Pagina 12 di 65 primaprima ... 210111213142262 ... ultimoultimo
Visualizzazione dei risultati da 111 a 120 su 643
[Ufficiale] Mediacom Winpad w801 [M-WPW801]
  1. #111
    May 2014
    Ringraziato 68 volte in 62 Posts
    nella cartella del programma
    L'ultima parte del procedimento non va a buon fine.
    Questo è il risultato:
    C:\Program Files (x86)\Minimal ADB and Fastboot>adb kill-server
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb wait-for-device
    * daemon not running. starting it now on port 5037 *
    * daemon started successfully *
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb shell mount -o rw,remount /
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb shell mount -o rw,remount /system
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb shell mkdir /system/bin/.ext
    mkdir failed for /system/bin/.ext, File exists
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb shell chmod 0777 /system/bin/.ext
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb push x86\su /system/bin/.ext/.su
    cannot stat 'x86\su': No such file or directory
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb shell chmod 06755 /system/bin/.ext/.su
    Unable to chmod /system/bin/.ext/.su: No such file or directory
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb push x86\su /system/xbin/su
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb shell chmod 06755 /system/xbin/su
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb push x86\su /system/xbin/daemonsu
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb shell chmod 06755 /system/xbin/daemonsu
    Unable to chmod /system/xbin/daemonsu: No such file or directory
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb shell mkdir /system/app/SuperSU
    mkdir failed for /system/app/SuperSU, File exists
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb shell chmod 0755 /system/app/SuperSU
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb push common\superuser.apk /system/app/SuperSU/SuperSU.apk
    cannot stat 'common\superuser.apk': No such file or directory
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb shell chmod 0644 system/app/SuperSU/SuperSU.apk
    Unable to chmod system/app/SuperSU/SuperSU.apk: No such file or directory
    C:\Program Files (x86)\Minimal ADB and Fastboot> adb shell /system/xbin/su --install
    root@WinPad:/ #
    C'è qualcosa che non va.
  4. #113
    May 2014
    se confronti il tuo log con il mio vedi che è uguale....allora ho provato tutta la procedura di nuovo senza riavviare il device e senza chiudere il prompt...prova a fare così
  5. Il seguente Utente ha ringraziato Toto71 per il post:
    peter63 (11-03-16)
  6. #114
    Quote Originariamente inviato da Toto71 Visualizza il messaggio
    La procedura non va a buon fine. c'è qualcosa nel percorso che non quadra infatti nel punto 6 della guida cioè: 6)adb push UPDATE-SuperSU-v2.46/META-INF/com/google/android/update-binary /system/update-binary ho dovuto togliere system/update-binary e il processo si è avviato, solo che l'ultimo punto cioè : 7)adb kill-server........ ecc. ecc. non va a buon fine è sempre come prima.
    Io non ci capisco più niente.
  7. #115
    Baby Droid L'avatar di konigstiger
    Ragazzi, seguendo la guida di Toto71 e RosCop che ringrazio, anch'io sono riuscito a far funzionare la procedura. Spero di dare un ulteriore contributo di semplificazione e chiarezza, postando questo riepilogo..... a prova di quelli "de coccio" come me:
    Fase 1:
    (N.B.: ai miei link va aggiunto il prefisso https perchè non sono autorizzato (ancora) a postare url)
    - scaricare "Update SuperSU 2.46" da qui: //download.chainfire.eu/696/SuperSU/
    - scaricare "Minimal ADB and Fastboot" da qui: //forum.xda-developers.com/showthread.php?t=2317790
    - eseguire il file: minimal_adb_fastboot_v1.3.1_setup.exe come Amministratore secondo normale procedura guidata
    - ad installazione terminata a buon fine, nella directory C:\programmi\Minimal ADB and Fastboot\ ci mettete sia il file "UPDATE-SuperSU-v2.46.zip" (ovvero l'intero file zip), sia l'intera cartella "UPDATE-SuperSU-v2.46" già scompattata con relative sottocartelle all'interno. In pratica nella directory Minimal vi ritroverete oltre al normale contenuto del programma (adb.exe, i files .dll, l'uninstall), anche il file zip SuperSU e la stessa cartella SuperSU già scompattata con le altre sottocartelle all'interno (se usate decompressori tipo WinRAR la cartella "UPDATE-SuperSU-v2.46" ve la crea lui, se usate 7-Zip fate attenzione a che ve la crei con il nome preciso.
