Pagina 16 di 31 primaprima ... 6141516171826 ... ultimoultimo
Visualizzazione dei risultati da 151 a 160 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #151
    Jul 2015
    I am running the V11
    I checked the adb logcat , and find that some of logs appear very frequency:
    W/ActivityManager( 890): getRunningAppProcesses: caller 10096 does not hold REAL_GET_TASKS; limiting output
    I konw this messages is because of the QQ app ( most of the chinese guys will install it) want get the list of current running apps. It looks something is wrong.
    I checked the Google and find some info about it
    https://android.googlesource.com/pla...+/aaa0fee%5E!/
    maybe it is useful for you. I can't make sure that this is the apps problem or the CM/AOSP code problems.
    I have several apps want to get the current running task lists, so if I enabled all of them my phone will never go to deep sleep and waste a lot of battery.!!
    Temperay I only enabled the app I want, and use the MyAndroidTools to disable all of evil apps.
    Ultima modifica di securecrt; 10-09-15 alle 10:44
    yes I know
    Gerrit Code Review
    apps need to be updated for the new permission
    Nubia Z7MAX
  4. #153
    Jul 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    yes I know
    Gerrit Code Review
    Can you please revert this change , I think most of the apps need time to make the new permission works.
  5. #154
    Quote Originariamente inviato da securecrt Visualizza il messaggio
    I can try but I don't know if this revert can mess up something
    Nubia Z7MAX
  6. Il seguente Utente ha ringraziato PaoloW8 per il post:
    securecrt (11-09-15)
  7. #155
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    There is one unresolved problem. When an incoming call when the phone is in your pocket and I walk down the street, the melody plays the first 2 seconds, then turns off the sound. Rather foot screen is touched through the fabric. I think it is wrong that the screen reacts to it when the phone is in your pocket.
    It turns out a serious problem. If I do not hear the call during the first 2 seconds, then miss a call because of the lack of melody.
    4PDA community from Russia
  8. #156
    link and changelog version V12 in first page
    Nubia Z7MAX
  9. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    BaSch83 (15-09-15),jadar (16-09-15)
  10. #157
    Feb 2014
    V12 does not start , remains hanging entering short in the PIN and restarts. Im Bach to V11
  11. #158
    Quote Originariamente inviato da migel121 Visualizza il messaggio
    strange, I use it since this morning
    maybe some incompatibility, this week the cm12.1 has moved from build id LMY48G (5.1.1_r6) to LVY48F (5.1.1_r18) then several things have been changed
    if you can try to flash with a full wipe
    Nubia Z7MAX
  12. #159
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Same problem here when upgrading from v11 to v12 plus new radio. Reverting....
    I'm gonna check if the problem is with the radio or with V12.
    Once i manager to fully boot but phone did not enter deep sleep. After rebooting, random reboots before asking pin or immediately after.
    Ultima modifica di inigoml; 16-09-15 alle 01:52
  13. #160
    Jul 2015
    I update from v11 to v12. Everything looks fine!
    Note: I update to v12 first, rebooting, then update radio 357.
