Pagina 244 di 627 primaprima ... 144194234242243244245246254294344 ... ultimoultimo
Visualizzazione dei risultati da 2,431 a 2,440 su 6265
[ROM][KK 4.4.x] Stock modded by Cuoco92 per Nubia Z7 Mini [NX507J]
  1. #2431
    Senior Droid L'avatar di kerbero
    Nubia Z7 Mini
    Ringraziato 63 volte in 51 Posts
    Quote Originariamente inviato da Foxxx3 Visualizza il messaggio
    I did also the wipe after the flashing.
    Maybe recovery used?
    Oct 2014
    Ringraziato 30 volte in 22 Posts
    Quote Originariamente inviato da kerbero Visualizza il messaggio
    Io l'ho installata da CWM senza nessun problema.
    Puoi flashare tranquillamente la recovery al posto della TWRP.. Penso che utilizzerai il programma consigliato da cuoco..
    Grazie Kerbero. Allora ri-flasho la CWM con Flashify. E incrocio le dita sperando riparta il tutto.
  4. #2433
    Aug 2014
    S6 duos G920FD
    Ringraziato 132 volte in 112 Posts
    I think so @kerbero ....
    @Foxxx3 you have to change recovery, TWRP or CWM...
    I don't know if you can change it from Rayglobe recovery which I never used, by the way you could push TWRP or CWM recovery via ADB-Fastboot commands.
    See tutorial on #1 post of this thread...
  5. #2434
    Nov 2014
    Quote Originariamente inviato da frobenius68 Visualizza il messaggio
    ok, thanks. I will give it a try this evening.
  6. #2435
    Nov 2014
    Ringraziato 3 volte in 1 Post
    Ma perchè?
  7. #2436
    Aug 2014
    S6 duos G920FD
    Here is the above said translated guide :
    How to instal cwm recovery
    First of all download this (ADB-fastboot app):
    https://www.dropbox.com/s/kq2w7x9f3j...Z7Mini.7z?dl=0
    Download and install USB driver, if necessary, from link below:
    https://www.dropbox.com/s/1kv769erec...rivers.7z?dl=0
    Connect phone to pc.
    Copy recovery file (.img) to folder 'ADB-Fastboot_Z7Mini' then rename it 'recovery.img'
    Launch adb_cmd.exe
    Type adb reboot bootloader ,to boot phone in fastboot mode
    Now install CWM recovery typing:
    fastboot -i 0x19D2 flash recovery recovery.img
    Then reboot into recovery typing:
    fastboot -i 0x19D2 reboot-recovery
    It's done!
    Edit: donwload link for CWM recovery image: https://www.dropbox.com/s/xlx674aiq3...2.img.zip?dl=0
    Ultima modifica di frobenius68; 14-11-14 alle 15:39
  8. #2437
    Androidiano L'avatar di ciencio
    Parma
    nubia z7mini
    Quote Originariamente inviato da Shikaiya Visualizza il messaggio
    Ti arriva rootato con la ROM di Cuoco92, magari alla versione 1.62
    non proprio, c'e' la cwm di cuoco92 ma la rom e' la 9.42 parzialmente tradotta.
    Android: 5.1.1
    UI Nubia: V4.0
    ROM: NX507J_V3.95_ROW_CCUOCO92
  9. #2438
    Parma
    nubia z7mini
    Quote Originariamente inviato da Fr3zzy Visualizza il messaggio
    Ma perchè?
    stesso errore, ho risolto con la TWRP
    Android: 5.1.1
    UI Nubia: V4.0
  10. #2439
    Oct 2014
    Allora la CWM non va bene per la rom di Cuoco. Mi pareva di ricordare qualcosa...
  11. #2440
    Parma
    nubia z7mini
    Quote Originariamente inviato da Shindaiwa Visualizza il messaggio
    Cuoco e altri dicono di installare da CWM, cio' nonostante io ho dovuto per forza installare TWRP
    Android: 5.1.1
    UI Nubia: V4.0
