Pagina 12 di 50 primaprima ... 2101112131422 ... ultimoultimo
Visualizzazione dei risultati da 111 a 120 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #111
    Nov 2015
    Alpha5 loaded, so far okay except:
    - files access rights in some root required apps (most likely due to busybox issue)
    - Smart Lock cannot access Bluetooth list selection
    Quote Originariamente inviato da awssong Visualizza il messaggio
    Today, after the compilation and the emergence of such a problem:How to solve it?
    In file included from art/runtime/gc/space/rosalloc_space-inl.h:22:0,
    from art/runtime/gc/space/rosalloc_space.cc:18:
    art/runtime/gc/space/rosalloc_space.h: In member function 'virtual size_t art::gc::space::RosAllocSpace::AllocationSize(art: :mirror:bject*, size_t*)':
    art/runtime/gc/space/rosalloc_space.h:65:3: internal compiler error: Segmentation fault
    Please submit a full bug report,
    with preprocessed source if appropriate.
    See <http://source.android.com/source/report-bugs.html> for instructions.
    build/core/binary.mk:706: recipe for target '/home/songyingai2012/android/cm13/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/gc/space/rosalloc_space.o' failed
    make: *** [/home/songyingai2012/android/cm13/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/gc/space/rosalloc_space.o] Error 1
    I stil have no problem to compile the rom
    you can try with a clean compile
    codice:
    . build/envsetup.sh
    lunch cm_nx505j-userdebug
    make clean
    brunch cm_nx505j-userdebug
    Nubia Z7MAX
  4. #113
    Oct 2013
    Ultima modifica di tigreos; 20-11-15 alle 13:58
  5. #114
    I have enabled the doze feature in CM13 but I don't know if it's works or not on our phone
    to work it needs the sensor "Significant Motion Detector" and I really don't know if our phone has it
    (cpu-z reports this sensor but without any value)
    Nubia Z7MAX
  6. #115
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    this feature is not yet been included in CM13
    Paolo,what time do you upload the latest ALPHA 5?
  7. #116
    I'm working on sepolicy rules so I will upload when I finished
    Nubia Z7MAX
  8. #117
    Nov 2015
    Thanks!!paolo
  9. #118
    Nov 2015
    paolo,Alpha5 Is not yet perfect? ROOT permissions problem is solved, and so you upload it?
  10. #119
    Nov 2015
    Paolo,What's the nearest busy? ROM has the update? About what time?
  11. #120
    Jan 2015
    Nubia Z7 Max
    Seriously guys, stop rushing Paolo. He's not ZTE support and he provides this ROM in his free time. We should be very thankful to have someone like him working on this, not harass him every day for updates.
    Thanks for the great work Paolo
  12. I seguenti 2 Utenti hanno ringraziato RoboTrigger per il post:
    flasher (24-11-15),PaoloW8 (23-11-15)