    Spero che quest'ultimo punto vi sia particolarmente chiaro perchè non lo era affatto nemmeno a me prima.
    (mi spiace perchè avevo preparato un'immagine da postare ma dato che sono ancora troppo "immaturo" su Androidiani, non posso aggiungere link come già detto sopra)
    Fase2:
    dalla directory lanciare l'eseguibile adb.exe come Amministratore e si aprirà il prompt dei comandi di Windows. A questo punto procedere con i seguenti 3 comandi, uno alla volta:
    adb root
    adb remount
    adb disable-verity
    ora, e senza fare il reboot del device proseguire con questi altri 2 comandi che non dovrebbero darvi problemi se avete posizionato correttamente SuperSU come spiegato sopra:
    adb push UPDATE-SuperSU-v2.46.zip /system/UPDATE-SuperSU-v2.46.zip
    a questo punto senza chiudere il prompt selezionare, copiare e incollare tutti insieme i seguenti comandi:
    adb kill-server
    adb wait-for-device
    adb shell rm /system/bin/app_process
    adb shell ln /system/xbin/daemonsu /system/bin/app_process
    adb shell rm -r /data/dalvik-cache
    adb reboot
    (dare invio)
    Se tutto è andato come previsto al boot successivo il dispositivo è rootato e SuperSU lo trovate fra le applicazioni.
    N.B.: ricordo ancora una volta che il root invalida la garanzia, e la responsabilità dell'eseguire queste operazioni sul vostro dispositivo è solo ed unicamente vostra.
  8. I seguenti 2 Utenti hanno ringraziato konigstiger per il post:
    mrtuttle (24-04-17),peter63 (11-03-16)
  9. #116
    Feb 2016
    Konigstiger bravo stavo per postare un messaggio che spiegava come spostare e che file andassero nella cartella adb, questo passaggio aveva dato problemi anche a me e per questo motivo non riuscivo a portare a termine la procedura. Ieri a tentativi e grazie alla guida postata RosCop e Toto71 ci sono riuscito. Il mio problema stava proprio nei file da posizionare insieme allo zip. Ciao e grazie
  10. #117
    Quote Originariamente inviato da konigstiger Visualizza il messaggio
    Fase 1:
    Fase2:
    adb root
    adb remount
    adb disable-verity
    adb kill-server
    adb wait-for-device
    adb reboot
    (dare invio)
    Ti dobbiamo fare una statua. Con questa guida sono riuscito ad eseguire il Root.
    Grazie milleeeeeee !
  11. #118
    In teoria con questa procedura si può effettuare il root a qualunque tablet? Chiedo perché ho anche un tablet cinese Teclast con doppio sistema operativo e chiedevo se secondo voi è possibile fare il root.
    Inviato dal mio Elephone_P3000S-64bit usando Androidiani App
  12. #119
    Quote Originariamente inviato da rayko Visualizza il messaggio
    Edit: i ringraziamenti vanno a Toto71, RosCop e konigstiger che hanno condiviso la guida passo passo...ho sbagliato nel quotare..
    Grazie...risolto anche io con questa procedura su tutti e due i tablet presenti in casa....ma ora..quale procedura usare per spostare le app sulla SD?
    con Link2sd plus, ricevo questo messaggio di errore:
    App2SD non è supportata dal tuo dispositivo poichè ha una memoria esterna primaria che è emulata dalla memoria interna. Puoi collegare le app per spostare i loro file nella memoria SD
    sbaglio qualcosa....oppure DEVE essere in questa maniera? naturalmente ho provato a collegare l'applicazione QuickPic e funziona...anche se il file programma...rimane sul tablet.
    grato ancora per la soluzione al root e per eventuali suggerimenti per l'errore descritto sopra.
    Ultima modifica di peter63; 11-03-16 alle 15:45
  13. #120
    May 2014
    Quote Originariamente inviato da peter63 Visualizza il messaggio
    ho lo stesso problema...provato sia con appmgrII, che con all-in-one toolbox che con link2sd...proverò ancora...vediamo che ne esce fuori
