Pagina 11 di 50 primaprima ... 91011121321 ... ultimoultimo
Visualizzazione dei risultati da 101 a 110 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #101
    Quote Originariamente inviato da owhk Visualizza il messaggio
    In cm12.1 and 13, when dialing *#*#4636#*#*, the first option allows us to get into sim network details and make changes on network type selection. Is it possible to add one similar option for sim2 as well, same as miui ROM does?
    the MIUI is based on stock firmware so can use some features present in the original rom
    CM are completely compiled from source code so without a patch is not possible (by default the secret codes only work on sim1)
    for change the network type the *#*#4636#*#* is useless, the same thing can be done in settings->sim or settings->other
    Nubia Z7MAX
    Nov 2015
    I see.
    What about default apps? I switched back ro cm13 yesterday, I use Next browser most of the time, when I click on a link like a link inside an email, ui keep asking me for default apps to use, even I choose Next browser always each time.
    I find I can define default SMS apps in setup, how about adding default setup for browser, camera, music, email, dialer, photo browser ..... as well?
  4. #103
    I see.
    try with another browser, I use chrome (beta) and does not have this problem
    select the default app for every "task" work exactly like lollipop
    Nubia Z7MAX
  5. #104
    link and changelog alpha5 in first page
    Nubia Z7MAX
  6. Il seguente Utente ha ringraziato PaoloW8 per il post:
    jadar (19-11-15)
  7. #105
    Nov 2015
    Downloading , thanks.
  8. #106
    Sep 2015
    Thanks Paolo for great job (once again). The choice of a different ringtone for each SIM card has disappeared. Is that an issue?
  9. #107
    Quote Originariamente inviato da jadar Visualizza il messaggio
    this feature is not yet been included in CM13
    Nubia Z7MAX
  10. #108
    Sep 2015
    Would it be? Can "you" do something about that?
  11. #109
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    reserved 1
    paolo,Your alpha 5 code for a long time to upload it?
  12. #110
    Nov 2015
    Today, after the compilation and the emergence of such a problem:How to solve it?
    In file included from art/runtime/gc/space/rosalloc_space-inl.h:22:0,
    from art/runtime/gc/space/rosalloc_space.cc:18:
    art/runtime/gc/space/rosalloc_space.h: In member function 'virtual size_t art::gc::space::RosAllocSpace::AllocationSize(art: :mirror:bject*, size_t*)':
    art/runtime/gc/space/rosalloc_space.h:65:3: internal compiler error: Segmentation fault
    Please submit a full bug report,
    with preprocessed source if appropriate.
    See <http://source.android.com/source/report-bugs.html> for instructions.
    build/core/binary.mk:706: recipe for target '/home/songyingai2012/android/cm13/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/gc/space/rosalloc_space.o' failed
    make: *** [/home/songyingai2012/android/cm13/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/gc/space/rosalloc_space.o] Error 1
