Pagina 1 di 214 1231151101 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 2136
[GUIDA] [PHILZ KERNEL] ROOT + CWM da RECOVERY STOCK o da odin, No BrickBug
    Link alla discussione su XDA: Safe Stock Kernel+CWM6, No BrickBug, Root
    INDICE DI THREAD:
    1. Post 1 ==> Presentazione kernel
    2. Post 2 ==> Istruzioni istallazione e link download
    3. Post 3 ==> Menł speciale PhilZ e NOTA per i NANDROID BACKUP CON FIRMWARE E ROM JELLY BEAN (preload)
    Vi presento il PhilZ-cwm6 - Safe Stock Based Kernel. Questo č un kernel stock a cui sono state eliminate le righe di comando killer cosģ da non incappare nel BRICKBUG delle 4.0.4
    il kernel una volta flashato vi abiliterą i permessi di root e vi istallerą la recovery CWM touch.
    Quote Originariamente inviato da Phil3759
    Features
    KERNEL
    Patched kernel to avoid brick bug issues on ICS 4.0.4
    PhilZ Touch Recovery: enhanced clockworkmod 6 full touch based recovery
    Pure stock kernel (only ramdisk changes)
    Can be flashed in Stock Recovery (root + no yellow triangle) or in Odin
    Init.d and customboot.sh support
    Introduced support for custom MULTI bootanimation (bin and zip)
    Dual USB mount in recovery support
    ADB root in recovery: just wait about a minute to activate
    RECOVERY TOUCH
    touch interface:
    - toggle between 3 touch modes: FULL TOUCH, DOUBLE TAP to validate and SEMI TOUCH (scroll but no touch validation)
    - written from scratch full touch code
    - safe full touch : no wrongly validations while scrolling
    - when you set full touch mode, it defaults to optimized settings for menu height, scroll sensitivity and touch accuracy (you still can alter them manually later)
    - adjust scroll sensitivity in a huge palette
    - adjust menu height in a huge palette
    - adjust touch accuracy
    - 27 color settings for each of the 6 GUI parts + 5 alpha transparency settings
    - user custom background png can be selected in addition to 27 solid colors option
    - show / hide background icon
    - show / hide bottom virtual buttons
    - show/hide + set color and transparency for menu line separators to match solid color themes, like Black...
    - set number of bottom log rows to show
    - Friendly Log View and pause on logs: no more miss logs during zip installs
    - auto dim screen after user configurable delay
    - auto turn off screen after user configurable delay
    - adjust brightness and turn off screen with a gesture action
    - show/hide clock and remaining battery %, even during nandroid operations
    - clock and battery stats now effectively refresh every 30 seconds and during nandroid operations
    - toggle vibrator on/off when using bottom virtual buttons
    - toggle key repeat for volume up/down scrolling when maintained pressed
    - set time zone + 30mn offset: correct time can now be set for nandroid backup path and clock
    - capture recovery screen shots with a gesture action
    - one file to save all settings
    - backup and restore settings file
    - reset to default settings option
    - prompt to restore your settings from a backup when they are wiped by a new ROM install
    - option to auto restore your settings from a backup without a prompt
    - all toggles are applied live, without restart of recovery (except reset of stock CWM background image)
    - toggle menu options are automatically right aligned and menu text left aligned based on device display size
    - configurable gesture actions: double tap, slide right/left, long press/lift, long press/move, can be associated with any of: show log, change brightness, blank screen, capture screen shot, launch Aroma File Manager
    Note: after scroll, first touch will select only, second touch will validate: this is by design and not a bug. It is there to limit erroneous validation while scrolling
    browse phone with root access using full GUI in Aroma File Manager
    terminal access from recovery with root access through Aroma File Manager
    Multi Zip Install menu: check multiple zip files to install in a row
    Custom Install Zip Mode: set a default folder to start with + browse backward up to the root
    exFAT + ext4 support in recovery for external sd
    TWRP backup and restore support, include full md5 sum support (single and multivolume, compressed and non compressed formats)
    support .android_secure backup/restore from external storage and exfat partitions
    optional reboot after custom backups/restores
    sd-ext support (ext4)
    nandroid backups support /preload in backup and restore jobs (custom and stock backups)
    set special nandroid settings: time zone, toggle md5 check for lightning fast backup and restore, toggle /preload backup and restore, enable nandroid compression using pigz (multi-cpu gzip compression) and choose ors backup target volume
