Pagina 10 di 50 primaprima ... 8910111220 ... ultimoultimo
Visualizzazione dei risultati da 91 a 100 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #91
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    sorry but I not have any issue to compile the rom
    so something must have gone wrong when you put the patch
    Thank you, POLAO, I joined the file after the method of users, the compiler is not a problem, your new version for a long time and we meet? All Z7MAX users are looking forward to you! Thank you for your hard work!
    Nov 2015
    Quote Originariamente inviato da awssong Visualizza il messaggio
    But you give me four, I do not know which has a signal, and I have only one ground test. Do you give the four patches that need to be all together? Or just one of them?
  4. #93
    I succesfully ported the nubia camera app in CM13
    there is still a bug: the photos are always saved in the internal memory even if you set to use the external sd
    I try to fix this bug before uploading
    Nubia Z7MAX
  5. I seguenti 4 Utenti hanno ringraziato PaoloW8 per il post:
    inigoml (18-11-15),jadar (18-11-15),LiveMoto (19-11-15),migel121 (18-11-15)
  6. #94
    you need all four patch
    Nubia Z7MAX
  7. #95
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Fantastic.
    I'm afraid your bug is due to new Android 6.0 SD card treatment. If you use as external storage only for photos and music, you won't probably been able to write there. I've the same problem with ES File Manager when moving files from internal SD to external SD.
  8. #96
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    Fantastic.
    yes, maybe it is just that so for now I leave it
    I have found another bug with front camera but I've already fixed
    the only problem is that to fix this bug I had to modify the framework sourcecode then the NubiaCamera will be compatible in the new release alpha5
    (maybe tomorrow)
    Nubia Z7MAX
  9. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (19-11-15),LiveMoto (19-11-15),migel121 (18-11-15)
  10. #97
    Feb 2014
    Great News
  11. #98
    Nov 2015
    There is no order? These four patches seem to be in a directory.
  12. #99
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    (maybe tomorrow)
    Thanks! Good news!
  13. #100
    Nov 2015
    In cm12.1 and 13, when dialing *#*#4636#*#*, the first option allows us to get into sim network details and make changes on network type selection. Is it possible to add one similar option for sim2 as well, same as miui ROM does?
