Pagina 20 di 50 primaprima ... 10181920212230 ... ultimoultimo
Visualizzazione dei risultati da 191 a 200 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #191
    Aug 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    ok done
    flash this zip without any wipe
    cm13.0fix_DisableSoftkeyWithNavbarEnabled.zip
    when enable/disable the navbar the softkey are disabled/enabled after a reboot
    ok.thx a lot...but i have already back to cm12.1. i'm a chinese user and there are still many details which were not translated to chinese,though they dont't affect usability.also some features are still missing so i decide to wait some time for the future version of cm13.
    Quote Originariamente inviato da momomo Visualizza il messaggio
    yes, for now a lot of things are only in english (but is not a big problem)
    Nubia Z7MAX
  4. #193
    Jan 2015
    Nubia Z7 Max
    Bug report: wi-fi does not seem to work. Clean install after system/data/cache/dalvik wipe.
    The installation program recognized my wi-fi network and connected, but then disconnected when I turned on mobile data, and I was unable to turn it on again.
    I downgraded to my go-to cm12.1-v18 installation but I thought you might like to know
  5. Il seguente Utente ha ringraziato RoboTrigger per il post:
    PaoloW8 (08-12-15)
  6. #194
    Quote Originariamente inviato da RoboTrigger Visualizza il messaggio
    umh... I just tried now with a clean installation (wiped system, cache, dalvik and data) and I have no problem with wifi
    Nubia Z7MAX
  7. #195
    Jan 2015
    Nubia Z7 Max
    Hmmm. I don't know, it might be something on my end then I'll try another wipe later or tomorrow and report when I do. Thanks Paolo!
  8. #196
    you have also flashed the gapps ?
    I know there is some problem if flash only the rom without the gapps
    Nubia Z7MAX
  9. #197
    Jan 2015
    Nubia Z7 Max
    Yes, I flashed the Gapp package in your Mega repository, but I disabled Google's wi-fi location checking. I'm thinking that might have something to do with it now.
  10. #198
    Oct 2015
    Hi, Paolo. I used Beta2 for a day and found a few Bug.
    First of all, I used the "cm13.0fix_DisableSoftkeyWithNavbarEnabled.zip ", but after the restart and no effect. Don't know if it's a case.
    Then, after the notification bar is pulled down, click the little triangle below wifi. Inside the WiFi name can not click.
    Finally, the problem of NubiaCamera and Default camera. Front camera open flower screen. I cleared the camera data, the problem still exists.
    Thank you again for your hard work.
    Ultima modifica di narutonote; 09-12-15 alle 10:06
  11. Il seguente Utente ha ringraziato narutonote per il post:
    PaoloW8 (09-12-15)
  12. #199
    Quote Originariamente inviato da narutonote Visualizza il messaggio
    Finally, the problem of Camera Nubia. Front camera open flower screen. I cleared the camera data, the problem still exists.
    lol, yes the front camera doesn't work (also with the camera stock app)...I try to fix
    for the softkeydisable zip, if you flashed the zip with the navbar already enabled probably not work... try to disable the navbar, reenable and reboot
    Nubia Z7MAX
  13. #200
    Oct 2015
    Thank you very much, Paolo. Thank you for your reply. I have closed the navigation bar. Looking forward to your next work