    you can cancel any nandroid operation with back button
    create custom_rom.zip from current ROM or from a pre-existing nandroid backup (based on boot, /system and optionally /preload)
    nandroid backup path now will be named with current ROM id from build.prop (ro.modversion, then ro.romversion, then ro.build.display.id)
    custom backup and restore job list: backup and restore freely any partition combo (include modem and efs) from old nandroid folder or new custom_backup one
    custom restore option to browse from /sdcard/0 (android 4.2 workaround)
    backup/restore EFS in both tar + img formats, now with time incremented copies for both tar and .img
    support flash modem.bin image files in addition to custom modem.img files, now support for multiple *.bin versions under dedicated folder
    during custom restore, you can see the contents of the folder you want to restore from
    delte custom or TWRP backups from recovery menu
    full wipe before flashing new ROM: wipe user data + format /system and /preload. SD card content is not affected
    full support for openrecovery script specifications include all backup and restore options
    run openrecovery scripts in 3 modes: on start goomanager boot scripts + one touch menu to either directly open a default path or freely browse for scripts
    define ors backup target volume from within Nandroid Settings menu
    ors restore path supports stock clockworkmod path, TWRP path and custom_backup path
    poweroff, reboot to recovery and reboot to download mode options
    dual USB mount in recovery support and mount external sd over usb for /data/media devices
    adb root in recovery: just wait about a minute to activate
    detailed build info in About menu
    Credits
    • Chenglu for his great unpack / repack tool: MAJOR CREDITS
    • kbc-developers for the base semi-touch code :good:
    • Gokhanmoral@Siyah for his touch source and great support over PM in fixing dual USB mount: MAJOR CREDITS
    • Tallustus from Team Skyfire for his great support over IRC: MAJOR CREDITS
    • sk8erwitskil for his recovery source (ors support, aroma file manager and efs backup/restore), a great place to start learning: MAJOR CREDITS
    • shoe63 for his testing and great help in porting to the N7000 Big thanks
    • dr.ketan for his precious help in porting to the N7000 (I don't own one), for support in the thread and for his faster mirrors: Big thanks
    • utkanos for his great and kind support over IRC
    • gweedo767 @ #Koush for sharing his new touch code source (not yet used)
    • myfluxi for his xxRecovery source in fixing dual usb mount
    • Koush for his great work on CWM6 and CM
    • Cyanogenmod for their scripts / initramfs
    • Chainfire for his support (stock recovery flash) and all his work for the Android community
    • superatmos and Dharam_Maniar for their great guides on unpacking/building custom kernels
    Ultima modifica di Anna; 10-04-13 alle 16:20
  2. I seguenti 83 Utenti hanno ringraziato Anna per il post:
    6pudu5 (04-06-13),adelmodesmo (29-11-12),agrib82 (19-10-13),Al3xDroid (20-03-13),alemei91 (08-02-13),amicog (18-03-13),Andry96 (13-07-13),angiotell (15-02-14),ataru moroboshi (21-11-12),berner64 (11-05-13),biska (31-05-14),bluciano (29-08-13),bluflight13 (22-11-12),bollesan (04-06-13),boomby78 (22-11-12),brogi87 (14-02-13),Brrmatteo (07-07-13),cellax (23-02-13),clashfloyd (04-12-14),cotechinho (22-04-14),crasso (15-11-14),crisgen (23-11-12),Cupo72 (02-12-12),dado72 (16-03-13),Daha601 (13-02-13),Darčios89 (02-10-14),dav010 (18-02-13),diavolo78 (22-11-12),edosossi (06-01-14),FABIOT84 (28-09-14),Fenomeno82 (27-02-13),Followotto (21-11-12),fpego (19-02-13),FraFX (09-05-14),fransis1981 (29-03-13),FuSer (09-01-13),gerrystyle (08-05-14),Gg636 (08-07-13),gianluca3392 (15-04-13),greg123 (09-01-15),Gribodo (03-09-13),housepabldroid (03-06-13),illuminato67 (21-11-12),iscio (30-03-13),jackdaniel80 (01-05-14),Kreien (16-03-13),ldoublel (17-02-15),Leo2589 (21-11-12),Lorenzo_Ace (27-04-13),lucaponze (19-10-13),ludorexmundi (03-12-12),luigimak (27-11-12),lupin 78 (23-06-13),madaal (24-11-12),marco69 (25-03-13),maxdelco66 (04-05-13),memphis (16-02-13),mescal67 (22-11-12),mimmok4 (23-03-13),Misterx86 (21-11-12),Mo3bius (13-01-14),MrMat (02-06-13),msquared (21-11-12),myrianto (10-03-13),N1m0Y (23-01-13),NiloGlock (28-06-14),Ofelia (02-12-13),offtopic (21-12-12),optimus77 (03-04-13),OrnyXD (31-05-13),Pein666 (18-11-13),Rape (12-12-12),salvo811981 (23-11-12),SalvoCT (11-02-13),scimmia01 (07-06-13),sghisciu (13-12-12),Skyman1 (17-03-13),Starblaster (20-02-13),STEULM (23-11-12),UrbanMan (01-07-13),Valerius1995 (13-02-13),Yuzathecloud (11-03-13),zeven (16-01-13)
    QUALE KERNEL DEVO SCEGLIERE?
