Please add to your ROM Smart Cover functional.
Thanks.
Thanks.
V14 works like a charm, so far!
Thank you very much, again .
Is it possible to move this button to the bottom?
thx a lot for your rom
but why no call recording?i remember there used to be this function
Hi. Paolo!
There is one unresolved problem. When an incoming call when the phone is in your pocket and I walk down the street, the melody plays the first 2 seconds, then turns off the sound. Rather foot screen is touched through the fabric. I think it is wrong that the screen reacts to it when the phone is in your pocket.
It turns out a serious problem. If I do not hear the call during the first 2 seconds, then miss a call because of the lack of melody.
4PDA community from Russia
you do not have the option "prevent accidental wake-up" active?
with this option if the proximity sensor is covered, the display does not turn on with the double tap
...ah wait...in incoming call....ok, tomorrow I will do some test
edit:
https://www.reddit.com/r/xposed/comm...ncoming_calls/
No, I'm saying that when there is an incoming call and the phone in your pocket, the melody is played just a couple of seconds and then it stops playing. This is due to the fact that some thin fabric clothes in his pocket and the screen touches the body through the fabric. I want to tune the incoming call has not stopped the sound when you touch the screen when the phone is in your pocket.
--- ADD
More specifically, when an incoming call comes on the screen, regardless of whether the option is on "protection against accidental contact" or not. Because of this, the skin of my legs through the fabric presses reject the call, or somewhere else and stop playing the melody.
We need to do so that the screen does not light up if the option "protection against accidental contact." And then the screen to turn on, if the phone out of his pocket. It's real? Thanks in advance!
Ultima modifica di LiveMoto; 27-09-15 alle 20:03
Hey, thnx for the great rom, everything working very well!
only my battery drains extremely fast: like 10% in 3 hours idle and 30-40% when browsing in the train for 2 hours. I am not sure if this is a ROM issue or a hardware issue as i have the phone for a week so want to try a good stock rom. How do i reset to stock from this rom? i want to try 3.22 or higher. Note the combi rom on this forum doesn't seem to work with my sim so need to flash with nubia tool but no idea how as all the guides say the tools only work from rom x to y/
Also, were can i buy a good glass screen protector? the one I have is rather thick and seems to interfere with touch a bit to mutch.
thnx for any anwser.
you can flash 3.55 with nubia tools
firmware: ROM Nubia Z7 Max v3.55 | [Official] add the 08/27/2015 on Needrom
guide to flash: ROM Nubia Z7 Max v3.09 | [Official] add the 04/28/2015 on Needrom
Good morning and thanks for the great rom.
The only problem i face is the hardware volume keys, when i press them i get the message: ui has stopped working....
Any help?
