 32 GB Class10 MicroSD
    Ex: Motorola Milestone @1GHz CM9 by Nadlabak
    Samsung Galaxy S2 OmniROM (KK 4.4.2)
  7. #586
    Motorola Milestone
    Sono uscite due nuove versioni!! Ho scaricato l'ultima qualche ora fà... Per ora tutto ok, mi pare anche la ram disponibile sia aumentata. Per ora ho anche tolto Superchareged, pare che non ce ne sia più bisogno!
    Motorola Milestone
    Cyanogenmod 7.1.1 Kang
    Open recovery Androidiani 1.4.6
    ICS loockscreen blu
  8. #587
    Sep 2010
    aversa
    MEIZU M2 NOTE
    BLASH hai perfettamente ragione ma ti vorrei ricordare che anche GB per noi sembrava solo un sogno quindi anche sè sembra impossibile io ci voglio (anche sè in piccola parte) credere che verso inizio 2012 avremo ice cream sandwich sul nostro pietrone
  9. #588
    Oct 2010
    Brutte notizie: xda-developers - View Single Post - Ice Cream Sandwich For Milestone
    L' unica speranza è che quando si completa l' acquisizione di Motorola da parte di Google rilascino le chiavi del bootloader, ma ci credo veramente poco.
  10. #589
    Mar 2010
    Ma quali notizie? Sono cose che ho sempre saputo e ho già detto
    Kabaldan ci ha fornito una spiegazione più dettagliata.
    HTC One CM11
    Nvidia Shield
  11. #590
    Oct 2010
    Se permetti, un' affermazione di Kabaldan sulle future release della cyano per il milestone è una notizia.
