Ormai è una vita fa. Mi ricordo solo che è stato un parto difficile e che l'ho fatto con MTK Droid Tools e/o SP flash tools. Ad ogni modo la recovery che ho e la seven max 2.7.
E' il gps secondo me.
ROOT:http://www.thlmobilestore.com/news/t...e-root-method/
After you root your phone you can install supersu from playstore and you ready.
You can also root it with the installation of twrp.
RECOVERY:http://www.needrom.com/mobile/recove...-for-thl-5000/
Download from playstore and use MobileUncle to flash recovery, place .img file into root of your memory.
you have to have the twrp-2-7-1-0-kk-for-thl-5000 recovery.img file of your phone before you flash it put them in your*sd*card
Instruction :-
1 first root your phone
2 install mobile uncle tool.apk
3 open mobile uncle tool
4 select flash recovery then select the twrp-2-7-1-0-kk-for-thl-5000 recovery
5 then reboot your done with flashing recovery
Another way to install the twrp is with the flashtool, download it from needrom also download the factory rom from needrom, run the flash tool program locate the scatter file in the factory rom then go to recovery and locate the twrp file uncheck all the files except the recovery file ,then change to download only and press download, this procedure must be done without the phone connected, after you press the download button switch off your phone then keep pressing the red reset button behind the first sim slot insert the usb cable and then release the reset button the procedure should start if the procedure don’t start it means that you’re missing the preloaded drivers of mtk.
With this way you can also installed a factory rom.
DanieleGS (30-04-15),lorispasseri (04-05-15)
Quando fate o ricevete una chiamata, durante la chiamata stessa vi appare la scritta "sconosciuto"? Avete percaso la soluzione?
Ciao, alla fine ho installato la 1.1.2. Ho usato il metodo TWRP scaricando la App dallo Störe e installando il tutto (già con root).
Però, devo dire, che il GPS (che prima fixava in un attimo ora fatica tanto).
Vado a controllare le impostazioni GPS e poi vi dico
Risolto
Ho installato il solito faster fix. Al momento sono in vasca da bagno al piano terra di palazzina da 2 piani e in 30 secondi ho questo risultato Screenshot_2015-04-30-21-15-41.jpg
Sullo store sia il faster fix che lo gps test (il plus forse su blackmart) ma credo che la versione base vada bene lo stesso.
Alla fine aveva il server del GPS su quello asiatico e con faster fix riesci a impostare il server italiano / europeo
Ultima modifica di r_esisto; 01-05-15 alle 00:05
ant0ni0 (01-05-15)
provato fasterfix ma non funge: "failure, please try again".
Ultima modifica di ant0ni0; 01-05-15 alle 00:31