    digitate da tastierino numerico *#1234# e controllate cosa riportano le ultime tre cifre del PDA
    La versione di kernel per il vostro firmware corrisponde a quelle tre lettere.
    COME FACCIO AD INSTALLARLO?
    METODO DA RECOVERY STOCK senza triangolino e senza aumentare il counter (CONSIGLIATO).
    Per telefono stock.
    • Digitate da tastierino numerico *#1234# e controllate cosa riportano le ultime tre cifre del PDA poi scaricate il kernel in formato .ZIP per recovery stock che vi corrisponde
    • Mettete lo zip appena scaricato nella sd card esterna
    • Riavviate in recovery STOCK (volume up+home+power)
    • Selezionate "apply update from external storage".
    • Selezionate il file precedentemente messo nella memoria
    • A questo punto avete rootato il vostro cellulare
    METODO DA MOBILE ODIN PRO senza counter e triangolino.
    Per telefono con solo root.
    • Digitate da tastierino numerico *#1234# e controllate cosa riportano le ultime tre cifre del PDA poi scaricate il kernel in formato .ZIP per RECOVERY STOCK che vi corrisponde
    • Mettete il pacchetto appena scaricato nella sd card
    • Selezionate in "open file" di mobile odin pro il file della recovery
    • Premete su "flash firmware" e sui successivi pop up di avvertimento che compariranno
    • Attendete che faccia il flash e che si riavvii
    METODI DA ODIN per PC e da recovery CWM
    ATTENZIONE:
    La versione per recovery stock in formato .ZIP vi da la CWM touch e il root
    La versione .TAR invece vi darą solo la recovery CWM touch e dovrete flashare anche il pacchetto che trovate nelle istruzioni di istallazione con odin (che istalla anche la busybox)
    Se della versione ci sono sia signed che fixed:
    La versione FIXED č per chi provenendo da kernel custom ha dei bootloop.
    Per chi viene da stock deve usare la SIGNED o la versione per ODIN
    Se invece esiste una sola versione usate quella
    Per aggiornare la versione del kernel?
    Se volete aggiornare la recovery basta flashare la nuova versione, che sia da recovery o da odin
    ATTENZIONE:
    Mi sono accorto solo ora che lo sviluppatore non vuole link diretti ma vuole che si rimandi al suo thread:
    << Posting direct links to below files is not allowed. Please post links to this thread/post instead >>
    Quindi d'ora in poi non verranno messi pił i link per il kernel. Li scaricherete direttamente da xda.
    DOVE TROVO I LINK?
    Link alla discussione su XDA: Download
    Ultima modifica di Anna; 15-05-13 alle 11:01
  5. I seguenti 34 Utenti hanno ringraziato Anna per il post:
    Al3xDroid (20-03-13),alterego1026 (06-09-14),brogi87 (14-02-13),Brrmatteo (11-04-13),cotechinho (22-04-14),crasso (15-11-14),Daha601 (13-02-13),danynitro92 (17-04-14),Darčios89 (02-10-14),diavolo78 (26-03-13),FABIOT84 (28-09-14),Fabryzio12 (20-12-13),Gahara (01-10-13),gdarius (14-12-13),Gg636 (08-07-13),Ghost_01 (02-01-16),gianluca3392 (18-04-13),giorgiog1 (20-12-12),greg123 (09-01-15),Kreien (16-03-13),l2jalbe (15-04-13),luigimak (27-11-12),lunonnato (01-03-14),Misterx86 (22-11-12),myrianto (10-03-13),N1m0Y (23-01-13),nitrofuels2 (09-12-13),Ofelia (02-12-13),onidjkd (21-02-13),Pein666 (18-11-13),Robertom (25-11-12),salvo811981 (23-11-12),Valerius1995 (13-02-13),zeven (16-01-13)
  6. #3
    MENU' PHILZ SETTING/SPECIAL BACKUP & RESTORE ALL' INTERNO DELLA RECOVERY CWM PHILZ:
    Attenzione, queste non servono per flashare il philz la prima volta per ottenere il root ma sono un metodo per flashare modem o kernel in formato .IMG
    Per le istruzioni di root seguite quelle al post 2
    Come vedete dalla figura le operazioni da fare sono diverse, backup & restore di kernel e cartella efs (nella memoria esterna e interna) e il flash di modem e kernel in formato .bin.
