Google translate
Ho la possibilità di inizializzare in HDD Raw Copy dei dispositivi di memorizzazione USB Qualcomm MCC con stile di partizione MBR.
È che una saggia idea.
Se guardo attraverso HDD Raw è il mio dirver buono e la gestione dei dispositivi ancora QHSUSB_BULK
You must install driver....you can try to load from hdd raw copy recovery.img....
Inviato dal mio z7 max 48000 antutu usando Androidiani App
When i understand you correctly i have to write the file recovery.img from the directory Nubia_Z7_Max_Multi to mine device?
jan you can use a recovery of z7 max..you can extract recovery.img of the rom posted in first page....You have to change the id hardware of the device....then you may install the driver...
I downloaded the file z7max_nx505j_线刷包(1) on the first page.
I should write recovery.omg to mine device with HDD Raw Copy
Where and how can I change the ID of the Hardware?
Yes you should write recovery.img on your device with hddrawcopy only so you can change the id ...
recovery written
how can i change the id
id change only if you write with hddrawcopy boot or recovery.img .... Try and try to install driver....you can try to hold power button and + ,- for 18 second, power button only for 14 second...
I got a headache. Hardware ID is stil 19.
I wil try tomorow, I can not accept (yet) that mine Z7 is dead,
In HDDrawcopy is get an qeustion to initialize the drive. See picture. Is that a way to go?
The manager sometimes see mine phone as YUNOS phone.
Oneplus+?????
Molte grazie che sei un "imbecille" come me vuole aiutare.
Ultima modifica di Jan1959; 07-02-15 alle 22:12
- Motivo: more information
- Non puoi inserire discussioni
- Non puoi inserire risposte
- Non puoi inserire allegati
- Non puoi modificare i tuoi messaggi
Regole del Forum
