Visualizza i risultati del sondaggio: Quale rom state usando?
Chi ha votato
46. Non puoi votare questo sondaggio
  • Io ho la rom di BB72&Cuoco92 vers. 1-3
    2 4.35%
  • Io ho la rom di BB72&Cuoco92 vers.4 installata tramite recoverry
    16 34.78%
  • Io ho la rom di BB72&Cuoco92 vers.4 installata tramite OTA
    15 32.61%
  • Io ho la rom LEWA multilingua
    4 8.70%
  • Io ho un'altra rom
    9 19.57%
Pagina 203 di 489 primaprima ... 103153193201202203204205213253303 ... ultimoultimo
Visualizzazione dei risultati da 2,021 a 2,030 su 4883
[Alcatel/TCL IdolX+/S960] Guide Root- Recovery- Rom Custom
  1. #2021
    Apr 2014
    2.6.3.0 I'm using. OK I'm trying with restart.
    Super Droid L'avatar di Cuoco92
    Sardegna
    #Z7-Z9 MAX #Z7 MINI #K3 NOTE
    Ringraziato 3,958 volte in 1,624 Posts
    Quote Originariamente inviato da spavian Visualizza il messaggio
    Did you tried it again? Has worked?
  4. #2023
    Apr 2014
    Ringraziato 7 volte in 4 Posts
    Today, I had a strange thing on v6.2, I openned whatsapp and the screen was blank for about 10 seconds, and then content appeared
  5. #2024
    Apr 2014
    It works after rebooting the recovery. The recovery is bugged, maybe put a warning on first page to all people to know what to do when install failed. Another thing , I returned to rev 5.11 because the volume in call is very low almost I can't hear what other people say. I tried with mobile uncle to up the volume but the audio settings is not here. Stupid EU rules for not damaging the hearing from high volume.
  6. #2025
    Senior Droid L'avatar di joemilan
    Italy
    Oneplus 3T
    Ringraziato 65 volte in 46 Posts
    È vero, ho notato anch'io che il volume delle chiamate è basso... Cosa si dovrebbe modificare in mobileuncles per aumentarlo?
  7. #2026
    Apr 2014
    You can't modify nothing because the setting is not here. In mobile uncle under engineering MTK, hardware testing, audio you can modify all volumes settings . In ver.6 the volumes are low because the rom is for European countries and EU have a stupid rule to keep volumes low.
  8. #2027
    Sardegna
    I'll try to fix it
  9. #2028
    Apr 2014
    Another problem, guys please tell me a music player that works with hifi active on headphones. The only one that activate the hifi sound is google music, all my other player's not working . Tune in and music player from Es file explorer is not activating the hifi sound. I need a player that play online radio and from network shares that activate the hifi sound when playing on headphones. Thank you.
  10. #2029
    Sardegna
    Io uso il programma stock della musica e nn ho nessun problema
  11. #2030
    Apr 2014
    What stock music player, I don't see one.