    Vediamo ora come flashare un kernel o un modem in formato .bin
    I file flashabili devono avere estensione .bin e li trovate estraendoli da pacchetti zip o tar. Potete anche cambiare il nome dei file per distinguere le varie versioni, l' importante č che l' estensione rimanga .bin
    Istruzioni flash Kernel
    • Creare (se gią non l'avete) una cartella di nome clockworkmod
    • Al suo interno create una cartella di nome .kernel_bak
    • Mettete all'interno il file con estensione .bin del kernel da flashare
    • Entrate in recovery CWM PHILZ
    • Selezionate philz setting
    • Selezionate special backup & restore
    • Selezionate flash Kernel from sd
    • Trovate e selezionate il file del kernel con estensione .bin e poi selezionate il flash
    • Tornate indietro nel menł e riavviate
    Istruzioni flash modem
    • Al suo interno create una cartella di nome .modem_bak
    • Mettete all'interno il file con estensione .bin del modem da flashare
    • Selezionate flash modem
    • Trovate e selezionate il file del modem con estensione .bin e poi selezionate il flash
    NOTA: NANDROID BACKUP CON FIRMWARE E ROM JELLY BEAN (preload)
    Quote Originariamente inviato da unname
    Ciao
    In merito al Philz ho scoperto questo:
    NOTA: Le ultime versioni di Philz richiedono di impostare in modo specifico il backup/restore di /preload. Si imposta dalla recovery Philz CWM:
    1. avviare la recovery Philz
    2. Philz settings
    3. Special backup and restore
    4. Misc nandroid settings
    5. selezionare /preload processing (assicurarsi che dica /preload will be processed)
    tratto da qua
    Non ho idea se nel tuo 3D relativo la guida al Philz se ne parla, nei primi post no..
    Sarebbe importante metterlo in rilievo...
    Ultima modifica di Anna; 10-04-13 alle 16:19
  7. I seguenti 14 Utenti hanno ringraziato Anna per il post:
    6pudu5 (04-06-13),brogi87 (14-02-13),cotechinho (22-04-14),Daha601 (13-02-13),FABIOT84 (28-09-14),Fabryzio12 (20-12-13),gianluca3392 (18-04-13),greg123 (09-01-15),Kreien (16-03-13),Leo88 (07-04-13),myrianto (10-03-13),N1m0Y (01-02-13),Valerius1995 (13-02-13),whytwokey (29-03-13)
  8. #4
    Localitą
    ......in riva al mare
    GalaxyS2-GalaxyS3-GalaxyS5
    una sola parola: finalmente
    ottimo jaco
    Ultima modifica di Anna; 12-02-13 alle 14:11
  9. Il seguente Utente ha ringraziato dieguccio per il post:
  10. #5
    Senior Droid L'avatar di ataru moroboshi
    Ringraziato 40 volte in 31 Posts
    Bravo Jaco!!!
    Does android deep sleep of unix based sheeps?
  11. Il seguente Utente ha ringraziato ataru moroboshi per il post:
  12. #6
    All download
    Ultima modifica di Anna; 26-03-13 alle 12:11
  13. I seguenti 4 Utenti hanno ringraziato Anna per il post:
    dahil (03-03-13),Fabryzio12 (20-12-13),Kreien (16-03-13),N1m0Y (26-02-13)
  14. #7
    Localitą
    Nokia 3310
    Vecchi link
    Bene
    Stasera la aggiungo in OP di la
    Sent from my GT-I9100
    Ultima modifica di Anna; 26-03-13 alle 12:10
  15. Il seguente Utente ha ringraziato msquared per il post:
  16. #8
    Senior Droid L'avatar di vial
    Oct 2010
    Ringraziato 34 volte in 32 Posts
    Per chi non ha SD esterna?
  17. Il seguente Utente ha ringraziato vial per il post:
  18. #9
    Quote Originariamente inviato da vial Visualizza il messaggio
    usi odin per pc ....
  19. Il seguente Utente ha ringraziato Anna per il post:
  20. #10
    Localitą
    Modena
    Samsung Galaxy S4; S2
    ottima jaco...quindi questa "sostituisce" questa [GUIDA] Permessi di ROOT su Android 4.0 (senza aumentare il counter) SAMSUNG GALAXY S2 I91001?!
  21. Il seguente Utente ha ringraziato Misterx86 per il post:
