Pagina 7 di 68 primaprima ... 567891757 ... ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 676
[KERNEL] Nuovo Custom Kernel Per GT-S7500 by Lox
  1. #61
    Samsung Galaxy Ace Plus
    Ringraziato 271 volte in 209 Posts
    Quote Originariamente inviato da imre Visualizza il messaggio
    prova ad aumentare la soglia del kernel panic
    Con che valore?
    ROM: CyanogenMod 11 by DirtyDev
    KERNEL: 3.0.101 Dirty Kernel
    E se ti sono stato d'aiuto non dimenticare il tasto thanks
    Androidiani Power User L'avatar di imre
    Bologna
    Nexus 5
    Ringraziato 1,000 volte in 466 Posts
    ecco il mio script, stasera ti posto i file
    codice:
    #!/system/bin/sh
    /data/data/ccc71.pmw/sysctl -w fs.file-max=524288
    /data/data/ccc71.pmw/sysctl -w fs.inotify.max_queued_events=32000
    /data/data/ccc71.pmw/sysctl -w fs.inotify.max_user_watches=10240
    /data/data/ccc71.pmw/sysctl -w fs.lease-break-time=10
    /data/data/ccc71.pmw/sysctl -w kernel.msgmax=65536
    /data/data/ccc71.pmw/sysctl -w kernel.msgmni=2048
    /data/data/ccc71.pmw/sysctl -w kernel.panic=10
    /data/data/ccc71.pmw/sysctl -w kernel.random.read_wakeup_threshold=128
    /data/data/ccc71.pmw/sysctl -w kernel.random.write_wakeup_threshold=256
    /data/data/ccc71.pmw/sysctl -w kernel.sched_latency_ns=18000000
    /data/data/ccc71.pmw/sysctl -w kernel.sched_min_granularity_ns=1500000
    /data/data/ccc71.pmw/sysctl -w kernel.sched_wakeup_granularity_ns=3000000
    /data/data/ccc71.pmw/sysctl -w kernel.sem='500 512000 64 2048'
    /data/data/ccc71.pmw/sysctl -w kernel.shmmax=268435456
    /data/data/ccc71.pmw/sysctl -w kernel.threads-max=524288
    /data/data/ccc71.pmw/sysctl -w net.core.rmem_max=524288
    /data/data/ccc71.pmw/sysctl -w net.core.wmem_max=524288
    /data/data/ccc71.pmw/sysctl -w net.ipv4.tcp_rmem='6144 87380 524288'
    /data/data/ccc71.pmw/sysctl -w net.ipv4.tcp_tw_recycle=1
    /data/data/ccc71.pmw/sysctl -w net.ipv4.tcp_wmem='6144 87380 524288'
    /data/data/ccc71.pmw/sysctl -w vm.dirty_background_ratio=70
    /data/data/ccc71.pmw/sysctl -w vm.dirty_expire_centisecs=250
    /data/data/ccc71.pmw/sysctl -w vm.dirty_writeback_centisecs=500
    /data/data/ccc71.pmw/sysctl -w vm.drop_caches=3
    /data/data/ccc71.pmw/sysctl -w vm.min_free_kbytes=4096
    /data/data/ccc71.pmw/sysctl -w vm.swappiness=35
    /data/data/ccc71.pmw/sysctl -w fs.inotify.max_user_instances=256
    Alchemy ROM per Samsung Galaxy Ace Plus
    se vuoi ringraziarmi usa il tasto thanks
  4. #63
    Salve ragazzi,ho provato il nuovo kernel e va abbastanza bene,unica pecca che ho trovato è che registrando video vanno poi lenti nella riproduzione usando i lettori esterni tipo real player mentre con il lettore integrato nemmeno si aprono..è capitato anche a voi??
    Inviato dal mio GT-S7500 con Tapatalk 2
  5. #64
    Androidiano VIP L'avatar di Giugiu19
    Porto Torres
    Galaxy S5mini (SM-G800F)
    Ringraziato 698 volte in 354 Posts
    A me i video vanno e uso vlc come player
    Inviato dal mio GT-S7500 usando Androidiani App
    Seguimi su Twitter per informazioni su nuove uscite e aggiornamenti!@Giugiu19
    per chi vuole donare per sostenere lo sviluppo
  6. #65
    Ho provato vlc e nemmeno si aprono..allora devo aver sbagliato io qualcosa..forse perché non ho fatto il wipe data??Ma avevo paura di perdere qualcosa di personale tipo rubrica,messaggi,musica ecc..gli altri wipe però li ho fatti..può essere per quello??
  7. #66
    Behind you
    SGAP + Nexus 7
    Ringraziato 73 volte in 62 Posts
    Quote Originariamente inviato da Ernguevaradelaserna
    A me va senza aver fatto il wipe data, ma è sempre meglio farlo...
    Inviato da un dispositivo di cui non conosco la provenienza...
    GT-S7500 - CM10.2 DirtyDev
    Nexus 7 2012
    CyanFox 2.0.1
    WHAT DOES THE FOX SAY?
    LOL
  8. #67
    Quote Originariamente inviato da troll4 Visualizza il messaggio
    Non ho video da provare... Ma appena posso vi faccio sapere qualcosa
  9. #68
    Basta che ne registri uno con il telefono stesso..
  10. #69
    Con vlc e il lettore interno alla videocamera funziona benissimo
    EDIT: Ho trovato un backport del row-iosched per il kernel 3.0.x... Da quel che sono riuscito a vedere da una rapida scorsa del codice mi pare si avvicini di più alle "nostre" (del kernel 2.6.x) necessità, dovrei essermi facilitato il compito...
    Volevo ancora chiedere se avevate necessità particolari per i governors (ce li ho quasi tutti sotto mano, quindi li posso aggiungere), aggiungere, togliere, sostituire... Per il resto mi sa che si continuerà a lavorare sull'OTG
    Ultima modifica di loxdegio; 01-06-13 alle 15:44
  11. #70
    GALAXY ACE PLUS
    Ringraziato 31 volte in 23 Posts
    Cos'è l' OTG.. scusa la mia ingenuità D:
